Question about Ryobi Drills
Ryobi 18 volt battery charger
Battery charger does not work
    Genius:
  • 1,212 Answers
If replacing the charger is not an option, open it up and check the fuse. Another item to check is the current limiting resistor, color coded red-red-black.
Posted on Feb 18, 2012
rowdy45176
  • 2176 Answers
SOURCE: 18 volt ryobi battery charger...green & yellow lights come on wha
talked to Ryobi and they are vague. It can either mean that the battery is bad, or the charger is bad and another one that maybe the contacts of the battery are dirty or not seating fully in charger. What I would look for in this instance first unplug the charger and look into charging slot to make sure the terminals of the charger are not bent and they come out into the cavity where battery would go. If not gently pull terminal into opening and retry. Sorry I couldn't be of more assistance
Posted on Dec 31, 2008
  • 74 Answers
SOURCE: can a bad ryobi 18 drill ruin a new 18volt ryobi battery
If the drill has a short in it, then yes, it could short the battery out. Probably in the trigger switch.
Posted on Feb 10, 2009
  • 104 Answers
SOURCE: my 18volt Ryobi battery needs the inside batteries
Yes you can replace the inside batteries yourself , just take the old ones out and go to Battery world or a similar shop and get replacements then all you have to do is repack them yourself and put them back into the battery case .
Posted on Jun 12, 2009
  • 4 Answers
SOURCE: delta 18 volt charger broken
buy a new one
Posted on Oct 06, 2009
Testimonial: "you missed the point te charger is "obsolete""
chasemagnum
  • 7 Answers
SOURCE: how to fix an old RYOBI 18 volt battery won't
take a hammer, and apply force. These batteries dont last forever... but i am serious about the hammer... you may be able to free up whats inside (if you know how a batterey works.)... also apply heat.. try to hit it from all angles than slam it down on the back and leave it sit... than try. I hope this works for you my dewalt batteries over the years have don this, and it works.. but BTW. it wont hold a charge for very long anymore.. the battery is pretty much garbage.
Posted on Oct 13, 2009
I have 2 ryobi 18 volt one + batteries won't charge, blinks red. I have 2 chargers, same for both. 65 degrees here so not too cold.
Just a thought, lithium batteries wont charge in Ryobi's old chargers. I upgraded my batteries but not the charger until I found this out.
Feb 18, 2017 | Ryobi Drills
Who rebuilds ryobi 18 volt li ion batteries
Rebuilding the Lithium batteries is a waste of time and money. For starters the cells cost a minimum of $5 ea and a low power pack takes 5, so now you are in for $25 without doing any work. You can pick up packs on eBay for around $30 - $40 if you shop around. If you know what you are doing, you can strip cells from bad packs and test them to find good ones and then rebuild with those. It can be tricky and you may get mixed results.
Aug 23, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
Will a ryobi 18 volt charger replace a coleman powermate battery charger?What's your problem?
They look different in their shape where the battery goes so I would say no. To be safe always use the charger from the same manufacturer. There are a few different types of batteries too so it is always best to use the model number of your original charger to search for the replacement.
Aug 08, 2012 | Coleman Cable Coleman 18 Volt Combo Drill...
My 18 volt Ryobi battery shows charged in charger (Green Light) But will not work in any of the power tools. I have three other Batteries that do work. Bought at Home depot on july 24 2011 Ryobi Two 18V...
Some of batteries drain very quickly. Depends on how they are used.
Feel free to check Your Local battery Manufacturer for best prices for all different batteries. You name it and they have it or they can custom make a battery for you.
Thanks
Oct 09, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Will 14.4 volt charger charge 18 volt battery ryobi
I'm afraid not. It will damage the battery if you try. You'll need to get the correct charger.
Jan 12, 2011 | Ryobi Multi-Volt Battery Charger
I have a ryobi 18V battery and the only charger I have is a ryobi 14.4V. Can I charge the 18V battery on that charger?
Hello, unless the charger specifies that it charges 18 volt, it will only charge a 14.4v properly. If the battery fits the charger physically, then the most you might get an 18v to charge at is 15 or 16 volts. Your battery life will be shorter and you might damage the charger. I hope this helps.
Jan 12, 2011 | Ryobi Garden
Charging
Negative partner, you can try all day everyday but 12 v is 12v and 18 v is much more. its just not gonna supply enough juice to charge the battery. the most youll ever charge it is 12 v... sorry.
May 02, 2009 | Ryobi Multi-Volt Battery Charger
Can a bad ryobi 18 drill ruin a new 18volt ryobi battery
Jan 24, 2009 | Ryobi Multi-Volt Battery Charger
Drills Logo
518 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
