Question about Toshiba Computers & Internet
TOSHIBA PSLTOA-00D001 ERROR CODE F3-F100-0007
RUNNING RECOVERY TO FACTOY SETTINGS
SOURCE: error code when creating recovery disc
smash it, lol, i hate some computers, by the way im just kidding i have no clue what to do!
Posted on Jun 23, 2009
Holygrass
  • 443 Answers
SOURCE: F3-F100-0003 error
When exactly do you get this error message?
Is it while you open any application or at the start up of the computer?
What's the recent change that you made to your computer prior to this issue occurring?
Get back with more details to assist you better as your question does not contain all the necessary information required to help
Thank you.
Posted on Dec 28, 2010
  • 115 Answers
SOURCE: my laptop toshiba satellite L455
the only way out is to order a cd recovery for your model from toshiba and it will work cuz somthing was erased that wasent suppose to now theres issues .factory restore will get it all back to normal ,if helpful plz rate.
Posted on Jan 19, 2011
Ezrahite
  • 2632 Answers
SOURCE: On start up of my Toshiba Satellite L505-S5990
Hi ilikepie2,
Unfortunately Error F3-F100-0003 means that the hard disk has failed. You need to replace the hard drive of your computer. If you can get someone (local tech) to check if they can still recover the files on it, it would be better.
Thanks for using Fixya.
Posted on Jan 28, 2011
SOURCE: dropped and screen broke,replaced the
sounds like bad luck. your hard disk or the cable to your hard disk is gone.
try to take it to a service center.
Posted on Jun 17, 2011
Erreur F3-F000-0001
That error is a hardware error, either the recovery disc has errors or the hard drive has bad sectors. The bad sectors may be logical sectors that will prove OK if you run chkdsk/f and the boot sector may repair if you run the command 'fixboot'
Hope that helps.
Dec 24, 2013 | Toshiba Computers & Internet
ERROR : F3-F100-0003 when running recovery disc for Toshiba Satillite L755-25217
Just format your Laptop because your operating system is damage.Install another Operating System that's all.
Mar 26, 2013 | Computers & Internet
F3-f100-003 error code what does it mean?
The new HDD apparently has no OS. what is what the msg says.
boot to Bootable media with to install a NEW OS. or boot to your Recovery Media. and let it restore to Factory.
if this does not help - then provide more info.
Jan 18, 2013 | Toshiba Satellite Computers & Internet
Error code F3-F100-0004
I suspect, you have been trying to restore to factory settings. This does appear to be a common problem with Toshiba Satellites. You should always make recovery discs if they are not supplied with the PC, a lesson you will now have learned.
You have two choices, you can either contact Toshiba and see if it is possible to purchase a set of Recovery Disks for you particular laptop. Or, you borrow (as you have already thought of) a Windows 7 OS disc. Keep in mind this disc must be the same version of Windows 7 that is written on your Product Key sticker. This will probably be stuck underneath the laptop. If you try to use a different version your product key will not work.
If you can get the discs from Toshiba this will save you the time and trouble of having to download and install all the drivers that you need for a clean install as they will be included on the discs. Hope this helps.
Jan 08, 2013 | Toshiba Computers & Internet
My laptop will not reboot. I was trying to set it back to an earlier date and it crashed. I get an error - F3-F100-0004. How do I repair it?
A Google search for this error code suggests that this may (or may not) be a disk problem. You should attempt to recover your data files (photos, documents, videos) if they are not backed up somewhere else.
A competent tech should be able to boot from a Linux-based recovery CD or DVD and recover your files. A slightly harder way is to pull out the drive and recover the files using another computer running Windows or Linux.
The machine is certainly repairable. If there is a service contract or warranty, have the supplier do the repair AFTER you have secured any files you wish to keep. The manufacturer will almost certainly erase everything in the repair process.
Sep 29, 2012 | Toshiba Computers & Internet
Error : F3-F200-0002
This is actually a problem with the recovery disk. Your notebook comes with a recovery partition that will allow you to perform a recovery without discs. I would suggest you hold "0" when you power on the computer, and then follow the prompts. You can as well call the Toshiba support for assistance.
Sep 11, 2012 | Toshiba Satellite L675D-S7016 Laptop
F3-F100-0010
http://www.windowserrorhelps.com/error-f3-f100-0010-fix-toshiba-error-f3-f100-0010-the-simplest-way/
This website explains it well, along with a few options to fix it. Uses some computer jargon but is fairly easy to understand.
May 23, 2012 | Toshiba Satellite C655DS5043 Notebook
Toshiba C650 error F3-100-0003 recovery
The problem is in the hard drive or the recovery disc has a flaw. The hardware needs to be tested to find out.
Apr 19, 2012 | Toshiba Satellite C650 series C655S9520D
Toshiba error F3-F100-0003
Maybe caused by damaged recovery media or faulty hard drive.To reinstall your laptop to the factory settings / "out of the box" settings, please follow these steps. It worked for me, and should work for you.
ALL DATA WILL BE ERASED ON YOUR HARD DRIVE IF YOU PROCEED. YOU WILL NEED TO ENSURE THAT YOU HAVE THE POWER ADAPTER PLUGGED IN. DO NOT SWITCH OFF OR RESTART YOUR COMPUTER DURING THIS PROCESS.
1) Hold down the power button for 10 (ten) seconds to switch off your machine.
Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
3) When the machine Starts beeping; release the 0 key.
4) When prompted by the warning screen; select Yes to continue with the system recovery.
5) Select Recovery of Factory Default Software; click Next.
6) Select Recover to out-of-box state. Click Next again.
7) Click Next to Start recovery.
Apr 11, 2012 | Toshiba Satellite A205-S5880...
Computers & Internet Logo
44 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
