Question about Acer Veriton 7100 PC Desktop
Im try to format my acer veriton 7100 but the computer cannot boot any drive.. teach me how to do it
I put the dvd win xp pro sp3 to format.. but the computer cannot boot any drive.. and ask me to insert a system diskette
    Genius:
  • Acer Master
  • 1,274 Answers
When the pc starts you'll see a splash screen that says hit "*" key * being some random key usually delete, or f2 or f1. once in bios change the boot order to DVD/CD first. save changes and exit. upon reboot you should see the computer say press any key to boot from DVD.CD
Posted on Feb 17, 2012
4 Suggested Answers
ithana
  • 185 Answers
SOURCE: unable to load retail version
the only way to solve the problem is need to re-install the OS, otherwise u can open it safemode and made save changes like system restore,etc. but it is strongly recommended to re-install the os.
Posted on Aug 15, 2008
gherna1
  • 190 Answers
SOURCE: Tengo una Nueva Acer Veriton M460 core 2 duo,
La instalación del HP Compaq no funciona en la máquina nueva porque el sistema (hardware) es completamente diferente.
La mejor manera de hacer el "downgrade" es instalar el sistema operativo desde el comienzo, borrando cualquier partición que exista, donde está el sistema operativo instalado que no funciona. Para eso se necesita el CD o DVD con Windows XP SP2. Esto se hace activando la opción en el BIOS de la PC para que lea el CD o DVD antes que el disco duro. Una vez dentro del programa de instalación, hay que descartar la instalación anterior borrando la partición y volviendo a crearla, usando los íconos del programa.
¡Buena suerte!
Posted on Dec 02, 2009
mariolands
  • 2296 Answers
SOURCE: My desktop audio driver for
Here is a direct link to download the audio driver for Acer Veriton 3500.
Posted on Dec 05, 2010
Boot with press f1
to do a format you must boot the pc with the disc in the drive, and set pc to boot from dvd, in boot options, then when it comes to install options press options and format, this will do a wipe/format and you should be ok from then.
Jan 26, 2013 | Dell OptiPlex GX110 PC Desktop
Acer L410
Make sure you have the proper video drivers loaded.
Give that a shot and hopefully it should resolve your issues
Oct 27, 2012 | Acer Veriton L410-ED4450C PC Desktop
Hi there, have a strange problem with a brand new DVD SAMSUNG SH-S223C. Installed a few days ago and running latest SB05 firmware (Even I reinstalled twice this firmware). Now on boot with my WIN XP PRO...
Start up BIOS and perhaps change default boot drive to your hard drive because i think your default boot up device is the dvd drive.... try to put that last on the list... F2 should get you to BIOS if not try F8 Just keep tapping right at beginning of startup before the logo screen shows. Once in BIOS go to boot menu and change default device :) Hope that works for you
May 04, 2017 | Samsung SHS223C 22x Internal DVD±RW...
How can i remove windows 7 starter and install windows xp
Boot to you bios and make sure you can boot off your dvd rom first. boot off you win xp disk and follow the instructions.
First locate drivers that are compatible with your computer and win xp.
Apr 06, 2010 | Acer Aspire One PC Notebook
I dont have a branded pc its a clone so heres the problem i have upgraded my pc with 3 dvd combo drives but when i try to repair it using the windows xp 2sp2 disk it always shows an error message i cant...
You plug in the drives, you don't have to repair windows just because you added drives.
You can't repair xp it does not have a repair, it only has recovery, and unless you made a recovery disk or have one you can't.
Windows xp is up to SP3.
Did it boot from the disk ? you need to force boot to cd, But try this.
When your BIOS post, first screen, hit the F8 key, and see if you can boot into safe mode.
Then go to start, accessories, system tools, system restore, and restore it.
Any other questions of you have have more details after you try this post back.
Feb 07, 2010 | Acer Veriton 5600GT PC Desktop
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Tengo una Nueva Acer Veriton M460 core 2 duo, vista bussines,Disco Duro Seagate 320GB, se hizo downgrade a Win XP PRO, no funciono, volvi a recuperar disco duro, hize lo mismo y no funciono, instale el...
¡Buena suerte!
Dec 01, 2009 | Acer Veriton M460 Micro Tower Core 2 DUO...
I want to format my pc acer 6800 veriton because it detected a spyware
Use the windows installation cd / dvd it will ask you to format / partition the disk in the setup.
Jul 10, 2008 | Acer Computers & Internet
DVD Drive auto ejects on stratup of system & Remains open
did this happen after you have updated your win xp to sp3? try to do a system restore. go to all programs>accessories>system tools>system restore> go back to the date before the sp3 was installed. try also updating the driver for your optical drive
Jun 12, 2008 | BenQ DQ60 DVD RW Dual Layer Burner
Acer Veriton 7100 PC Desktop Logo
116 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
