Question about Galaxy Radios DX-959 40-Channels Base CB Radio
The variabel key drops sometimes drops when radio is keyed up and sometime the RF power knob has to be turned farther to bring it back up on my Galaxy DX959.
The variabel key setting sometimes drops with out turning the RF power knob wether talking or not. Sometimes i have to turn the RF power knob farther to bring the key back to the same setting that it was. What could be causing this?
    Problem Solver:
  • 26 Answers
I'm not shure if you have tried but turn the mic gain down then check the d.k output. If you still lose power after a d.k it could be a final it's hard to say w/o seeing it. Also an external meter is more stable than the internal one. Check your coax, make shure all are tight. If you need more help e-mail me at
herzjoe3@gmail.com. no capital's
Good luck
Posted on Aug 24, 2012
3 Suggested Answers
thetez
  • 32 Answers
SOURCE: dx959 galaxy
do you have any knobs or switches that say 10k or just switches on the side. It should also be on AM if the other person is on AM (this is not a 10m radio anymhz it only has AM, it is a legal CB Radio) Generally you should just be able to put it on AM and talk if your on the same channel. if its been modded and has switches a 10k switch or (high low norm) these may no be in the right place. if the clarifier is unlocked that may also cause a problem, it needs to be on with the switches and knobs in the right place.
good luck! play with the switches, with someone else who has a radio.
Posted on Feb 12, 2009
  • 40 Answers
SOURCE: Galaxy DX959
it can not be tuned to go high or low you need to add switches for that and then realign the radio.
Posted on Mar 10, 2009
How do i set my galaxy dx 88 hl so the talkback is on all the time
turn the talkback knob to the right and push it in to engage talkback.when you get the volume you want leave it alone .Now key the mic.You will probably hear a squeal coming from the speaker.Now turn the volume down on the talkback knob until the squeal goes away.If you run your RF gain wide open it may squeal also.
Sep 25, 2013 | Galaxy Radios DX- 88HL Base CB Radio
What makes the radio cb 959 galaxy have no ears
It could be your antenna or coax. Check the swr. Also check the rf gain knob. It also could be the mic. Sometimes the wires come off.check all conn. Like coax to the radio. If you still need help here is my email
www.herzjoe3@gmail.com
Jul 26, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
Icom ic 7600 rf issue
it is just because your cable is loose, try it after tightning it up
Jun 05, 2012 | Icom IC-7600 HF/6 Transceiver
Why is the variabel key un stable on Galaxy DX959
Dirt or corrosion on the controls, the relay contacts, and even some switch contacts. Contact cleaner applied judiciously should remedy most of the potential causes.
Feb 16, 2012 | Radio Communications
SSB dead key & TX frequency problems
Check C-144, c-149, c-153, c-154 using an ESR meter.
Dec 23, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
Frequency counter displays two digets high from hump on fine clarifier adjestment on usb.27.186 insted of 27.185. also in am mode shows dead on with clarifer hump until mic is keyed thin dropes from 27.185...
Turn that fine clarifier a 1/4 turn or so to the right. I own a Galaxy DX99V and sometimes if that clarifier is just right it will drop down a hundredth of a MHz just like that when the mic is keyed. Your radio is just fine. Just adjust that clarifier a tad. The Galaxy DX99V is one of the best radios out there. I love them. -73-
Mar 10, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
Full power with zero modulation
you possibly have a faulty microphone, if the amp is keyed to transmit and there is not audio to modulate. Try another mic
Sep 19, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy 2547
Is there a dial marked RX Gain? Does this radio have this feature?
M3ODQ
Feb 01, 2009 | Galaxy Radios DX-2547 40-Channels Base CB...
I HAVE A 2517 GALAXY RADIO IT IS MUFFELD ON TRANSMIT
What is the power output on a watt meter telling you? if it is up above an 8 watt dead key with the rf power turned all the way down, someone has turned up the radio inside and you will ned to turn it back inside to get about a 2 or 3 watt dead key with the rf power turned all the way down on the outside knob on the face of the radio. to do this, you will need to locate the VR18 pot for low power on am/fm and the VR14 pot for high power on am/fm and adjust accordingly, you are most likely overdriving the radio in some way and if you are not familiar doing this sort of thing, then my suggestion would be for you to take it to your nearest electronics repair tech and have them do it for you. It is not a costly procedure and you will be better off to have an experienced tech in there. Also if you are running a power mic on it, try turning it down some or going back to the stock mic to see if the problem persists. If it does while running the stock mic, then most likely it's internal issues like the one explained above.
Dec 10, 2008 | Galaxy Radios DX-2517 CB Radio
Galaxy Radios DX-959 40-Channels Base CB Radio Logo
94 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
