Canon NP6025 copier keeps saying Error E010
My Canon NP6025 copier keeps saying "Error E010 Turn off and turn back on again", nothing happens except to show me the same message. Solutions?
  • 31 Answers
SOURCE: Canon 6025
Your problem is most likely caused by dirty optics. Place a sheet of paper on the glass & make 1 copy with the lid up. Look under the glass at the mirrors on the scanner & see if there is any dust on them. If so,turn the copier off & unplug it from the wall, remove the glass & wipe off the mirrors with a DRY cotton rag. There are 3 mirrors on the scanner assy. There is also three mirrors under the lens cover that should also be cleaned. After cleaning the optics, make a test copy.If your copies are still to dark, press the additional functions key & select exposure adjustment. You can lighten/darken all copies by changing this setting. If you have any problems or questions my email is bspier@carlsonsupplies.com Good Luck!!
Posted on May 29, 2007
SOURCE: Canon NP 6030 Error code E010
M/C GEARS JAMMED . MAY BE DP UNIT JAMMED OR MOTER (MAIN) JAMMED OR FULL OF DUST ETC.
Posted on Oct 06, 2007
SOURCE: Canon imageCLASS D761 Grayscale Copier
hi im jules_09.try checking the power supply board,trace the voltage output from the power board to the logic or main board.if the logic board is deffective there is an error that will indicate it
Posted on Dec 11, 2007
MediaMan85
  • 163 Answers
SOURCE: Canon copy machine NP6025. Error E800.
According to what I have E800 is eith a problem with the Mains switch or DC controller. I doubt it's the switch but there are many things that would cause a DC controller error. You might try Hytec Board Repair for help on the DC controller. http://www.hytecrepair.com/
Posted on Dec 12, 2007
Cogz
  • 1326 Answers
SOURCE: iam getting error code E010,E014
A E010 & E014 have to do with the main motor drive. You may have a drum blade that has flipped or it could be that the center screw that locks the drum to the drum shaft is loose ( just tighting screw- you can also get blank copies as well. The E014 deals with the fixing unit, you have to make sure it is spinnig freely. It could be that the lower pick off claws have dug in to the lower fixing roller, or the ball bears are siezed or the web is rapped around the upper fixing roller or a bushing is broken or it may be to much pressure is on the UFR from the web... Just a few ideas.. Good Luck
Posted on Nov 07, 2008
Canon ir 2018n error code e010
check the drive of the main motor >may be a broken gear .If that is ok then check the main motor in another machine.If that is also okie then u have got urself a fried DC controller PCB.Replace it
Mar 28, 2012 | Canon Office Equipment & Supplies
Okay i want to print something and my Canon IP2600 keeps saying "Cancel printing then turn off then turn on again." but it doesnt do anything....?
On this model there is a cartridge full error that happens when the ink containment unit gets full. This is a very messy job trying to clean them.
Aug 18, 2011 | Office Equipment & Supplies
I use canon imagerunner 330. what happen when it says switch main power off and on. E010 do i have electrical problem or technical problem
The Error code E010 means that there is a drag on the main motor. I would look in the fuser unit & see if the lower fuser roller is damaged or that the cleaning web is wraped around the upper fuser roller. Also try to turn the fuser. You may have a siezed ball bearing. Also, try to remove the drum unit and close the door and see if the code is gone, if so you have a problem with the drum unit, but I would say it is in the fuser unit...... Good Luck
Sep 05, 2010 | Canon imageRUNNER 400S Copier
Once the np 6050 is turned on it displays error code E010 switch off and on again
E010 code is main motor lock. Open front cover, Release Transport/Fixing Unit tray. Pull the tray out untill it stops. Try rotating the larger knob to see if Fixing unit will turn...if not, raise the exit/stripper assembly to check for jammed paper. If no paper present and the Unit turns freely, reinsert Transport/Fixing tray into copier. Latch into place. Close front cover. Power on machine.
It is possible that the main motor has failed, but not likely.
Jun 19, 2009 | Canon NP 6050 Copier
E010 error code is a main motor lock .
Check for jammed paper in the Fixing unit.
Pull transport/Fixing Unit tray out and rotate large knob on left side to check Fixing unit for obstruction/turnability. Other than this, it could be main motor failure.....
Jun 08, 2009 | Canon NP 6050 Copier
System error E000 how do I fix it. I tried what it said in the instructions to turn it off for a while then turn it back on that didn't help. Canon NP6025 copy machine.
To delay the 3 second shut down and enable the technician to access service mode; open the front door and pull out the transport unit. Do not actuate front door microswitch. Press the service mode button, enter " * 4 * ", scroll to error clear and clear error code. Machine will automatically turn off power after clear. Power up machine and test.
If the power shuts down after error code has been cleared, the cause of the error has not been corrected. Correct cause of error code and clear error in service mode.
May 07, 2009 | Canon Office Equipment & Supplies
Error message on canon np6025
LOL.... I just kept wiggling wires and connectors and all of the sudden it worked.... not real sure what I did .
Apr 09, 2009 | Canon Office Equipment & Supplies
Dec 11, 2007 | Office Equipment & Supplies
chiudere sportello superiore destro
Oct 04, 2007 | Office Equipment & Supplies
64 people viewed this question
k24674
jasbo
jasbo
