Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
45's records won't turn and prior to that they only played side B
The first problem I had was that it only played side B of the record no matter what was selected. I changed all of my records around to make side A be side B. Then after a period of time the spinner that holds the records stopped spinning. Now I can't use it at all. Help, any suggestions on how to fix?
Thanks
Janice
    Champion:
  • Wurlitzer Expert
  • 211 Answers
There's a motor under the back of the carousel about 11 oclock. You can see the drive gear if you bend down and look under the toothed base of the carousel. If you press the lever to rotate the carousel you'll be able to see if the motor is turning or not. If it is turning but the carousel isn't moving you could have a stripped nylon gear.
Posted on Nov 03, 2008
Hitachi Troubleshooting
Check to see if you have a setting to change between 33 or 45. If set to the wrong setting for the size record you are playing the tone arm will pick up incorrectly.
Nov 16, 2013 | Heating & Cooling
Even though i am playing my record on normal speed, it plays to fast
if your turntable doesn't have a pitch control (like the dj's turntables) if you open it you should find on the board close from the 45-33 rpm switch a variable resistor ( a small electronic part with a sort of disc on top with in the middle of it a place for a flat screw driver and marking like + and - those resistor are made to control the speed and can go bad or just need to be adjusted . First try to adjust it turning the dial really carefully with a small screw driver if nothing happened it could need to be replace.
Feb 03, 2013 | Mutant MIG-MT201 Record Turntable, 33...
When i play a video on my phone that's not recorded, it won't play and the video's format is 3gp but it still won't work
Though 3gp works on mostly all mobile but their size also matters, if file is big or its a movie that you have converted then its unlikely as file size id big and unrecognizable in some models
Oct 10, 2012 | Nokia 6300 Cellular Phone
My smilebox slide show won't record.
My creations preview great but when I press the save to DVD nothing happens, I am not saying is a smilebox problem, but It used to work just fine. I am just wanting to know what to do because I just wasted 40 bucks if I cannot burn it
Jun 21, 2012 | smilebox.com
What is required to convert 78rpm records to mp3 format?
The cartridge must have a stylus for 78rpm records. If the turntable does not have a 78 speed play it back at 45rpm. Record it and using the software you have or get one such as Audio Cleaning Lab, just select the option to convert from 45 to 78. You can then carry out any audio modifications to clean it up, then save it as an MP3.
Never use a 45/33 stylus to play a 78 and never use a 78 to play a 45/33 record.
Nov 07, 2010 | ION Audio TTUSB10 Turntable
My console can only play 45 rpm records
There should be a record size selector switch somewhere. It will move the arm to the positions for 12inch 7inch and 10inch records. It must be set to 7inch or 10 at the moment. For 33 it should be on '12' and for 45 on '7'.
Jul 11, 2009 | Audio Players & Recorders
Samsung dvd r-120 recorder
First make sure there is not a DVD or CD in the tray. It must be empty. Turn the unit off, then on. Then press the "play/pause" and "stop" buttons. This will reset your DVD player. This worked for me. Unfortuantely the DVD player has always had issues with DVD's that play over 90 minutes. At this point it freezes. I have updated the firmware. It seemed to freeze earlier prior to the update (say around 45-60min). It came free with my TV, which after a year was replaced as it required a $2k repair.
Jun 03, 2008 | Samsung DVDR120 DVD Recorder
Stops recording discs
certain discs will be ok then when u record something then try an play it it says th words no read then takes ages to get it out of th machine
Feb 25, 2008 | Samsung DVD-R4000 DVD Recorder
Problem playing 45 Records to their entirety.
There is an adjustment on the tone arm that you use to set where the tone arm picks up at the end of the record. This adjustment is normaly at the back (pivot point) of the tone arm and will be on the side probably. By the way, the tone arm is the part that the stylus is mounted to that swings back and forth to reach all the surface of the record. Make your adjustment and then test and continue doing this until you get it just where you want it. It is a process of trial and error. Good luck.
May 20, 2007 | Emerson NR303TT CD Shelf System
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
93 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
