Question about CacheFlow 600 CA-611 (080-02588) Proxy Server
Username / password
Hi there, i need to gain access to the cacheflow box but dont haev a usename or password . Also is there anyone in Melbourne Australia who supports this box ?
  • 51 Answers
SOURCE: how to access to cacheflow ca-615 proxy server
Do you know the IP address of the device? You can learn that from the front panel according to the manual at:
Once you know the IP address you can access the device from a web browser using the format
Posted on Nov 10, 2007
0 characters
1 Points
I for get my pass word
This issue can be resolved by reseting the router.You might see a reset password option on the back side of the router.
Please reset the router by placing a pin in reset hole and push the pin slightly, (remember you need to do this when the router is in ON state)
Then connect your router to your computer using Ethernet port (this is for configuration) and also connect the ADSL cable.
now open internet explorer and type in //
Then it will prompt you for user name and password
Username: admin
Passsword: password
this username and password is by default.
Jan 21, 2011 | D-Link Other Network Devices
How do I reset LinkSys Router Default Password?
When you forget your Linksys router password, you will need to reset it back to the factory defaults. You can restore the router configuration to back to the factory by following the steps outlined below:
1. Hold in the reset button of the router for 30 seconds. 2. Unplug your power cord for 30 seconds 3. Plug back your power cord4. Wait for a few seconds then release the reset button.
NOTE:¨ When holding in the reset button, make sure that you do not release it until you are sure that it has been compressed for at least 30 seconds or more.
¨ This procedure resets the router back to all its factory default settings thus apart from affecting your username and password, it will also affect your configuration and IP addressing.
Once this is complete, you can now login and reconfigure your password. To do this:
1. Connect a PC to one of the Linksys router Ethernet ports
2. Open your web browser and go to the URL This will take you to a web page with a popup box which asks you to enter a username and password to login required to login to your router
3. On older LinkSys routers, the username is set to blank and the password is set to "admin" (without the quotes). On newer Linksys routers, both the default username and the default password are set to "admin".
4. Click on login. You have logged in to the Administrator account and are now able to access and change a number of configuration options for your router.
5. Click on management tab then change your administrator password to any password that you like. Remember to choose a strong password that others cannot guess but that will be easy enough for you to remember.
6. You can also choose to reconfigure other aspects of you Linksys router at this point.
on Nov 25, 2010 | Other Network Devices
Cannot access my account
Not very clever to give your log in details or email out...
Click on the forgot password link.
You need to be more carefull giving personal details out
Jul 22, 2010 | Compaq NetFlex (142042-001) Control...
I have forgotten username and passsword on my router
The common username and password are the following:
Username :admin
Password :admin
Username :admin
Password :password
If these does not work try to reset the router to factory default and then the same would work
In order to reset either there would be a dedicated reset button either on front or back of the router,or there would be a reset hole where u need to put in a pin and hold it for 20-30 seconds, if none of them are available press the power button and keep it pressed for 40 - 50 seconds, it should work
Jun 14, 2010 | Other Network Devices
How to unblock websites
Thats ad AdBlocker running on your browser or server blocking your access. If its on a browser it should be a plugin. You haven't specified the browser. If it has set on server level that needs a different approach than this.(If they use an add blocker or a site blocker. If so use this link. Use the proxy. If they use more hardened security you may have to use a free vpn to bypass them).
Managing Add-ons in IE Managing Add-ons in Firefox
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem...Thanks for contacting Fixya
May 29, 2010 | CacheFlow 600 CA-615 (080-01776-01) Proxy...
I need a proxy that cant be blocked solve this
Feb 24, 2010 | CacheFlow 600 CA-615 (080-01776-01) Proxy...
Password recovery
try a password recovery tool,hope this may help you:
how to recover lost password?
Jan 20, 2010 | CacheFlow 600 CA-611 (080-02588) Proxy...
How many users can connect to CACHEFLOW CA-645 PROXY SERVER
A CacheFlow 645 will handle 750 requests/second. There is no absolute limit on users. It has to do with how much web surfing each of those users is doing. The 645 is the top of the line for the 600 series. This line does not provide a highly available solution unless you use multiple devices in a farm.
Jul 02, 2009 | CacheFlow 600 CA-645 Proxy Server
How can i set a password on my dlink dir 300 router to prevent other computers from accessing my internet connection? please help. tnx a lot..
Type in your address bar. It will prompt for a username and password, by default username is admin and password is blank. Then find the wireless sercuity or security tab and change type to WEP- Personal. You'll need to set a wep key. Then you'll have to resetup network on all wireless computers or connections.
Mar 15, 2009 | Other Network Devices
How to access to cacheflow ca-615 proxy server
Nov 10, 2007 | CacheFlow 600 CA-615 (080-01776-01) Proxy...
CacheFlow 600 CA-611 (080-02588) Proxy Server Logo
Top CacheFlow Other Network Devices Experts
 C. Dante
C. Dante
Are you a CacheFlow Other Network Device Expert? Answer questions, earn points and help others
