Question about FIC AU13 Chameleon Motherboard
Looking for manual for rs480m motherboard
Where to plug in power wire from emachine t6520
  • 2,229 Answers
Try this one:
http://productsmanuals.com/computer-manuals/ecs-rs480-m-motherboard-manual
Posted on Feb 17, 2012
I need the wiring diagram that shows where on the motherboard to plug the power switch ,power LED, and HDD Led on a T6520 emachine desktop
Most Motherboards are made to only accept certain plugs in that specific spot! If you are trying to add something new like a new Fan or LED, or HHD and you need power you would have to use a 4 prong plug off the power supply, If your power supply does not have any more available plugs, Amazon.com or Newegg.com sells splitters!
Good Luck and Best Wishes!
May 03, 2011 | Computers & Internet
I am trying to find the power switch diagram for an emachine t6520 thanks
On a Asus motherboard its not designed for eMachines systems because they come with a proprietary setting on the case. So what you need to is take the emachines motherboard that you took out and take the new motherboard that you bought and match the two. If there is a difference then you need to return it or buy a new case and you shift all the hardware from the emachines to the new case. If not buy a similar replacement board from emachines or ebay and you can find one and buy it. The Power setting is on all motherboards but some are different then others.
Dec 04, 2010 | E-Machines T6520 PC Desktop
I NEED TO KNOW HOW TO CONNECT THE POWER SUPPLY FOR AN EMACHINES T1120 COMPUTER. CANNOT FIND A SCHEMATICS DIAGRAM ANYWHERE.
After reading an article about Emachines awhile back, I found out the reason you can't find the schematic- it isn't available, as some motherboards are made specifically for Emachines and therefore not distributed, as they might normally be, but again, others are, but you have to identify them and go through another source to get them- Emachines, appartantly, will not supply them. All is not lost, however...all motherboards have, basically, the same hookups and connectors for the power supplies, hard drives, etc.- they are standard. I found a web blog that explains the power switch, reset, and power led, which will help. Here it is: http://www.computing.net/answers/hardware/emachine-power-sitch-wiring/56545.html
This site will explain about the 24 pin connector from the power supply
http://www.tomshardware.com/forum/53750-7-installation-manual-rs480m-w3400-emachine-motherboard
If you google "motherboard wiring" you will find sites that have illustrations of the motherboard, and explain which connectors go to which sockets, and how to identify them.
With a little patience and determination, you should be able to hook everything up from the various blogs on the net. Hope this helps.
Apr 17, 2010 | E-Machines eMachines Desktop PC
Need to re-attach power button cable, hard drive
The manual for your computer is available from emachines, p.168 shows the info you need (replacing the front I/O panel)
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
The good news is that you can't harm the computer by connecting the wires wrong and the bad news is they just won't work the way they are supposed too if not connected properly. The LED's must have the correct polarity to work.
In general, if you look real close (as in magnifying glass and flash light) you will see the ID for each set of pins is printed on the motherboard (pwr,rst,HDD,pwr sw,speaker) Just match what it says on the motherboard to what it says on the wires. Don't worry if you get the polarity wrong. If a light doesn't work just swap the two wires. The colored wires should be positve (+), though. The reset (rst) and power switch (pwr sw) wires don't require polarity.
These instructions are for most computers in general, YMMV.
Nov 30, 2009 | E-Machines eMachines Desktop PC
T6410 EMACHINE TRYING TO CONNECT START BUTTON
The motherboard in your computer is an MSI MS-7145, which is also called RS480M. You can download a copy of the manual here. The front panel connections are on page 2-20.
Looking at the header JFP1, pins 1 through 9 (odd numbers) are the front row, pins 2 through 10 are the back. Pin 10 is the missing pin. The power switch connects to pins 6 and 8. The power LED connects to pins 2 and 4. The HDD LED connects to pins 1 and 3. The reset button, if used, connects to pins 5 and 7.
May 13, 2009 | E-Machines eMachines Desktop PC
Hdd led off
see to the front panel section on mother board possibly on the right hand side of bottom u can see the label there to connect hdd led
Dec 28, 2008 | MSI RS480M-IL (816909008517) Motherboard
Wires unpluged
these normally go at the front of the motherboard if you are looking at it where the power supply box cables are at the back. There are litlte pins that these fit onto that will say on the motherboard Hdd led etc... in small writing.
hope this helps
Oct 31, 2008 | E-Machines eMachines Desktop PC
Emachine W3400/ front panel connections
they have to be plugged in horizontally although it is possible to plug them in vertically because the pins are evenly spaced either way. they are color coded just not like you would expect for example one plug has a green wire and a white wire the green side goes to the green pin and the white side goes to a green pin with a white cross you have to look close because there are several green pins which is what threw me off do this with all three plugs
Apr 19, 2008 | AMD eMachines Desktop System w/ 17'' CRT...
FIC AU13 Chameleon Motherboard Logo
188 people viewed this question
Top FIC Computers & Internet Experts
David
David
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
