Question about MA Audio MA1500XL Car Subwoofer
Correct box size for ma audio 10 inch sub - MA Audio MA1500XL Car Subwoofer
3 Suggested Answers
SOURCE: ma120xe sound horrible
Make sure that you have the subs wired in a 4-ohm series and not a 8-ohm load
Posted on Dec 23, 2007
etirbynnor
  • 655 Answers
SOURCE: Specs for Ported Box for 2 12" MA AUDIO HK12X2 Subs
Hello joseph_delac,
MA Audio's website has the recommended box volume and port size online here. A ported enclosure needs 3.0 CuFt of internal volume and the port should be 48 sq/in and 14.5" in length. A 4X12" rectangular port would give you the recommended 48 sq/in. Using 3/4" MDF, a box 16X18X25 has an internal volume of 3.25 CuFt allowing .25 CuFt for the sub and port displacement.
Hope this helps.
Posted on May 13, 2009
What would be the ported enclosure airspace requirement for a dynex 10" sub?
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. Box size will be 11 inches x 11 inches x 11 inches. Hope this helps
Feb 25, 2011 | Dynex 10" Single-Voice-Coil 4-Ohm...
Tip
Box size and airspace for 10 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 10 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be around 26 liters, meaning that you will end up with a box of 11 inches high, x 11 inches wide, x 11 inches deep. <br />Enjoy! <br />
on May 29, 2011 | Car Audio & Video
What is the optimal box size for the planet audio bb2215d?
If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 16 inches x 16 inches x 16 inches
May 19, 2010 | Car Audio & Video
What size enclosure is recommended for 2 10" kenwood tornado subs?
If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 11 inches x 11 inches x 11 inches
Apr 19, 2010 | Kenwood 2 10 " SUBS SUBWOOFERS 500W POWER...
I need to know the demensions for 10 inch subs
almost any 10 will use .75 cubic feet up to 1.25 cu ft. thats about the size of a milk crate give or take. a sealed box will give you the cleanest tightest bass. A ported box will be louder but also larger at the cost of decreased power handling ability and sound quality. If your subs are designed for small enclosures use a sealed box around .75 to 1.00 cu ft.
Jan 30, 2010 | Koiiler XM-6715 Car Subwoofer
Hello joseph_delac,
Hope this helps.
May 13, 2009 | MA Audio HK12X2 Car Subwoofer
I need to find a good sub box for my 10 inch JL w6
Hello ama1228a,
You did not say what type of vehicle the box is to be mounted into. Many times, where the box goes dictates the shape and size you have to work with.
That JL W6 will work OK in a sealed box with as little as .625 CuFt of volume and a ported box with .75 CuFt, so you have lots of choices.
Here's a link to the PartsExpress box page. These are Goldwood boxes, so don't let the prices scare you away. They really are built well, and one of them will make your JL sound good.
http://www.parts-express.com/wizards/searchResults.cfm?FTR=&search_type=main&WebPage_ID=3&searchFilter=goldwood+boxes
Hope this helps.
Apr 02, 2009 | Jl Audio 10W6v2 Car Subwoofer
Ma audio hk 4000d
you have definately blown a output channel, or power supply. Send it in for warranty.
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
12W3V2-D4 ENCLOSURE
12W3v2-D4 sealed or ported enclosure use.
Sealed 1.25 ft3 23" x 14" x 10"
Ported 1.75 ft3 29" x 14" x 12.25" - Slot port size 1.375" x 12.5" x 23.75"
12W3v2-D4
Fc: 47.4 Hz F3: 41.3 Hz Qtc: 0.83 Recommended Port Tuning: 30.3 Hz
Maximum wattage: 600 watts per driver.
I hope this helps you, more info can be found at: http://mobile.jlaudio.com/pdfs/12W3v2_MAN.pdf
Jun 24, 2008 | Jl Audio 12W3 Car Subwoofer
Ma120xe sound horrible
Dec 14, 2007 | MA Audio MA 1200XL Car Subwoofer
MA Audio MA1500XL Car Subwoofer Logo
Top MA Audio Car Audio & Video Experts
Mark Skinner
jamie suver
Level 1 Expert
Robert Rankin
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
