how old is it? that noise is coming from the cd drive it is probably on its way out or is full of dust and dirt, you can clean it yourself but you probably wont be able to fix as they are extremely difficult to work with and you cant just by a new drive as they have special code that link them to the xbox its in if you remove it and put a new one in you will only be able to play dvd as it will not recognise games because the code wont be there
This could be a magnet issue, on top of the dvd drive motor there is a magnet that can become detatched, the dvd drive needs to be stripped down and the magnet glued back on, this is usually the case if its a grinding noise.
Hope this helps.
Yes this is normally because the DVd drive is taking too much heat, to fix it you need to stop the heat build up you can do this by sending it in or using a good Xbox 360 Repair guide
When the xbox 360 is plugged into a power outlet, power is at the "entrance" of the console is stopped or held. When there is an internal hardware issue, some of the power leaks into the console, turning it on. If you want to fix the issue, I would suggest calling microsoft for repair. (only if you are under warranty) Otherwise, find a better repair company.
The grinding noise is natural, it is the console's way of turning on.
