Question about Honda Vehicle Parts & Accessories
1999 civic key fob reprogramming
2 button valeo ir
KEYLESS ENTRY PROGRAMMING
Have all remotes for the vehicle on hand.
Make sure all the doors and rear hatch/trunk are closed during programming.
Only need to use 1 remote to get into program mode but all remotes must be programmed during the same session.
Each step must be completed within 5 seconds.
1. Sit in the car with all doors/trunk tightly closed
2. Turn the key to the ON position, marked by "II" on the ignition bezel so the dash lights come on, then within 5 seconds press the "Lock" button on the remote for 1 second or so and release the button.
3. Turn the key to the OFF position, marked by "I" on the ignition bezel - dash lights go off.
4. Repeat steps 2 & 3 three more times (A total of 4 times) - each step must be done within 5 seconds of the previous step.
5. Upon the 4th turning of the key to "ON", press the lock button on one remote, the locks will make a cycling sound (clunk), locks will NOT lock or unlock at this point, they will just make a noise. The system is now in programming mode. Do not turn key off.
6. Within 5 seconds of entering programming mode and within 5 seconds of each other, press the lock button ON EACH remote you are programming, for a second or so and release. This step needs to be completed within 10 seconds. Each time a remote button is pushed, the locks should cycle. Up to 3 remotes can be programmed.
7. Turn ignition completely off and remove the key. Step out of car and close door. The remotes should be programmed and should work. If you have a trunk/hatch release, the button for this feature needs to be held for a few seconds before the trunk/hatch will "pop".
Posted on Feb 08, 2009
2009 honda civic hybrid
May be keyfob needs reprogramming to make it work line normal.
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.
If the remote s faulty then key fob will not get programmed.
Insert the key in ignition. Turn the key to on position, and cycle the key three times off-on-off-on-off-on. Then with the key fob remote select your remote and then try to operate the vehicle with remote.
These are just the basic procedure, but sometimes it will not help.
On that case dealer is the only option.
There is a related troubleshooting link mentioned below for remote key fob reprogramming. Click the link below to go through its details and procedure: -------
ANTITHEFT WILL NOT LET CAR TO START?
http://alltypesofpartsreplacing.blogspot.com/2012/12/keyfob-programming-reprogramming-car.html
These will help.
Thanks.
Dec 10, 2012 | 2009 Honda Civic
Wireless enteryhow do you reset the reciever and reprogram the remotes
I suggest check the right procedure in your owners manual, and keep in mind this...
Here is a quick HowTo on programming your own keyless entry:
1) Turn ignition to OFF.
2) Locate the Data Link Connector, its a black 16 pin connecter that is under the driver's side dash, right where your right knee would be. You have to look up into the dash from below to see it.
3) Ground pin 1 of the Data Link Connector by taking a wire or paper clip and running it from pin 1 to pin 4. Pin 4 is ground so you can just short pin 1 to 4 and it will be grounded. Grounding pin 1 tells the system you are ready to reprogram it.
4) Close all of your doors.
5) Turn the key to ACC then back off. The power door locks will lock/unlock. This is the signal that the system is ready for reprogramming.
6) Push a button on your key fob, doesn't matter which button.
7) If you have 2 key fobs, then press a button on the 2nd fob within 1 minute of pressing a button on the 1st fob. Both must be programmed at the same time. If you only have 1 fob then press a button 2 more times to signal that you only have one.
8) The doors will lock/unlock to signal the codes were received.
9) Remove the jumper wire from the data connector. This is the same process that I use/used to reprogram my stock key fob. It's word for word on how to do this on your Avenger/Sebring. Since it's not in my own words I used quotes and it was written (or copied) by several folks with either 2G Eclipses/Talons or Avenger/Sebrings,
Hope helps.
Feb 27, 2011 | 2002 Dodge Durango
I need my gm key fob programmed to my 99 alero
THE DEALERSHIP HAS TO REPROGRAM KEY FOB.YOU NEED A SPECIAL SCANNER TO REPROGRAM NEW KEYS OR NEW IGNITION SWITCH.
Mar 10, 2010 | 1999 Oldsmobile Alero
I have a 1997 honda civic valeo remote locking fob and both rubber buttons are missing can you help
sure call the dealer or salvage yard
best bet salvage u just need buton ruber
time for some disassembly
Jan 15, 2010 | 1997 Honda Civic
Porsche boxster 1999 model keyfob not working. have replaced battery but still inoperable.what do i have to do to reprogram
i presume little led in fob flashes when button pressed. Key needs to be initialised. Put key in door lock or ignition barrel and press unlock button watching led on dash, this should flash. remove key from lock, remote should now work
Aug 29, 2009 | 1999 Porsche Boxster
Neither of 2 standard fobs works
try
sit in the car
point remote at the mirror ir sensor (1995)
press remote twice and within 30 second
insert key and turn to drive position
if you don't havemirror mounted ir sensors
point at your sensor location
Jul 11, 2009 | 1994 Mercedes-Benz C-Class
Reprogram key fob
10) your done
May 15, 2009 | 2000 Dodge Durango
Program key fob 1999 sillouette
Take it to A GM Dealer they Hook into the ALDL and Reprogram it By Way of a Scanner
Feb 05, 2009 | 1999 Oldsmobile Silhouette
IR control module for remote entry is inop
I have had problems like this and it was caused by a light film of dirt on the battery contacts in the key fob. I took a 3M kitchen scrub pad and lightly rubbed the contacts on the circuirt board of the fob and put the battery back in and it worked. I thought the problem might be caused by the warm enviroment of a pants pocket where the fob is usually kept when not in use.
Dec 15, 2008 | 2005 Dodge Durango
Program a remote key for 03 A6
I have an A4 and did this to re-program my key:
1. used the key to start the car...then turned it off
2. put the key in the driver door (door closed)
3. pressed the lock button on the key fob once
4. turned the key to lock the door.
This is basically the steps in the owners manual, but the car must be started with the key first, and the key must be in the door lock before pressing the lock button.
Dec 10, 2008 | 2003 Audi A6
Vehicle Parts & Accessories Logo
1,489 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
David Alger
Level 1 Expert
Colin Stickland
Colin Stickland
David Burbee
David Burbee
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
