Question about Dayton 3VE53 Oil Filled Liquid Fuel Utility Heater
I have a 3VE53 heater and was wondering about how much eletricity does it use if I keep it at 65-70 degrees for 9 hrs. a day?
Our last eletric bill was around 3 times as much and I am just trying to find out why.
  • 5,763 Answers
Okay, for example a 100 watt bulb left on for 10hrs uses 100x10 =1000. so 1000= 1kwh. so look at the watt rating on the fan motor and times that by 9hrsand then do the math, then look at your bill and see what you pay per kwh (kilowatt per hour) and times that with your answer, for example lets say the heater blower is 10watts, take 10 X 9 = 90, then 90 divided into 1000=.09 so it .09 of a kilo watt almost a tenth of a kilo watt. so if you pay 3.25 a kwh then you would say .06X3.25=.195 less than one cent, hope this helps
Posted on Feb 17, 2012
Testimonial: "very helpfull thank you"
How do i stopped my eletric tipping plug on fridgefreezer got wet when moving now keeps tripping eletric
Remove plug, check wiring is dry, strip back cable a little to be sure no water trapped, and replace with a new plug.
Nov 08, 2014 | AMCC Computers & Internet
White knight
you have to check the heater and the motor first as one off these may by need to be changed or repaired
Jan 05, 2014 | Washing Machines
Codes for a general eletric tv
Codes for a general eletric tv are
0047 ,0747 ,1147 ,1347 ,0051 ,0451 ,
0093 ,0178 ,0021 ,0055 ,0282 ,0135 ,
0027 ,0279
Thanx
Jul 18, 2010 | One For All URC4220 Remote Control
Where is the mechanical fuel pump, im not getting any fuel to the carb and have already hit the fuel pump relay under the heater core inside the cab
if the truck has a fuel pump relay, then it's not a mechanical pump it's eletrical. If you're SURE it has a relay, then the ELETRICAL pump is in the fuel tank. If it's mechanical, it will be on the motor, near the belts. Not sure which side on a ford.
Jul 17, 2010 | 1986 Ford F 250
Eletric PTO is not working
The PTO draws a pretty good current, so a weak or loose contact in the switch, or in the connections on the back of the switch, could cause this overheating. But it could also happen if the PTO clutch itself or the wiring to it has a short. If the mower's still under warranty, get the dealer to diagnose and fix it. If not, then I'd measure the resistance of the PTO clutch - should be about 2 ohms - and make sure the wiring to it isn't shorted. If all that is OK, then just replace the PTO switch and any melted connectors and wiring. Good luck!
Jul 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Fridge walls very warm around freezer door
that is ok these fridges have the condencer lines within the walls of the fridge or some have heaters this is for condensate not to form on the fridge it keeps the fridge dry on the outside
Sep 26, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Bosch eletric hob schott ceran one side flashing and not working
Will need a control panel for the faulty side.Easy repair very expensive part
Jun 11, 2009 | Audiovox Bosch 718 World Cellular Phone
Eletric blanket timer
If walgreen can't order the part I would try places like appliance stores,like D&LAppl.
Mar 13, 2009 | Heating & Cooling
Ep82 starlet eletric window runs intermitantily
woow i think that u should check about the eletric system.
if it'not clear. buy secondhand it's better.^^
bye john
Aug 02, 2008 | 1984 Toyota Starlet
Dayton 3VE53 Oil Filled Liquid Fuel Utility Heater Logo
122 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
