Question about NetGear DG834G Router
Does netgear dg834n come with an out of the box password.Bought second hand one but did not get password
Does netgear have common out of box setup password
  • NetGear Master
  • 32,281 Answers
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Feb 17, 2012
Change username
1. Open your web browser and type in your router's IP address. The default IP address for Netgear routers is http://192.168.2.1.
2. Enter your username and password once prompted by your web browser. The default username and password for Netgear routers are admin and 1234 respectively.
3. Select "Set Password" from the left hand navigation menu on the router's manager menu.
4. Type in the old password, which should be 1234 if it is set to default and then type your new password twice.
5. Click "Apply" and the new password will take effect immediately.
Nov 05, 2013 | NetGear FR114P Router
After firmware upgrade the no wireless signal and the router is not recognized by my laptop even if I connect it thru lan cable
You may have taken a bad update try factory default if you get in try to download from verified site new firmware
reset to factory default
press and hold reset button during the whole process and only release when completed.
1)press reset button 30 seconds
2)remove power cable 30 sec
3)plug in power cable 30 sec and then release.
You should no be set for 192.168.1.1
username admin
password is password
Apr 01, 2012 | NetGear DG834N Router (DG834N-100AUS)
How to lock my router
in your browser type in 192.168.1.1 or 192.168.0.1 ( usually the first one)
when prompted for username type admin and password admin
Select "Wireless Settings" from Setup Menu in left hand navigation bar
Under "wireless network" type in your desired network name in SSID box
Under "security options" select WPA-PSK [TKIP] + WPA2-PSK [AES]
Enter your desired password into "passphrase" box
Click Apply
http://kb.netgear.com/app/answers/detail/a_id/112
May 04, 2011 | NetGear WGR614 Wireless Router
I have a nieghbor who has somehow found out my password. How can I change my password so he can't use it anymore.
you can change your wireless encryption password by going to internet explorer
http://192.168.0.1 or http://192.168.1.1
the default login/pass
  • Username = admin
  • Password = password
    • For older devices, password = 1234
if this does not work you will need to reset your router by holding the reset button for 30 seconds or more when you power it on.
  1. Use an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin;password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
    For Steps 4-9, refer to Figure A below.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  5. Under Wireless Network, enter your desired network name in the Name (SSID) box.
  6. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  7. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into thePassphrase box.
    • WRITE DOWN or KEEP NOTE of your network name, security option and passphrase - you will require them to connect wireless computers and devices to your network.
  8. Click Apply to save the settings.
Mar 29, 2011 | NetGear MR814 Wireless Router
I am trying to connect another computer to my wireless network but i do not know my netgear code, where do i find this?
Netgear code? Can you be more specific?
Are you referring to the password required to connect to your wireless network called "Netgear"? I assume you're being asked for a password on the 2nd computer when trying to connect to the wireless network called "Netgear".
  1. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  2. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  3. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  4. Under Wireless Network, enter your desired network name in the Name (SSID) box. This is currently set to "Netgear" most likely.
  5. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  6. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
  7. Click Apply to save the settings.
Once you've set this password, you can use it to connect to "Netgear" on your second computer.
Jul 25, 2010 | NetGear WGR614 Wireless Router
How can i access my router configuration to open port 3074?
Open any web browser, such as Internet Explorer or Mozilla Firefox. In the address bar, enter "192.168.0.1" and press the enter key. This will bring up the login prompt for most Netgear wireless routers. If that doesn't work, try "www.routerlogin.net", "192.168.0.5", or "10.1.10.1" until the login window appears.
Should be able to acces it from the web interface.
Dec 18, 2009 | NetGear DG834N Router (DG834N-100AUS)
How to set up home office network with Netgear
Wow ... I teach a whole college semester on this. This forum can't possibly provide enough complete information on design, setup, maintenance, security, etc.
View this netgear link:
http://www.netgear.com/Products/RoutersandGateways/RangeMaxWirelessNRoutersandGateways/DG834N.aspx
It includes diagrams...
Go to a book store and purchase a paperback book on home network setup.
Sep 30, 2009 | NetGear RangeMax WPN824 Router
Connection problem. shows limited connectivity and disconnects
limited connectivity means you didn't get an IP address. Is the router set to give addresses via DHCP, or is another PC doing that? Most common cause of this problem is wrong authentication (normally "open") or encryption type (WEP, WPA or WPA2). Pklease note that encryption keys can be set as HEX or ASCII, if they are HEX it will be only numbers 0 to 9 and letters A-F. ASCII can be anything.
Jun 01, 2009 | NetGear DG834N Router (DG834N-100AUS)
Ma question
i like to add a password to my ( netgear DG834N )
THANK YOU.
my E_mail is
h6b6an@hotmail.com
Oct 11, 2008 | NetGear DG834G Router
Internet faliure
This is a problem with your modem, you can try to reset the modem then reconfigure it back using the setup CD but the best way to solve this and check the modem is to call Netgear tech support and let one of their tech walk you through with that process , this is the number 1-888-638-4327 ...
Hope that helps..........
Sep 15, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
NetGear DG834G Router Logo
47 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
