Question about Hansgrohe Plumbing
Hansgrohe concealed thermostatic mixer ref no 1537418
Water is not getting hot enough,is there a thermostatic part in the unit that can be replaced easily?the other showers in the house that do not have this control are fine,the unit is approx 8yrs old and was working fine up until 1 wk ago
  • 50 Answers
Check for sediment in your valve body... sometimes sediment can build up particularly in hot water pipes and that can cause the pressure balancing function of the valve to limit total hot water and therefore you cant get it hot enough... here is a link to what I think is the proper valve and the instructions for installing it... you'll want to follow the instructions for flushing and pressure testing... if you have good pressure at the thermo body then you might try adjusting the hot limit stop also covered in the document linked below...
Hope theat helps...
Posted on Jan 05, 2009
Hansgrohe ecostat not at full water flow
The most likely cause for a decrease in flow on the Ecostat mixer is debris in the filter screens. Try removing the thermostatic cartridge and cleaning the filter screens on the the cartridge. Doing so will most likely resolve the low flow issue. If you need instructions feel free to contact me at Hansgrohe Tech. 1-800-334-0455. Press 2 for Tech and ask for David Scarborough. I'll be happy to provide instructions for the Ecostat mixer.
Feb 04, 2013 | Plumbing
Hansgrohe shower not hot enough
The first thing to do is identify the unit so I can give accurate instructions. Hansgrohe makes many valves and the temperature adjustment between them is different. Feel free to call me at Hansgrohe at 1-800-334-0455. Press 2 for Tech and ask for David Scarborough. I'd be happy to help identify the unit and get you the instructions for the temperture adjustment.
Oct 05, 2012 | Hansgrohe Home
How to clean Axor Terrano Showerpipe - hot water part of mixer seems blocked
There are filter screens on the thermostatic cartridge inside this unit. You will need to remove the thermostatic cartridge and clean the filter screens. If cleaning the thermostat cartridge does not resolve the issue you may need to replace the cartridge. If you need further assistance feel free to contact me at Hansgrohe Technical services. 1-800-334-0455. prees 2 for tech and ask for David Scarborough.
Aug 30, 2012 | Home
Hansgrohe shower thermostat: water is getting only Lukewarm. Hot water ok in sink and throughout rest of house.
The first thing to try is cleaning the filter screens on the thermostatic cartridge. Hansgrohe thermostat valves have filter screens to protect the element from debris or water deposits. If they begin to get clogged the valve will have a hard time regulating temperature.
Jul 28, 2012 | Home
I have a hudson reed Twin Concealed Thermostatic Shower Valve. It was working fine for a couple of years. My brother used the shower and adjusted the water temperature valve but since then the water has...
Sounds to me the diffusor is stuck or broken in the position to allow only hot water through it.Looks to me tou have a mixer valve on it. Might have to replace it.
May 31, 2011 | Hudson Reed Home
How do I remove cartridge part # 9273000 from my Hansgrohe kitchen faucet?
Please contact us at the below number or email me directly and I will get you a copy of the instructions that you need.
Christopher Scott
Technical Support Specialist
Hansgrohe Inc.
1492 Bluegrass Lakes Parkway
Alpharetta,Ga 30004
Feb 19, 2011 | Hansgrohe 06649860 Solaris Single Hole...
Hansgrohe Kitchen Faucet low water pressure
Try removing the aerator and handspray to clean out any debris that may have accumulated. After 8 years there could be quite a buildup if it hasn't been regularly cleaned.
May 24, 2010 | Plumbing
My thermostatic concealed shower valve only gives either boiling hot water or cold water, there is no inbetween temperature? the cold is fed from mains and the hot from a combi boiler. the plumber has said...
If the hot and cold are fitted the wrong way round then the thermostat on the shower unit cannot operate properly!
Most thermostatic mixer showers have a 'bi-metallic' thermostat, if you supply the hot to the cold and vice versa IT WILL NOT WORK.
It is like wearing the left shoe on the right foot and the right on the left! It doesn't work.
Re-install the hot and cold to the correct supply, and this will sort it.
I hope this helps.
Jul 07, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Hansgrohe shower
it's possible sometimes you can get brand new junk. one question is the thermo coupler in the right postion? i would check to make sure that it is indeed picking up the temp like it should.
Sep 02, 2008 | Home
Plumbing Logo
902 people viewed this question
Top Hansgrohe Plumbing Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Hansgrohe Plumbing Expert? Answer questions, earn points and help others
