Where is the dip switch on polaroid tlx-04244b
SOURCE: Polaroid TLX-04244B Remote wont work
5 Digit code is 15231
3 Digit code is 494
Hope that helps, took me about 4 hours to get that figured out!
Posted on Dec 05, 2008
  • 4 Answers
SOURCE: 42' polaroid tv wont show screen still
well if the light stays blue , that means its still on ...what you may need to do is go to your menue and select the setup selection and then go to tuning band.....i belive it will be on page 32 of you manual, under customising the setup settings....in order for the tv to start working it needs to be able to scan for channels.....if you are useing a cable company like comcast or direct tv...depending on how you pluged it into the tv ,(like using the input 1 or 2 , s-vidio, cable , ectra,)...you need to push the input button thats on the lower right side of your remote and select the propper input area as to how you hooked up your cable box
Posted on Dec 14, 2008
onyeobike
  • 70 Answers
SOURCE: screw size needed
I strongly advise and recommend you get the details and if possible the screws from the shop you got it from.
This advise is enssential so as to get the best from the certified sales representative
Posted on May 25, 2009
SOURCE: i have a polaroid tlx-04244b and just recently my
I dont have a solution but I am serching for the same answer to your question. As I had purchased the same TV from wallmart and they did not give me the warranty, because as i was told by a manager that they do not input the warranty option for BLACK FRIDAY PRODUCTS, which they do not willing offer as I have found out since with other products that have died. This TV had just suddenly turned off one day not even a year and a half after I purchased it and it flickers and stays black screen withg only the RED LED light on. PLEASE ANY HELP ON HOW TO GET THIS FIXXED WOULD BE GREATLY APPRETIATED!!!
Kevin
248-342-5213 text me if you know anyone that can give me a solution to this problem or point me in the right direction to get it fixxed as it cost 700$ and was a second tv...the SHARP I use in my living room which gets used 3 times as much is working and 2 years older then the poloroid. I RESIDE IN THE PHOENIX AREA IF YOU KNOW RESONABLLY PRICED TV REPAIR MEN. THANKS A LOT!!!
Posted on Jun 09, 2010
SOURCE: I have no power to the the whole tv set.
Right where you plug in the power cord on the back of the TV (without disassembling the TV) there is a hidden fuse in the black plastic connector...about 1/4 inch to the left of the plug... Very easy to miss, and opened using a small blade screwdriver. There is a symbol on the plastic that represents a fuse... I think it is a 250V 4A fuse, but check the markings to be sure.
If that fuse is intact, you may want to disassemble the TV and check the fuse that is on the actual power supply circuit board. It will be adjacent to the incoming power wires... It may be covered with insulated heat shrink wrap so you may not be able to tell if it is good just by looking at it...
The other poster's suggestion to check for bad/swollen capacitors is also sound advice but remember that not all capacitors that have failed are so easy to spot, and may look good even though they are bad.
Posted on Jul 13, 2010
Polaroid TLX 04244B washed out color
get the onscreen menu up , scroll around till you find contrast and adjust there
there will also be brightness adjustments as well
Aug 22, 2016 | Polaroid Televison & Video
How to disassemble polaroid TLX 04244B TV
If you wish to get some details; check the site linked here. Pull up older posts. Disassemble procedure to many popular devices are given with illustrations
May 16, 2016 | Polaroid Televison & Video
My Polaroid TLX-04244B loses color after half hour or so. Please help.
this is caused by heat; mount a small 12 volt computer powersupply fan over the back vents to draw the heat out
Feb 17, 2013 | Televison & Video
I have a poaroid TLX-04244B flat screen tv but no remote or manual how do i get these?
check out polaroid tv parts its a website. just google polaroid tv parts and it should be simple to find a remote. also a universal remote would work well that can be purchased at any local best buy, etc...
Aug 09, 2011 | Polaroid Televison & Video
Polaroid tv model#TLX-04244B....No pic,no sound,blue power light flashes....is there an inexpensive fix that can be done by us?
Part for this TV are not cheap and not easy to get as you can see here:
http://www.shopjimmy.com/catalogsearch/result/?q=polaroid+TLX-04244B
You will need to do some in-depth troubleshooting to find which board/s are bad.
Power supply module will be the first place to start.
So please read my guide first.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jul 16, 2011 | Polaroid Televison & Video
Last night I turned my Polaroid TLX 04244B off, and had zero problems. This afternoon, I have a 6" pattern of horizontal lines across the right hemisphere of the screen. They come and go, darker...
You are probably seeing hum bars which may be due to an AC ground loop that is going through the shields of one or more of the cables inteconnecting the TV with one or more of the other video components. You should do the following to try to resolve it...
1. reseat all the interconnecting cables between TV and other units
2. have all AC power supplied by one power bar with a ground plug
Mar 17, 2011 | Polaroid 4241-TLXB 42 in. LCD Television
3 Digit code is 494
Nov 28, 2008 | Polaroid FLM-4201 42 in. LCD Television
Can't get all cable channels
Chech with you cable company to see if they switched to the higher chanels. I do not know if you are connected directly to the antenna or a cable box.
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
