Question about Panasonic PT-47WX53 47" Rear Projection HDTV
TV turns on for about 10-15 min then turns off
TV has been working fine. Purchased it new in 2003. Just yesterday it started its problem. The TV will turn on for anywhere from 10 to 20 mins then shut off. The power light on the front will blink. If we unplug it and plug it back in it will turn on again for another 10 or so mins.
  • Tim Warner Aug 23, 2006
    Hello, We just discovered a new twist to our delema. We have a Sony DVD/VCR Receiver Home Theater System hooked up to the TV. We played a DVD movie and it played all the way through without the TV shutting off. Went back to watch the TV and it shut off after 10 mins again. What is up with it. Thanks
Sounds like a tuner section problem. When you are playing a DVD. You are only using the audio video circuit of the TV. Something like a monitor. But when you go back to TV mode... You are now in the tv tuner circuit. And your problem lays there. I had a mouse **** on my tuner section of my tv and it caused the same problem. Yes mice do ****...
Posted on Jun 28, 2007
I purchased yesterday a 42"
I came across this very same problem a year or so ago regarding a Plasma TV and connection via scart. It turned out to be a problem with the scart lead. Replacing the lead with an all pins connected type fixed the problem. It was caused by the TV not being given the +ve voltage on pin8 and the TV thought it was not a proper signal and shut down.
Hope that helps.
Feb 27, 2011 | Televison & Video
Hi I have Prima lv 3228p tv and there is no volume it was working fine yesterday andtoday no volume
prima lv-3228p lcd tv-after 15 mins of play the screen goes funny and there is still volume but the remote will not function. you cannot even shut the unit off, only by disconnecting the power supply. If you wait 15 -20 mins and plug the unit back in it will work for approx 15 mins again- then it will start acting up again?/
Jan 13, 2011 | Televison & Video
My vacuum worked fine yesterday and now doesn't start
To my knowledge, the on/off switch is the only area to turn your vacuum on or off. There might be a problem with your cord, or with the switch itself. I suggest checking for clogs and anything that may cause a problem.
I also suggest taking it to a local vacuum shop to have it looked and as you may need some new parts (cord/switch)
Apr 13, 2010 | Eureka Whirlwind 4388 Bagless Upright...
I have a 61" samsung dlp. It worked fine
Start with replacing the lamp. Then move on to the Ballast. Then the color wheel. Then the Power Supply. One of those parts should fix it. If not call back.
Jul 15, 2009 | Samsung DLP HL-P5663W 56" TV
Tv wont turn on
Same Problem. TV was purchased from Sams Club about 2 or 3 years ago. workede great unti llast week. We were watching tv and it just shut off. The power button on the tv started to get soft were you had to push hard or just use the remote. My guess its something with the wsitch.
Jan 28, 2009 | Sylvania 6427TE 27" TV
Chevy venture
Solution to your problem ... 1- I purchased from 1aauto.com a pair of Circuit Boards for my Chevy Venture 2003 for 85.00 $ ..free shipping 2 - I Installed them both , all lights now were not working at all. So I checked them and they were all burned ...So I purchased new ones ....Everything was working fine now but now my signal lights were not working left and right .....Checked the fuse box next to the passenger side door .... It was burned . Changed the fuse / Signals are working fine now ....All is good I just did this yesterday evening August 12, 2008 Conclusion ..Change everything going forward so you do not need to run around like I did from one store to another!
  1. Circuit Board : New
  2. Bulbs : New
  3. Fuses : New
Thank you
Jun 26, 2008 | 2003 Chevrolet Venture Passanger
HD TV flat screen
there is a timer that you can set to turn the tv off automatically. The timer settings is between 30 min. and 3 hours, maybe she has hit the timer button by mistake.
May 31, 2008 | Televison & Video
Plugged in, worked, turn on later, did not work
First thing i would do would be to check convergance amp ics
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Toshiba 55H70 55" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
122 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
