Question about Canon DR-9080C Path-Through Scanner
Dissassemble cannon dr-9080c scanner and clean glass plate
Want to remove top glass and clean inside of it
mohanchennai
  • 490 Answers
SOURCE: iDoc scanner Canon DR-9080C has a P00 error when not paper jam found?
There are sensors in the paper path. Just blow air to ensure that there is no shreds of paper is blocking the sensor.
S. Mohan, Chennai
Posted on Jun 30, 2008
SOURCE: CanoScan 5000F foggy glass
No problem.
1st step. Remove the lid. It just pulls out at the hinge end by lifting straight up, horizontal if you like. Where the two lid posts insert in the scanner body you will find 2 screws, undo them, no need to remove at this point, too hard. Rememeber you left them in there though.
2nd step. Around the 4 buttons at the control end is a striped trim panel that is the full width of the scanner. Locate the join between this trim and the light grey underside of the scanner body and just left and right of the COPY & EMAIL buttons, Using your fingernails lift with some gentle force. This edge will pop up. Note, the trim panel has 3 location tabs that insert under the grey border edge around the glass. So pop the front edge first and pull towards yourself.
3rd step. Once this trim is removed you will note 4 little grey plugs equally spaced under this area. remove the plugs and you will find 4 screws. Unscrew them, no need to remove, remember point above.
4th step. Time for CAUTION. You will be able to lift the upper part of the scanner up in which the glass is mounted. ***There is a lead with little play connected to the 4 buttons PCB which is attached to the upper panel. To ensure you don't damage it accidently when cleaning the glass you can remove the 2 screws attaching it to the upper panel.
5th step. See if you can wipe it, with a VERY SOFT LINT FREE cloth, without putting you finger on it somewhere......................
6th step. reassembly is the same in reverse
Posted on Sep 16, 2008
SOURCE: Fog build up on underside of glass plate.
I made contact with cannon and received this reply. I was satisfied with the answer but the question still remained on how to remove the glass should i wish to do so. Also after there answer... would there then be a problem if i did clean the reverse side. Their answer was initialy this...
The foggy haze on the glass is actually an anti-glare treatment that has
been intentionally applied to the underside of the scanner glass.  This
treatment lessens the glare from the lamp under the glass and provides
better image quality.  This haze may not appear uniform because of the
shape of the scanner base and the components under the glass. However,
the anti-glare treatment has been uniformly applied and the haze is as
expected.  The treatment should not affect the scan quality or output of
the 8600F.
Posted on Jan 14, 2009
SOURCE: Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Posted on Jan 31, 2009
mohanchennai
  • 490 Answers
SOURCE: Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Posted on Jul 10, 2009
Canon dr 9080c
Clean the Upper Reading Unit Glass with a soft cloth and isopropyl alcohol.
You may need to clean the shading plates by opening the top cover all the way and holding down the green start key until the shading plates extend.
Clean these with a soft cloth and isopropyl alcohol also.
Do not bend or tear these.
The clear stop key will retract the chading plates.
Apr 25, 2013 | Office Equipment & Supplies
When I scan a document in the canon 9080c scanner - the document when printed will print with a black line through the middle of the page or on the left side of the document. I have changed the rollers and...
Try scanning a few documents in full size mode (scannerrs maximum), If you observe a line in the same location in all images, you can conclude that there is either a scratch in the glass (due to stapler pins) or dirt stuck firmly. Try cleaning with Isopropyl alcohol. For absolute emergency, you can wet a cotton bud in after shave and clean the right spot, take care not to touch any other part other than the glass. If glass is scratched, you need to replace it.
S. Mohan, Chennai, India
Sep 14, 2011 | Canon DR-9080C Path-Through Scanner
We have a Canon DR-9080C scanner. When scanning in Duplex on pages with data on both sides, the back side of each page is coming out unreadably faint. The header and any overall large blocks of black on...
The Canon DR 9080C is a 'contact' scanner. There is no optical lens, instead it uses a technology called "Contact Image Sensor' or CIS. The page to be scanned must be close to the glass for a proper image. This is achieved by a full-length rubber roller just above/below the scanning module. The roller is spring loaded and in case it gets stuck, there wont be enough pressure on the document to keep it close to the glass. ensure these rollers are moving smoothly and if required clean them. The rollers are on the opposite of the Scanning module.
Jul 29, 2011 | Canon DR-9080C Path-Through Scanner
I am scanning few document on canon DR 9080c and i observer there
This must be a vertical line and appearing at the same location on all drawings! Please clean the glass thoroughly. It must be dust particle sitting on the glass.
S. Mohan. Chennao, India
Jul 14, 2009 | Canon DR-9080C Path-Through Scanner
HELP BIG JOB DUE TOMORROW! I have a DR 9080c and it just started putting two lines on the scanned pages. I have cleaned the rollers, the glass, run cleaning pages through even used compressed air to blow...
Vertical lines are from dust on the Glass. Use Isopropyl alcohol, no solvents pls. Try scanning in diff contrast levels and if the thichness varies, it is confirmed dust on glass, whereas any fault in the reading unit will be constant and also have sharp edges.
Jul 01, 2009 | Canon DR-9080C Path-Through Scanner
Faded images canon Dr 7580
Clean the glass thoroughly. Try Automatic settings and try various contrast levels in mamual mode.
S. Mohan
May 03, 2009 | Canon DR-9080C Path-Through Scanner
Canon DR-9080c Ghosting Problem
Though I've never seen this on any scanner, I can imagine it being a reading glass out of place. This could cause a weaker reflected image overlaying the direct one. Look at the top & bottom glass strips in the transport area. They should look level & unbroken.
Apr 07, 2009 | Canon DR-9080C Path-Through Scanner
Need CapturePerfect 3 driver for Canon Scanner DR 9080C
I have the same model Canon DR-9080C scanner which I recently acquired and I'm trying to figure out how used it is. I see many referrign to a counter. I see the big LCD on top front, but how do you know how many total pages have been scanned through it? I read somewhere there is a mechanical scanner. Is this true?
Jun 28, 2008 | Canon DR-9080C Path-Through Scanner
Apr 14, 2008 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
178 people viewed this question
old marine
old marine
