Question about Samsung CLP 300 Laser Printer
Home dev. error
Home dev.error is the message i get when I try to print. it worked fine for two days after I got it and then for no reason at all it comes up with the error message! there is no troubleshooting help for this problem. please help i urgently need to use it.
  • 446 Answers
Reinstall the affected dev assy, or try to removed and put back again
Posted on Oct 31, 2008
My error is dev home error
o to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
Dec 10, 2010 | Samsung CLP 300 Laser Printer
Will not print
change cartridge chips or all.
Jun 01, 2010 | Samsung CLP 300 Laser Printer
Samsung clx-3160 fn not printing flases DEVE HOME SENSOR ERROR
if the printer is flashing developer home then the developer unit is not situated correctly or the contacts are dirty causing the printer to not recognize the dev unit clean the contacts with denatured alcohol on the dev unit and where it makes contact within the printer and power back up.
failing that the dev unit may have expired requiring a new one to be installed.
if this answers your query and fixed the issue please rate me accordingly.
thanks
Sep 14, 2009 | Samsung CLX 3160fn All-In-One Printer
Deve home sensor error
You could try replacing the Image Unit (but these are quite expensive). This error actually refers to an optical sensor located in the gearbox (RHS of machine). The sensor controls the drive to the individual dev units, hence the "dev home error" if it malfunctions.
Probably a job for an engineer.....
Jun 19, 2009 | Samsung CLX 3160fn All-In-One Printer
I have a clp-350n samsung colour printer. Prints B+W images fine. When a colour image is sent to the printer the printer runs and runs and runs but never prints anything. It's as if the imaging belt can't...
There is an "opto coupler" in the main drive gear unit (right ride of machine) which controls the drive to the toner/dev units. If this (or part of the drive) is faulty it will give this error.
Jun 17, 2009 | Samsung CLP-315W Laser Color Printer
Brand New printer status led RED, Smart Panel error "dev home"
Samsung CLP-315 Dev Home error
It appears that the Dev. Home error is very common for Samsung printers. It obviously has different reasons. In my case I solved it by stabilizing the deviation clutch. It was too unsteady and the dev. sensor recognized a fault.
The dev. clutch is situated under the right cover, which is the power supply side of the printer. To remove this cover you need to firstly remove the top cover, which is held by two screws on the front. Then uncover the right side by unscrewing one screw on the back, near the power supply inlet and unclip a couple clips on the top side of the cover. After removing it you have to find the deviation electrical clutch. Check if it is too unsteady. If it easily moves, you need to somehow stabilize it, in my case by a couple of leather straps under it, so that they press it up and make it steady: 5_19_2012_1_08_58_pm.jpg
After that simply check if you have stabilized it properly. If you have the green light must turn on after switching the device on.
NB! Be extremely careful when power is ON, because there is high voltage running. I'd suggest that you would stabilize the thing with non metallic item to keep safe. Good luck!
Apr 13, 2009 | Samsung CLP 315 Laser Printer
Error on inkjet "print spooler service not running"
hi, friend. You need to re install your Printer software CD because the program corrupted. thats the only way to solve that.
Apr 08, 2009 | Compaq Inkjet IJ750 Printer
Error Messages
The false Jam at MP E is a common error caused a manufacturing error/problem. You can download a solution to this problem HERE.
The K dev unit error can only be removed by replacing the dev and completing the service mode adjustments. A service manual will help you with this issue. Get one HERE.
Jun 06, 2008 | Epson Aculaser C1100 Printer
Won't print pdf files
try with print other pdf file may this particular file is corrupted
Sep 22, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Samsung CLP 300 Laser Printer Logo
1,388 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
