Question about HP Office Equipment & Supplies
4500 Envelope printing problems
The printer won't print envelopes
thumu
  • 69 Answers
SOURCE: HP PSC 750 All-in-One Won't print an envelope
Please try solutions of below links:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu03053&cc=us&lc=en&dlc=en&product=57769&dlc=en&lang=en
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu04815&cc=us&lc=en&dlc=en&product=57769&dlc=en&lang=en#N748
These are recommeneded Solutions of HP on the issue. If you still face the issue, please contact HP Technical Support on the issue.
Link for technical Support of HP:
http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&dlc=en&product=57769&lang=en
I hope that this will resolve the issue for you.
Bye...
Posted on Feb 27, 2008
SOURCE: HP 5610 Envelope Printing Problem
Had this same problem. Went to Microsoft Office site and downloaded Service Pack 3 for Word 2000 and Security update #KB934392 and the printer started printing on the correct side again.
Posted on Mar 10, 2008
SOURCE: Envelope Printing on HP 5610
Installed SR-3 from Office Word. It did the trick.
Posted on Mar 11, 2008
SOURCE: Printer Error When Printing Envelopes
I had problems printing 4 X 6, and found out that I needed to go into the printer mode, and change the tray feed from "main tray" to photo tray.  Try that one.
Posted on Apr 25, 2008
SOURCE: LEXMARK X1240 WON'T PRINT ENVELOPES
I was so pissed off that so many on the web had this same problem that I spent many hours trying to get it to work. I am sure that this is not how it is designed to work but my envelopes got printed.First I went under File, Print, Properties to Page Set-up for envelope #10. I also ********** print colour images in black and white which someone else had suggested- although it might not be necessary. I selected quick print but normal should probably work too. I then closed out these two windows. Then under tools, I selected Letters and Mailing, then envelopes and labels, typed in the addresses, went under options and changed the feed from automatic to default tray, which automatically changes the feed method to the 4th one out of 6 which wasn't what I wanted but ignore it. Check off face up. Putting the envelope into the printer was bizarre- it has to be inserted very far into the printer until only 2-3 inches of the envelope stick above the horizontal surface of the printer. It must be inserted into the middle of the paper holder, until it is just 2-3 inches sticking up, and then slide it all the way over to the right where the printer indicates the envelope should be- nice and straight against the right margin. Do not use the movable paper holders that they suggest you swing over to the right to hold your envelope- or printing won't occur for some odd reason. Press O.K. on envelopes and labels and then press print. Good luck- it worked for me.
Posted on Mar 01, 2010
Hp help
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=3986399&
Manual
There is a guide for envelopes per manual. Place envelope with printed side facing up.
Good luck
May 05, 2013 | HP Officejet 4500 Wireless All-in-One...
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
I don't know how to put an envelope in to print it out.
Please follow the steps below on how to print on an envelope:
  • The print side of the envelope is faceup.
  • The paper guides rest against the edges of the envelopes.
  • You print the envelopes with Landscape orientation. Note: If you are mailing within Japan, then the envelope can be printed in Portrait orientation with the stamp in the lower right corner or in Landscape orientation with the stamp in the lower left corner. If you are mailing internationally, then print in Landscape orientation with the stamp in the upper left corner.
  • You select the correct envelope size. Select the next biggest size if the exact envelope size is not listed, and set the left and right margins so your envelope is correctly positioned.
I hope this information has been helpful. Thanks.
Oct 22, 2011 | Lexmark Interpret S405 Wireless All-in-One...
How do I print an envelope?
Put the envelope into the fold-down tray narrow end first with the side you want to print on facing up. After you click print in the application click on the 'options' button in the print dialog box and select the envelope size, check the media types to see if envelopes is listed, pick the most appropriate setting.
Aug 21, 2011 | Brother HL-5240 Laser Printer
Canon printer MX310 works fine, but I have never used before to print envelopes. Once i set it for a particular envelope, where do I insert the blank envelope. Have tried every conceivable...
canon.gifPrinting an Envelope
For details about how to load an envelope into the printer, see the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear tray, orient the envelope so that the flap is on the left and the folded surface is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the Main tab.
4. Click the Page Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape for Orientation.
6. Click OK.
When you execute print, the information is printed on the envelope.
Jul 21, 2011 | Canon PIXMA MX310 All-In-One Printer
How do I print an envelope on my Canon MP510?
Envelopes must be fed from the Auto Sheet Feeder. Use either European DL or US Comm. Env. #10-sized envelope.
Important :
  • You need to print from the computer to print on envelopes.
  • Do not use envelopes with embossed or treated surfaces, a double flap, pressure seals, or sticker flaps.
  • Select either DL Env. or Comm. Env. #10 in the printer driver according to the envelope size you are using. If you do not, the address will be printed in the wrong direction.
1 : Retract the Paper Support.
2 : Load the envelope against the Cover Guide (the right side of the Paper Support).
Load with the front face UP and the rear flaps DOWN on the left.
A maximum of 10 envelopes can be loaded at once.
*1 Printing orientation
*2 Make sure the flaps are folded.
Important : Make sure that the Cover Guide is set upright.
3 : Pinch the Paper Guide and slide it against the left side of the envelope.
4 : Press the Paper Feed Switch so that the Auto Sheet Feeder lamp lights up.
5 : Set the Paper Thickness Lever to the right.
In the printer driver, select 'Envelope' in Media Type, and then select 'DL Env'. or 'Comm. Env. #10' in Page Size.
Jun 21, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Jun 01, 2009 | Office Equipment & Supplies
Envelope Feeder is not accepting the command
> Home > Support & Drivers > Knowledge Base
Solution --> Phaser 4400 Printer: Printing envelopes
Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
Guidelines for envelope printing
  • Use only paper envelopes.
  • Do not print on the back of the envelope.
  • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
  • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
  • Envelopes may wrinkle depending on weight and stiffness of the envelope.
Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
  • Select faceup.
  • Clear Clockwise Rotation.
  • Select the feed method with the image centered and the stamp on the envelope to the upper left.
caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
  1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
    • Place the side to be printed faceup.
    • The top of the envelopes should be toward the left of the printer.
Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
26 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
