Question about Kohler Plumbing
Faucet threads stripped-earator won't screw on tight
I have a portable dishwasher that connects to the faucet using a special aerator. When I installed my new kohler faucet , i had to remove the aerator and install my special aeraotor so I can run my dishwasher . I could not get my aerator to seal properly and am afraid that the threads on the faucet are stripped . I suspect that Kohler uses plastic in their faucets and because the threads are made of plastic , they are suseptable to stripping
  • 68 Answers
SOURCE: Pressure problem with Kohler shower faucet??
Hi pglaw,
My best guess is the supply valve for the hot side isn't open all the way. This valve is right on the valve and is accessed by taking off the front cover plate. This would still allow the pressure balancing valve to let water through but then you would have a small flow on the hot side.
If this isn't it then then cartridge is bad.
Please rate this response and good Luck,, phil
Posted on Dec 31, 2008
dragonsthatk
  • 547 Answers
SOURCE: kohler single lever kitchen faucet,no hot water
no its somthing in water filter rust or dirt in line.take apart and drain line. thank you for useing fixya please rate me
Posted on Feb 26, 2009
defadad
  • 351 Answers
SOURCE: Single Handle faucet broke on my Kohler kitchen
Is cheaper to replace the whole tap as the service kits cost almost as much as the tap to buy, I presume you are talking about a flick mixer tap (that is what they are called in australia)
Replacing them is reasonably easy, turn off water at the main out on the footpath turn the tap on to let the water run out, go under the sink with a couple of spanners or deep reach socket and undo the lines and the tap hold down nuts and remove, replace in reverse order
Posted on May 07, 2009
  • 3600 Answers
SOURCE: Kohler Fairfax shower faucet repair
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
Posted on Sep 27, 2009
jyackle5
  • 8197 Answers
SOURCE: Kohler Fairfax single control kitchen sink faucet
Remove the air-irater at the end of the faucet where the water comes out. That is where 99% of clog are on faucets. If that does not do it then you need to replace the cartridge.
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Mar 19, 2010
Do I need to replace the adapter for the faucet areator for my portable dishwasher.
Probably. If you didn't discard the package of extra fittings that came with the dishwasher, you may find the correct adapter/aerator fitting in there. Otherwise, try contacting the manufacturer of the dishwasher. Be sure to provide the make and model of the new faucet along with the model number of the dishwasher.
Jan 03, 2015 | Dishwashers
How do I remove the aerator?
aerator always screw off typically counter clock wise (lefty loosy), but remember the aerator is "upside-down" as you look at it on the faucet arm. There are two types, male threaded and female threaded. Both unscrew from the faucet arm the same. There are at least four different sizes so take the old you with you when you go to replace it. Most times the threads are gunked up by lime and hard water deposits which means a pair of pliers or channel locks along with gentle rotation of the aerator cap will be needed to loosen the threads. Be aware that a washer may tend to stick in the faucet arm opening after you remove the aerator. Stick your pinky into the faucet spout opening and fell if there is a black rubber washer. Replace with a new one in reverse.
Sep 26, 2014 | Kohler Mistos Bath and Shower Faucet Trim...
GE portable dishwasher connector hose slips off faucet adapter
Google your dishwasher you will see parts on line There are loads just looked .
Apr 13, 2017 | Dishwashers
The small round metal mesh discs inside the kitchen tap have fallen out & will not stay in when re-inserted. Now the water squirts out at weird angles drenching the kitchen work surfaces. Do I need a...
Hi Jean,
These mesh discs and the part they go into - along with a few other small parts - make up what is called "an aerator".
Most aerators simply screw on threads at the end of your faucet. You can remove it by twisting it. You may need a wrench to loosen it first. Wrap the aerator in thick cloth / towel so that the wrench does not dent or scrape the finish on the aerator body.
Some aerators thread up and inside the faucet - rather than at the end - and need a special wrench to remove
Once removed, you should reassemble the parts and reinstall on the faucet. You may find replacement aerators in Home Depot, Lowe's, etc. if you're missing parts, etc. If changing it out, be sure to bring the old one with you to match.
I hope this helps & good luck!
Sep 22, 2011 | Microwave Ovens
My husband installed a new KWC Domo faucet in our kitchen yesterday. When he was finished, he turned the faucet on and got a trickle of water. We are stumped and the instructions are no help.
Take off the aerator from the spout (it just screws on, and should not be so tight you need a wrench) and then run the water. You'll probably find the aerator screen is clogged with debris and you can wash it off. This often happens when you turn the water supply off to connect the new faucet. After you clean off the aerator and screw it back into place your new faucet should work fine.
Feb 27, 2011 | Microwave Ovens
Faucet solution for hooking up portable dishwasher
there is a generic adaptor that fits on your faucet; take the name, model# and, hose to a hardware store and, they can show you the right adaptor for your machine
Sep 15, 2009 | Dishwashers
I have a portable ''GE quiet power'' portable dishwasher and the hose won't fit on my new faucet - is there some sort of adaptor I can buy for the sink so it will fit properly?
Yes, you need to know whether your faucet is male or female thread (threads on outside or inside) and buy an adapter that will fit into the faucet where the aerator normally sits. These are generally available in the plumbing section of your local hardware store. Make sure you know your diameters as well (O.D. stands for Outside Diameter and is usually male thread where as I.D. stands for Inside Diameter and is usually female thread)
Jul 03, 2009 | GE Dishwashers
I need to find a new aerator & the guts
I had to go to Home Depot and stack a few adaptors together to get a proper fit. You will probably end up without an aerator but, you will be able to use the dishwasher.
Feb 16, 2009 | Maytag Performa PAV2200
Hose does not fit on sink faucet
Yes, the adapter was the answer!!! I went to the Sears Service Center and bought one, under $10. HURRAY! And say hello to softer hands . . .
Nov 12, 2008 | GE 24-7/8" Convertible Portable Dishwasher...
Attaching potable dishwasher
Did you remove the existing aerator from the faucet nozzle first? If not, that's your problem.. If you did..then look at the adapter to see if the therad pattern on the end looks like the thread pattern of the aerator you've removed.. If it does.. then you need to install that one.. Sometimes ..you can get them started by rotating it into the faucette backwards a few turns and then rotating it forward until the threads get started properly..after that.. just tighten it in place.. Hope that helps !
Aug 18, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
Plumbing Logo
382 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
