The tv has a black screen with the green light flashing like mad, will not turn on?
  • 1,205 Answers
Evening there
Check the scart plugs and cables. There might be inputs for sound and brightness. Look at the back of the TV to check for input and output.
good luck
Kolbrun
Posted on Feb 16, 2012
SOURCE: TV will not turn on/black screen/picture/green LED is red/blinkin
I had the same problem for my TV which was model number: 42PF9631D/37 and I went to get the software update at http://www.p4c.philips.com. Type in your model number, then click on the right model. Then click on software & drivers in the left column. Then download the correct software update to a flash drive. The flash drive must be completely empty except for this file. Then unplug your TV, and plug the flash drive into the USB port. Plug your tv back in, and the software update will upload. It fixed my TV instantly.
Posted on Jan 09, 2009
  • 718 Answers
SOURCE: TV was playing, then the screen turned black.
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
Posted on Feb 24, 2009
  • 108 Answers
SOURCE: Have TV AOC L32W761 When i turn it on light turns
This sounds like a problem with the power supply. Usually capacitors on the power supply board tend to dome, bulge or dry up. The damaged ones can be seen on the power supply circuit board when the back is removed. The dry ones have to be removed and tested. The caps can be replaced at a repair shop for around $200, but if the power supply board has to be replaced it can cost a little more. It all depends on the shops repair fees.
Posted on Sep 07, 2009
dave1645
  • 834 Answers
SOURCE: Screen has black spot in corner that spreads to entire screen
one of the floresant bulbs has fail there is a place in Haverhill Ma called Tops Electronics that can fix you up really quick but you will have to ship it to them they do good work there
their new name is pinnacle solutions group over 30 year serviceing
Posted on Sep 18, 2009
  • 8457 Answers
SOURCE: Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Apr 07, 2010
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
How to repair LG TV
The power supply may have failed.
Nov 07, 2014 | LG 42LM3400 42" LED Cinema 3D HDTV w/ 4...
Panasonic tv PT50LC13 has no picture red light flashes when i turn it on green light flashes and turns off
This model was recalled by Panasonic-----massive recall. Start by having the lamp examined or tested---that is the place to begin.
Oct 17, 2012 | Panasonic Televison & Video
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
Our Hitachi Plasma TV suddenly went black and the indicator light started to flash green. We turned it off at the wall and back on. The screen flashed green, went black again and the indicator light...
If you want it fixed, you'll have to take it to a real tech. If you read this garbage you'll probably end up spending more that the tv is worthed in the long run to fix it.
Nov 02, 2010 | Televison & Video
Why is my sanyo tv flashing green, blue, and red ?
i turned it on nd it was still like that nd i gt more mad. i was gna throw the remote bt i presed the menu button randomly once or twice i dunno bt it came back(normal tv)
hope that helps
Apr 11, 2010 | Sanyo DS31520 31" TV
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
