Question about APC Symmetra LX UPS System
Symmetra lx beeping continuously
UNit beeping continuously
  • calin guga Feb 16, 2012
    symmetra lx beeping continuously
Syaf16krmt
Hi Ehabnwr,
The board is located on the top of the unit and can be 'reseated' in order to reset board. The UPS will need to be completely powered off while doing this to avoid possible damage to the unit and to yourself.
If you need UPS, Surge, or Power Related help contact:
Daniel@psihq.com with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
•• If this helped - click YES :) ••
May 13, 2014 | APC Symmetra LX (syaf16krmt) UPS System
Apc symmetra px stuck on self test
Place UPS into internal Bypass (Static Bypass) via the display. Then place unit back to Normal from Internal Bypass(Static Bypass). See if that helps. Or shut the unit down completely by placing UPS into Static Bypass first and then place UPS into external bypass mode, switch is located on the bottom front of the UPS. Please follow the UPS Manual to help you understand the procedures. Also recommend doing this after hours, not during business hours.
Jan 15, 2014 | APC Symmetra PX (SYCF80KF) UPS System
Apc sy lx
Ereadlu,
What's the problem? And is the UPS a Smart-UPS or Symmetra? Jotting down the exact model number will help.
Daniel • Power & Systems Innovations • 800.260.2259 • www.psihq.com
** If this helped - Give it a Thumbs Up :) **
Dec 17, 2013 | APC Smart-UPS 1000VA UPS System
Kindly recommend ups for 15kw load
I would get a APC Symmetra LX for single phase of Symmetra PX for 3 phase
Sep 21, 2013 | Computers & Internet
What parts are used to preform a tune-up
First you need a tech that is qualified and has experience in Annual PM's on this type of unit. Symmetra is a module type unit. there is hardly any "tune up' to do to this unit. Test the batteries and insure all modules all ok, this includes the intelligent modules that pull out. Review past alarms that have been recorded and insure that no major alarms are present. Do a battery test from the display interface. Clean the area around the UPS.
Aug 31, 2012 | APC Symmetra Tune-UPS technical support -...
I have an Symmetra RM APC and there is an amber light showing and a beeping about every 30 seconds.
Hi Ewiesemann,
The amber light on the UPS usually means that the unit is 'on battery' -- meaning that input power is affected. Check to make sure that unit is plugged in and check to make sure that a breaker on a panel feeding the UPS power hasn't tripped.
Hope this helps.
Jul 28, 2011 | APC - UPS - Matix/Symmetra Enterprise UPS...
Symmetra LX "Intelligence Module Fault". Does
First calculate the total load of the UPS and then calculate the total load. One of the Intel Module is Primary and one is Secondary. I can't remember exactly which one is primary. Q1. There will be a LED on the INTELI MODULE flashing RED. That identifies the bad MODULE. Q2. You can remove the MODULE, but I recommend you place the UPS in Static Bypass first through the Display Menu. Also make sure the UPS is in NORMAL MODE or already in STATIC BYPASS, the LED's on the Display should indicate what mode its in. Q3. You can remove the display from the Inteli Module with out harming the load. You just can't do anything with the UPS, as to tell it to Go to Bypass (Static Bypass) or get out of Bypass, check voltages, etc. So order the part first by getting part number on the sticker off the Module, then schedule your shutdown and perform the you maintenance after hours this way you don't affect anything during business. Also don't do the repair on a Friday due to the fact its weekend and APC/Third party UPS companies will charge you a lot to come out in the weekends. FIRST DO THIS PLEASE- GET THE MANUAL FOR THIS UNIT!!!! And READ IT FIRST!! Find in the manual where it walks you through putting the UPS In bypass (Static Bypass). Follow the manual, My way of doing is to READ TWICE, OPERATE UPS ONCE!! This has help me not dump any loads. My suggestion to you is to check if unit is in Bypass (static Bypass due to the faulty module. If it is on Bypass then all you need to do is follow the procedures to place UPS in External Maintenance Bypass. If UPS is in Normal mode but with Alarms and Beeping, then Navigate through the display and find the BYPASS Mode. Then hit enter Yes on the BYPASS MODE, it will ask you again if you want to "Place UPS INTO BYPASS. Hit YES. You will hear it click. Your LED on the display should Light UPS Solid "BYPASS LED ON" AGAIN Please keep referring to the MANUAL. Once your in bypass mode (Static Bypass) then you can operate the External Bypass Switch on the bottom of the UPS. That is the Maintenance Bypass Switch. This isolate the UPS completely and your load never see's the transfer from Static Bypass to External Bypass, Because its a MAKE BEFORE BREAK System. (Make the power before Breaking the Power) Sorry to get down to simple terms, but when I work on a UPS its personal due to the fact you are responsible for the all that is on the OUTPUT of that UPS. Once on External Bypass, You can now do you module swap. Turning the UPS back on, Please follow place UPS back On Line in the UPS Manual. Also in the Diagnostics, off the display of the unit, it also identifies what module is bad including the Power Modules to the Battery Modules.
Nov 03, 2010 | APC Symmetra Tune-UPS technical support -...
I have a Symmetra LX 16000 , and ups sen me the message ...Critical - UPS A main intelligence module fault exists.. code 0x0203.
Hi Scabcmx,
Without knowing the full model number of your UPS I cannot go into specific details fully for you.. but a good test with any 'intelligence module fault' is to re-seat the module and run a self test. If the fault remains then your intelligence module is bad and you will need to acquire a new one to replace the faulty one. This can all be done 'on-line' and you should not have any downtime... assuming there is a redundant intelligence module in the unit which is normally the case. This will clear the fault.
If you would like more information give me a call: 407.380.9200.
Oct 12, 2010 | APC - UPS - Matix/Symmetra Enterprise UPS...
APC Symmetra LX UPS System Logo
216 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
