Question about Plumbing
Install glacier bay # 236 631
Mounting faucet to base
  • 2692 Answers
SOURCE: Grohe ladylux faucet loose on counter.
Here is the manufactures web where you may request the information you desire concerning your faucet.
http://www.groheamerica.com/s/25_4060/page/modules/iframe/index.php?if_url=http://12.130.64.173/litrequest2.htm
Posted on Dec 10, 2008
  • 82 Answers
SOURCE: I just installed a Glacier Bay tub/shower faucet
Hopefully you still have the directions - the diverter isn't set correctly.
Posted on Dec 31, 2009
SOURCE: We recently installed a new bathroom faucet and it
check the strainer where the water comes out of your faucet it may be clogged or if the faucet has a cartridge in it it may be clogged and you will have to dis assemble the faucet to clean it usually the strainer is the problem and it should unscrew by hand
Posted on Mar 11, 2010
  • 349 Answers
SOURCE: I have a Glacier Bay(Costco) kitchen faucet. The
Check the weight and see if it has screws in it to move in on the hose line the distance it lacks retracting.
Most of them can be adjusted to proper retracting mode. It may have a couple of screws in it.
Posted on May 15, 2010
  • 122 Answers
SOURCE: Is there a way to remove the aerator from a
they unscrew from the faucet. counter clockwise.
if they are a little stubborn, you can use channel lock pliers, GENTLY grab the aerator with the pliers and GENTLY twist, counter clockwise.
do not use the pliers to re-install, just hand tight.
Posted on Aug 17, 2010
Tip
How to remove Glacier Bay Lever Kitchen Faucet Handles
To remove the lever handle from a Glacier Bay two-handle kitchen sink faucet: Insert a 2.5mm hex wrench into the small hole underneath the lever. Work the wrench into the small handle set screw.Turn the wrench and setscrew counterclockwise to loosen. Pull the Glacier Bay lever handle off the faucet stem. P.S. You do not need to remove the screw to take the handle off.
on Oct 07, 2010 | Globe Union Glacier Bay 8 In Double Handle...
I have a Glacier Bay shower faucet that is getting increasingly harder to control water temperature out of shower faucet! Water temperature is very hot
check the hot water supply first and if needed adjust if to high and or check your anti scald setting --need to remove the center handle on the mixing valve
How To Adjust Glacier Bay Anti Scald Device Yahoo Video Search Results
Jul 31, 2017 | Glacier Bay Home
Looking for an extension valve for shower faucet #108 191 Glacier Bay product.
Fixya is not a buying service. You may have to have the "plumber" redo the job; he forgot to measure the setback distance allowing for surface mounting of the escutcheon.
Nov 13, 2016 | Plumbing
How do I put seats and springs in a glacier bay Aragon three handle knobs
How to Repair a Glacier Bay 3 Handle Tub and Shower ...
www.faucetinstructions.com > Glacier Bay Faucet Instructions
My three Handle Glacier Bay Tub Shower Faucet Makes a High-Pitch Squealing ...The Glacier Bay tub faucet screw-cover buttons will not stay on the handles. ... Sealthe flanges to the shower wall with a high-grade anti-microbial kitchen and ...
Nov 07, 2015 | Plumbing
Wiggling Goose Neck
There could be loose hardware inside at the base of the goose neck. You will have to remove your carefully installed faucet and take a look inside to find out.
Nov 13, 2013 | Globe Union Glacier Bay 8 In Double Handle...
How to repair facet stem for glacier bay products kitchen sink
Theres not much you can do to repair the stem except replacing the small O-ring up inside. You can call Glacier Bay and ask for a new stem ( the faucet has a limited lifetime warranty. You can also use Delta faucet repair parts in your Glacier Bay kitchen faucet; they come from the same mold. Heres a link to Glacier Bay 2 handle kitchen faucet repair. Heres one to the Glacier Bay faucet manual for your faucet.
Sep 16, 2010 | Globe Union Glacier Bay 8 In Double Handle...
Single-handle Glacier Bay shower faucet, hot/cold reversed
Hello. It sounds like your plumbing was installed wrong, with the hot and the cold supply lines reversed. If that is the case, those supply lines will have to be replumbed to make your faucet work properly. Often, if those lines are accessable, it is only a 20 minute job. Joe
Mar 18, 2010 | Delta & Single Handle Shower Faucet
Plumbing Logo
123 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
