Question about Canon iR 2016i Black and White Copier
Error e246 canon ir 1022 - Canon iR 2016i Black and White Copier
Cogz
  • 1326 Answers
SOURCE: ir 8500 E000246
A E240 is the reg. clutch or the DC controller or a loose wire, a E246 to me would be a problem with the DC controler or a loose wire going to the pcb. And the E225 or E226 has something to do with the counter pcb or the DC controler pcb. Also I would check the rom version of the copier. Also, was that the problem you went there for?? If not retrase your steps..
Posted on Oct 02, 2008
  • 199 Answers
SOURCE: canon ir 2018 ERROR CODE E246
check print controller pcb connection, ram & EEPROM
Posted on Feb 26, 2009
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
  • 3 Answers
SOURCE: error e -070 in canon ir -3100 color copier
Its an error with the senor for the transferring belt. Try going into the additional functions-adjustments/ cleaning-gradation adjust- full adjustment. And follow the prompts on the screen. If this doesn't work and you feel comfortable trying you can clean the sensor. Remove the front covers, waste bottle and the drum. The sensor is located inside the chassy where the drum was at, in the middle (front to rear) on the left Do not use a vacuum on the sensor it can be damaged easily. After cleaning and reassmbling retry the gradation adjustment.
Posted on Jun 04, 2010
babaprithi
  • 372 Answers
SOURCE: error E246 on canon iR2020
communication error between main board and dc controller .remove all the connection to the boards and then reconnect them .
Posted on Aug 11, 2011
Canon ir 6570 ERROR CODE E246
Have you checked toner waste bottle wheter it is not full? Could be the issue you are looking for.
Apr 28, 2014 | Canon Office Equipment & Supplies
Error E246 on canon iR2020
Aug 11, 2011 | Canon iR 2016i Black and White Copier
When I start the machine I get an error message "system Error E246. Pl help me out.
that is problem with soft counter memory,
exactly error the EEPROM on the DIMM.
this happen because something try to changed number of memory counter.
solution is replace a new DIMM.
the dealer copier who have this part.
or you can search on http://alibaba.com. or http://amazon.com
Jun 11, 2011 | Canon iR 2016i Black and White Copier
Canon ir 2200 error e246-0002
An E246 is a Counter pcb issue. You may want to reseat the Counter pcb on the Main Controller, Also if you swapped the Main Controller you need to leave the orginal Counter pcb in the machine. If this doesn't pan out you need to call the TSC and open a ticket. You can not order a Counter PCB.
Mar 09, 2011 | Office Equipment & Supplies
Ir 1600 error code E246 PLS HELP
give detailed step-by-step instructions
Oct 06, 2010 | Canon imageRUNNER 2000 Copier
Canon ir 2018 ERROR CODE E246
Feb 26, 2009 | Canon iR 2016i Black and White Copier
Canon iR 2016i Black and White Copier Logo
138 people viewed this question
old marine
old marine
