Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Gritty dishes My dishes are coming out of the wash gritty. It is as if food has been dried on them. As if the rinse water has particles in it and then they are left on every dish. I have used a dishwasher cleaner several times and I also use the rinse agent in the machine. Nothing is helping. It is getting worse.The inside of the dishwasher. mostly on the top, usually has food residue all over it at the end of every wash. Even the machine is dirty. I'm hand washing everything right now. Any suggestions?
mosesclive
  • 191 Answers
SOURCE: Dishes not clean
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Posted on Jul 19, 2008
SOURCE: The glasses and about half the dishes I put on
Got a solution on a different website.
Posted on Dec 27, 2009
  • 677 Answers
SOURCE: How to access and clean the filter around the food grider
problem is hard water actually. go to www.dishwasherfilter.com. they have a new product out for this exact problem. works great and is very affordable.
Posted on Jan 01, 2010
  • 901 Answers
SOURCE: top rack dishes have a white gritty residue on
Check whether the top rackspray arm is moving freely. Check the jet holes and remove clogs if any.
Hope the bottom rack is good in wash quality!
Posted on Apr 13, 2010
heatman101
  • 43501 Answers
SOURCE: Dishwasher KUDS01DJ drains but leaves food
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Posted on Feb 27, 2011
Milky water when rinsing in dishwasher & gritty covering on dishes
I have spent many years (47) in the catering industry using catering dishwashers, under counter models, corner- wash stations and also conveyer machines..
The milky water is a by-product of the wash water and rinse water mixing.
The spray are has to rotate freely or the dishes won't wash or rinse properly. They spins a lot faster than you realise and this adds pressure to the water, but also a pulsating effect to remove dirt.
Over doing the salt can cause more problems that it solves. The gritty film may indeed BE salt. I actually prefer Calgon as a softener.
My advice is to remove both top and bottom spray arms. Check the slots/holes for obstruction, and run water through them under a tap, outside to inside (the opposite to how it is in the machine) rocking the arms up and down to allow any obstructions to flush out. Lemon pips and toothpicks are out biggest problem! Put the arms back and make sure they spin freely. Sometimes they just lock up for no apparent reason!
Use CLR descaler in the machine to clean it using the instructions on the bottle. Then run the dishwasher using the recommended doses of detergent and rinse aid.
Jan 19, 2016 | Siemens Dishwashers
Keeps leaving dishes gritty after wash.... Have cleaned everything possible
Do you live in a region with hard water? Most detergents don't work very well with hard water because phosphate is now outlawed as an ingredient in dishwasher detergent. Weird but true. Here's a map to show the water hardness in the US.
http://www.citriclean.net/why-citriclean/
Mar 19, 2013 | Indesit Dishwashers
My dishes come out with a gritty sand all over them.
If you live in an area with hard water, the grit is probably hard water deposits. Dishwasher detergents no longer contain phosphate, so the detergents often leave behind hard water deposits on your dishes. There is a great solution at www.cloudydishes.com
Oct 15, 2012 | LG LDF6920ST Stainless Steel 24 in....
Siemans dishwasher model SE55A560GB/42. Upper rotating spray bar not turning but botton spray bar is rotating. Dishes are left with a gritty feel to them.
Check that the arm rotates freely when spun by hand, then check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
Apr 13, 2011 | Dishwashers
Not sure what model but Frigidaire Dishwasher- the dishes are cloudy and gritty. The water gets hot, the cycle seems to be running normally, but even if I put clean dishes in, they come out cloudy and...
The problem is hard water leaving those spots. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Sep 20, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Brand new bosch dishwater does not get dishes clean - food residu
Try the cascade new soap they have been changing the ingredents due to state requirments for the water treatment. also make sure spray arms and jet are free from food particles,also clean soap dispencer,If you want run CLR through dish washer no dishes to clean machine.Thanks
Jul 26, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishes always come out gritty, even if I rinse them. Is there a way to clean something out to get the food particles out? Gibson Quit dlean I
if machine is fully operational, then it may be a detergent problem.
is your machine heating to proper temperture, is your machine rinsing ??
Jun 19, 2010 | Dishwashers
Gritty/sandy feeling on dishes from dishwasher
You could only check the basics. Since the dishes are clean, it means they went through the wash cycle. It also means that that the holes on the washer arm are not blocked. If they were salty and dirty the wash arms would be something to check. And since they came out feeling like salt is on them its possible they didn't rinse and its also possible the dirty water didn't drain.Were your drain and fill hoses checked or did the techs just check the dish washing machine itself? Its also possible the water for rinse is not hot enough. Before the rinse cycle comes around try running the hot water at your kitchen faucet. Any other issues may be within the cycling of the machine.
Apr 29, 2010 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
A gritty feel is left on glasses and some dishes
Hard water! Try Cascade Rinse Aid.
Mar 25, 2009 | Dishwashers
Dirty dishes
Try putting a cup of white vinegar in the empty dishwasher & running it on fast wash. Should eliminate film; do you have hard water where you live? If so lime build up could be the problem.
Hope this helps.Cheers.
May 16, 2008 | Dishwashers
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
83 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
