While recording on my portable cassette player, sound became wobbly.
/Sounded like I hit the "rewind" button....but it was still recording. Now the "rewind" sound is on the cassette tape I was recording.....I tried to clean the heads...but it still has the wobbly sound.
  • 130 Answers
SOURCE: Tape is stuck in VCR- Fast rewind and forward
It may need to be cleaned. Mechanical problems are one of the big problems with VCRs they use alot of mechanical moving parts and play for so long they fail. Plastic parts dont help much either. The pinch roller takes up the slack and is usualy the part that fails first because it constantly runs along the tape and builds a coating on the rubber so it doesnt grip the tape and pull it back into the cassette. If its not pulling the tape back in then it hangs up inside and you cant get the tape out. Fastforward uses the reels to pull the tape not so much the roller. Try and stop 2 times then fast forward then eject the tape. Try and eject the tape while its fastforwarding so it doesnt do anything else. Sometimes machines will unload after its been in fastforwad a while then it will eject. You will hear a change in the sound when it unloads, you can hear the mechanical arms move the tape in and out of the cassette. Thats when you eject it. You cant really clean it till you get the tape out. YOu can clean the pinch roller with fingernail polish or paint remover. It is a wheel inside it looks like a black tire. It pinches the tape against the capstan arm this is why it developes a film or a shine on the rubber making it slip.
Posted on Apr 04, 2006
bmwrider
  • 215 Answers
SOURCE: head cleaning
Quite often just the one clean won't dislodge the gunk built up on the heads. Make sure you use a new wet system head cleaner and you may have to run it a few times to clear the clog. JUST DON'T USE COTTON BUDS OR WOVEN RAGS. BMW
Posted on May 18, 2006
Vulfen
  • 5 Answers
SOURCE: Cassette player not working
Cassette players usually have a little rubber band that connects the motor to the spindles. If everything else is fine, I would suggest seeing if it slipped off somehow (or got cracked and snapped)
Posted on Jul 15, 2007
sreekidu
  • 60 Answers
SOURCE: Sound dropout
hi, the problem could be because of the problem with the pinch roller ,either it has some wear or the supporting spindle needle has some improper orientation. Is this with a specific tape or all tapes? if it is specific to a tape then it can be because you kept the recorded tape near magnet which causes this rythmic sound drop out. i guess the first one may be mostly happened. all the best sreejith
Posted on Aug 13, 2007
QTipsX800Pro
  • 48 Answers
SOURCE: My Camcoder says eject the cassette
Use a Sony head cleaning tape they work perfectly and you let them run there 10 second corse. Then your sharp will run perfectly...
Posted on Feb 19, 2008
Cassette Recorder play problem
It is problem in Take-up Reel section and its not sending signal to processor. How old is this unit?
Jul 24, 2008 | Onkyo TARW255 Single Dual Cassette Deck
'How do i play c.d cassett on my sony system RX775 Thank you
are you sure it is sony and not yamaha? i cannot find a sony rx775 anywhere
Feb 01, 2015 | Sony Audio Players & Recorders
My car cassette player is stuck on fast forward
Buy a cd player or hit stop or rewind button , if electric button , clean if physical mechanical button check for jams
Jul 08, 2014 | Audio Players & Recorders
Rewind button on Coby broken - how to replace
nesecito el picki-up laser lens para un boombox coby modelo mpcd 450blk hern7869@gmail.com
May 22, 2012 | COBY-PERSONAL & PORTABLE Coby Mpcd450...
Podcasts on my ipod touch have echo
Then, while I was staring sadly at my ipod, wondering why my audiobook sounded like it was playing in a tunnel, I saw a little "1/2x" next to the "30sec-rewind" button on the play screen. I hit it, so it changed to "1x" and miracle of miracles, the echo went away. Apparently there's a slow down and speed up button right there, and slowing something down where it can't, makes it echo. I'd never noticed it before, and I must have hit it accidently.
Feb 18, 2010 | Apple iPod touch
Sony tcd-d8 won't rewind
sounds like a belt slipping try renewing them they are fairly cheap to replace.sony tend to be very reliable but this is quite an old item now and belts degrade with time and use.farr64
Apr 30, 2009 | Sony Walkman TCD-D8 Personal Cassette...
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
71 people viewed this question
 Grubhead
Grubhead
