Question about Tradesman Air Tools & Compressors
Will not fire
Brad nailer/stapler model # 8480. will not fire when the triger is pulled. air presher is up to 100.
SOURCE: paslode finish nailer wont fire
CHECK THE SPARK! IF YOU HAVE A JOBSITE RADIO YOU CAN HEAR THE SPARK ON THE AM BAND AND TELL IF THE TOOL IS FIRING!
Posted on Nov 04, 2008
  • 4234 Answers
SOURCE: air stapler leaks air through ''nose''
This sounds like one of the O-rings has failed. Yes it can be fixed. Check to see if HD has an O-ring kit for these guns. That kit will contain all of the O-rings as well as the lubricants for a total rebuild. That should resolve your problem.
Dan
Posted on Nov 13, 2008
  • 1383 Answers
SOURCE: BNA125A Porter and Cable brad nailer
Both of these nailers have a check seal about half way down on the cylinder. This check seal causes the piston to retract if the piston ring is not too worn. The lower bumper should not be cracked and missing pieces, and the driver guide washer must be in place below the bumper. Also check that the driver is not bent causing it to get stuck. The da250b has an upper bumper of sorts and developes cracks that can only be seen by removing and inspecting, If cracked, the upper bumper must be replaced for proper function. The bn125a nailer probably has the discharge port clogged or upper valve parts worn or cracked. The headvalve should be inspected for cracks where the oring fits and the rubber seal should fit snug on the valve. There is a spring that pushes down in the headvalve that pushes from a rubber washer of sorts, check the diagram to be shure that all parts are in order. Both of these guns will not take too much pressure. Try adjusting to about 90 lbs max.
Posted on Nov 25, 2008
lester482529
  • 226 Answers
SOURCE: roofing nailer wont fire porter cable rn174a
9 times outa 10 this is an oring on the driver blade regulator inside the head. it can be removed by undoing the top you may probably find your problem there
Posted on May 26, 2009
  • 8 Answers
SOURCE: my mastercraft electric brad nailer stapler wont
Look for a jam in the gun.Sounds like a brad is "hung up" in it, probably right at point where it feeds into the mouth of the firing point. Be sure you unplug it before you do this.
Posted on Jan 15, 2010
Dewalt d51276 fires multiple times with a single pull of the sequential trigger
Trigger valve most likely problem. You could also just replace the two orings on the trigger stem within the triger valve. They are very small (2mm). There are two or three other orings inside the gun that need to be replaced as well. The yellow vinyl orings used by dewalt do not last as long as the black rubber.
Oct 23, 2013 | Makita Brad Nailer Finish Nailer...
What kind ryobi p300 staples & brad nails
Nice little nailer Fred. Here are the details (sold at Lowes or other lumber centers).
Staple Size 3/8 in. Crown Width, 1/4, 5/16, 3/8, 1/2, 17/32, 9/16 in. length
Brad Size 18 gauge, 3/4, 1, 1-1/4 in. length
Magazine capacity 100 staple/brad Good luck with your projects
Oct 14, 2011 | Ryobi P300 One+ Stapler Brad Nailer
What kind staples p300 stapler brad nailer
These are sold at Lowes and other lumber centers.
My Senco SFN1 finish nailer will not shoot a nail. When the trigger is pulled air comes out but no nail is shot. Thanks,Steve L
Not sure about Senco but most have latch you can open to expose firing mechanism. Nail sometimes gets jammed and will not allow driver to fire or if not nail push driver ****** all the way back into gun then see if gun will fire.
Oct 25, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
I have a Stanley Bostitch Sb 2IN1 2 In 1 Narrow Crown Stapler/18 Gauge Brad Nailer gun. How do I adjust the depth the nailer shoots the brad nails into base boards? I see that their is a dial on the back...
look on the front of the tool.there is a dial right where the plastic meets the yellow housing.also look closely and you should see a diagram on the plastic telling you whitch way to go.
Jun 12, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Bostich narrow crown air stapler won't work
before going about rebuild get can of carburetor spray cleaner and stray the ram area lots of times the glue that holds the staples/or nails builds up and stops up the ram rod spray the rod a few times than with air hooked up dry fire if it frees up lube rod area
Jan 17, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
I have a Bostitich brad nailer model BT200 it's 7 years old
The nailer needs some lubrication. The rubber gaskets are not riding in the shafts correctly. I would have this rebuilt and lubricated. It should be used one every few months to spread the oil around and keep the rubber parts oiled. Check with your local lumber yard. If they deal with Bostitch, you may be able to get a "rebuild" for the purchase of a box of nails. I was able to get a couple of guns overhauled this way during the local "Bostitch days".
Dan
Dec 28, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
I have a ridgid brad nailer. I am running about 100 psi. It will not fire. I hear it try, meaning the I hear air coming out, but not a fire. I tried my other gun ridgid finishing nailer and it is doing the...
insert a open fitting adapter into the connection end and make sure you are getting a good air flow with open ended connector hold away from face and eyes while doing test and be sure the fitting is well seated into coupler before releasing . let me know result
Dec 28, 2008 | Stanley Pneu Roof Stapler
Air Tools & Compressors Logo
35 people viewed this question
Top Tradesman Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Tradesman Air Tool and Compressor Expert? Answer questions, earn points and help others
