Question about E-Machines eMachines Desktop PC
How do you remove the delay on the keyboard for hitting the same key twice
  • 2,229 Answers
You can change this in the "accessiblity" or "ease of access" options in windows in the control panel.
Posted on Feb 17, 2012
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Computer says I have the control key on, but I don't. I popped off the control keys, cleaned and tried again. Same problem. Tried turning computer on and off twice. Same problem. Now I can't even...
    Try using the onscreen key board if possible in safe mode. If you have windows xp hit and hold ctrl+alt+delete twice in a row. This will bribg up the hidden admin account. The type Administrator as the user name and laeve the password field blank just hitting enter. Sometimes these hidden accounts are just overlooked. If you can borrow another keyboard or use an old one. You must ad it with the pc off or it will not read it. Sounds like you just need a new keyboard.
    Hope this helps
    Dec 03, 2010 | Dell 0Y3740 Keyboard
    Boots up then freezes up
    1.Shut down your computer and start hitting F8 key (on the top line of the keyboard.) immediately (on the top line) up and down at least 20-30 times and choose "Last known Good configuration."
    2.If this does not work, shut down your computer and restart the computer in the "safe mode with networking" option.
    How to restart the computer in the safe mode with networking: As soon you restart the computer, start hitting F8 key immediately (on the top line of the keyboard.) up and down at least 20-30 times and choose safe mode with networking by using the up and down arrow key on the keyboard and hit enter twice.
    2. If the computer restarts in the safe mode then, please follow these steps" a.Disable or unistall any anti-virus Norton Removal tool link: http://service1.symantec.com/Support/tsgeninfo.nsf/docid/2005033108162039 Mcafee removal tool link: http://download.mcafee.com/products/licensed/cust_support_patches/MCPR.exe
    b.run malwarebytes and scan your computer. http://www.malwarebytes.org/
    c.cleanboot the computer.Please follow the Microsoft Link: http://support.microsoft.com/kb/331796
    Restart the computer:
    Mar 24, 2010 | Gateway Computers & Internet
    I AM USING LOGITECH CORDLESS KEYBOARD WITH WINDOWS 7 W/VISTA EVERYTIME I HIT A KEY DOUBLE LETTERS COME UP CAN YOU HELP ME THANKS JOHN
    Not sure what to say other than:
    1) Driver is installed twice
    2) Keyboard keys are not effectively debounced in which case you would need to replace the keyboard
    To find out if the driver is installed twice, open up the explorer, right click on My Computer and click on properties. Go to device manager and then go down the list and click on Keyboard. there should only be one driver inside. if you find two and they are identical, delete one.
    Good luck
    Jan 26, 2010 | Logitech Wireless Access Duo Optical...
    Can't type same key twice in a row on keyboard. Have to wait a couple of seconds before typing same key again. bar on bottom of screen flashes yellow every time I press a key and window toggles between...
    Have you ever tried putting in another keyboard? If the
    other keyboard works, it's definite that you have a defective keyboard, and you must get a replacement. This is my observation based from your comments that there is no problem with the keyboard settings in your PC.
    Dec 02, 2009 | Computers & Internet
    Right side of keyboard locked up
    Try hitting the fn key which means Function some laptops you hit twice and it will keep it on constant and won't allow you to use your letter keys
    Happy Holiday
    Dec 24, 2008 | IBM ThinkPad T41 Notebook
    How do i turn off the delayed type on a ibm wheelwriter6
    at the very top right of your keyboard there is a "print mode" key
    press this key until the note in the left lower coner of the display says "char print"
    however in delay print you can correct mistakes before you print - saves on correction tape
    Nov 17, 2008 | IBM Wheelwriter 30 Typewriter
    Alternate keys on HP Keyboard
    Activate:
    Ctrl + fn + right shift key
    Deactivate:
    Ctrl + fn + right shift key twice
    so hold ctrl + fn + right shift key then release the right shift key but keep holding the ctrl + fn keys down then push the right shift key again and that should deactivate it
    Jun 09, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
    EXTREME DELAY IN KEY RESPONSE
    hi
    change the key board, i had a simliar problem once
    Paul
    Oct 17, 2007 | Logitech Cordless Desktop EX110
    E-Machines eMachines Desktop PC Logo
    22 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
