Fellowes DM12Ct wont automatically run
We have a Fellowes DM12Ct shredder. When I move the control switch to the "automatic" position the red light comes on. I've made sure the basket is in the right position and oiled the blades. I've hit reverse in case there was a jam. It will shred if I hold the Turbo Jam Release button. What do I need to do to make the Automatic start work?
  • 215 Answers
SOURCE: Fellowes PS60C-2 shredder doesn't shred
there are two switches under the cutter area. 1 for sensing when your basket is full, (sometimes these bin-full flaps get stuck in the up position, energizing the switch) and the other is a switch that detects if your basket is installed. fellowes has modified these shredders so many times, that there are alot of different configurations. look for something that resembles a flap under the head and make sure its in the down position. as for the basket sensor, some baskets had 2 projections on the left and right top of basket. one may be broke. if so, you can "cheat" the switch with a screwdriver to see if thats the problem.
hth,
razors
Posted on Apr 15, 2009
  • 105 Answers
SOURCE: The "bin full" indicator is always on.
you will have to clean or replace the bin full sensors
Posted on May 14, 2009
FixinFax
  • 3085 Answers
SOURCE: Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Posted on Jul 05, 2009
  • 610 Answers
SOURCE: the Fellowes P-4sc shredder is not shredding
plastic gears are broken. don't think fellows make replacement parts for small personal shredders. get a new one. don't buy a Royal or Aurora brand, they are the worst.
Posted on Oct 30, 2009
Testimonial: "It was helpful, and confirmed what I expect, though my boss is not going to be to happy to hear that we have to replace the shredder."
greg_margo
  • 1959 Answers
SOURCE: fellowes 3011001 shredder stopped shredding. tried
First, try switching to reverse, alot of times, stuck paper will come back out in reverse. Then unplug the unit, turn the head upside down and with a small flathead screwdriver, knife, or tweezers, dig out pieces of paper. It takes alot of effort but by digging small pieces out, a little at a time, you can get most of the paper free.
Posted on Nov 16, 2009
Wont automatically feed paper to shred
there is a small switch or an infra-red sensor that sees the paper. Check it in the slot of the shredder.
Paper Shredder Parts
shredderparts.com/
We sell all sizes of paper shredder gears, switches, blades, etc. to facilitate your repair. We also have shredder replacement parts for crosscut paper shredders, ...
General Shredder Parts - Shredder Repair Services
www.shredderrepair.co.uk/general-shredder-parts-227-c.asp We can supply a wide selection of parts for various makes of shredder some of the ... Paper Shredders ... Please note SRS take no responsibility for loss, damage or personal injury caused by the fitting of spare parts by non SRS personnel.
Paper Shredder Parts ' All brands inc Fellowes & Rexel ยป Document ...
https://www.documentdynamix.com.au/service/paper-shredder-parts/ Document Dynamix Australia has a strong reputation for responsive supply of paper shredder replacement spare parts and support. Whatever brand your paper ...
Jul 17, 2017 | Cars & Trucks
Fellowes dm12ct
One good thing about a Fellowes is that you can get parts and/or repair.
Look up your model and serial number, then go here:
Replacement Parts Paper Shredders
Aug 25, 2014 | Office Equipment & Supplies
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Can you take apart a fellowes PS-12C
FELLOWES SHREDDER
May 23, 2014 | Fellowes Office Equipment & Supplies
Runs reverse auto
From your manual!
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the waste basket; insert waste basket and repeat jam clearing procedure.
Feb 01, 2014 | Fellowes DM12C Shredder
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
Shredder stopped suddenly and won't work
If you are unable to clear the jam, turn off and unplug the shredder;
remove shredder head from the wastebasket and carefully remove any paper extending
below the cutting cylinders; empty the wastebasket; reassemble the shredder and repeat
if still do not run follow the next steps:
1. Make sure shredder is plugged in and
switch is in automatic [I] position.
2.Wait 15 minutes for shredder to cool
down before trying again.
3.make sure that the shredder head is in the correct position, if is not it will not run
please rate the post for i to know do this is helpful if not i will know by your rate that i should post some more information
Jan 11, 2010 | Fellowes P70CM Shredder
Runs continuously when in the on position.
there is paper jammed in front of the sensor. it was likely caused by feeding too much paper into the shedder at one time and now a chunk of shedded paper bits it blocking the sensor from seeing that the shedder is clear
Dec 18, 2009 | Fellowes DM8C Cross-Cut Shredder
Fellowes p45C
Please call us (Fellowes) at 1-800-945-4545 to check and see if this is a warranty issue or if we can troubleshoot the machine for you. It sounds like you may have a gear that went out
Mar 18, 2008 | Fellowes 3011001 Shredder
153 people viewed this question
jasbo
jasbo
