Question about Compaq iPAQ Connection Point CP-2W (241274-001) 802.11b Wireless Access Point
No Signal A freind of mine recently gave me an extra CP-2W wireless router he had for my new home. I've set it up and updated the firmware according to the manual. The router itself seems to be working and the computer connected directly to it by ethernet can access the internet but none of my wireless devices can access the router or the internet. I have performed the set-up process numerous times and have gone threw the manual over and over but can find no reason that it shouldn't be working. Any ideas would be much appreciated.
Hiya i have the same prob but i dont have teh drivers for the router but my ethernet works fine but cant fined wireless point plz help
Posted on Oct 06, 2007
    Problem Solver:
  • 10 Answers
Hey i hope this issue has been resolved by now... ami i right .. if its not then jus lemme know n i l post ya the exact solution for this one ,,, i think its a very minor issue,,, plz respond
Posted on Mar 12, 2007
I just installed a wirelss linksys wrt54gs v4 router in the bk bedroom, with my office computer equipment,,my wife has a wireless hp pavilion 6000, that she would like to use in the living room,40 ft away...
Hello
Try updating the firmware on the router.You need to log into the router using 192.168.1.0
Username =admin
password = admin or the word password.
Once in the routers home page check for updates and download and install.Also be sure any firewalls are not blocking the signal.
While your in the router set up a personal wep key for your wireless security.
There is a possibility your lossing signal to outside intruder.
Apr 21, 2011 | Linksys Wireless-G WRT54GS Router...
We've been using the MN-500 router for over 5 years without issue. Recently, the signal strength seems to have diminished. Router is in the basement. We used to be able to access from our first and second...
This is a common problem. There are two ways on how to fix this. First, update the firmware of your router. You can download the firmware from Microsoft download site.
Before you install the router's firmware, you must do a hard reset. Press the reset button at the back of the router for 30 seconds then unplug the power for another 30 seconds before you plug it back in.
Access the router's admin page through http://192.168.1.1 and look for firmware update settings.
After successfully updating the firmware, you must do a hard reset again. Reset for 30 seconds then power cycle it.
2nd
In fixing low signal strength, you'll just need to change the wireless channel on the router's admin page. Access the router's admin page through http://192.168.1.1 and look for wireless tab, change the channel to 11 and save the settings. If you have cordless phone you need to relocate its base away from the router.
Aug 05, 2009 | Microsoft Broadband Networking MN-500...
Setting a secuirty access password on Compaq IPAQ router CP-2W
You want to setup WPA, assuming the access point is new enough.
WPA with a Pre Shared Key (aka PSK) is what you want. This is often called WPA Home or WPA Lite or something similar. All a PSK is really is a password.
Look for this on your wireless setup menu. You should be able to set it there. There's a small chance this is on the advanced screen, although most have it on the normal screen. If you have a really old access point, you're likely going to only be given WEP options. If so, spend the $50 for a new one. You'll be money ahead in the long run... Since this is an 802.11b access point, that's almost certainly the case...
Mar 31, 2009 | Compaq iPAQ Connection Point CP-2W...
Give me a wpa key for my psp
If you forgot the key:
Reset you router to factory settings.
Enter a new WPA key to the router and PSP.
Mar 17, 2009 | Compaq iPAQ Connection Point CP-2W...
WRT54GS - freq signal loss!
Sounds like you need to download a firmware update for your router, download the firmware to somewhere like your desktop, then browse to 192.168.1.1 and loginto your router and look for the update firmware link, browse to your downloaded file and update your firmaware, make sure you dont cut the router off or unplug it while it is updating.
Hope this helps,
David
7.2 http://downloads.linksysbycisco.com/downloads/WRT54GS-v7.2_fw,0.bin
7.0 http://downloads.linksysbycisco.com/downloads/WRT54GSv7_7.50.5_fw_US_code,0.bin
Mar 10, 2009 | Linksys Wireless-G WRT54GS Router...
When router set with security key, signal too low, end up on someone elses
desirabledes hello,
Please go to the edimax website and download the most recent firmware to the router:
http://www.edimax.com/en/support_download.php?pl1_id=1
Then, try to update the driver to your wireless lan card, this might be causing the problems.
Oct 12, 2008 | Edimax BR-6216Mg Wireless Router...
Set up
Hi Rbosley,
I found the real manual here,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&cc=us&dlc=en&product=218413&os=228&lang=en&
Second one down.
Are you using Cable, or DSL. DSL requires you to setup a PPPOE connection, putting in your Username and password for you DSL connection.
Are there any other routerrs on the network? Just making sure you are not trying to use the router then there is one already one on the work.
I would suggest your use the reset button on the back, resetting it to defaults. That way, you should be able to plug in your modem to the WAN port, plug your computer into the LAN port.
Then restart the modem, wait 2 min, power up the router, wait 2 min, and startup the PC. Make sure your IPs are set to automatically get IPs and DNS. The router's DHCP should supply them to your PC.
DSL requries you setup a PPPOE connections, which really just consists of selecting the pppoe option, putting in the infomation, and the doing all the rebooting.
It you still are having issues, get back with us!
Jan 09, 2008 | Compaq iPAQ Connection Point CP-2W...
No signal
Is the wireless switch of your pC on? if it is, then try to reboot your PC and the router. You should see one. Check also if the SSID broadcast of your router is enabled.
Oct 06, 2007 | Compaq iPAQ Connection Point CP-2W...
Compaq iPAQ Connection Point CP-2W (241274-001) 802.11b Wireless Access Point Logo
100 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
