Question about Garden
I sharpend my chain and filed and flip the bar around. And it still want cut. Do I need a new bar and chain?
  • 2,239 Answers
I dont me to be rude but two things spring to mind, firstly have you put the chain on backwards? the chain on the top of the bat should have the sharp edge facing away from the saw ( turns clockwise as you look at it from the side of the saw ) and secondly have you sharpened it correctly ( right angles, and taken the depth gauges down to the correct hight ) there should be no need to replace the guide bar, at worst a new chain will do, let me know if you need to know more about chain sharpening.
Posted on Feb 17, 2012
  • 1 more comment
  • Lee Davidson Feb 17, 2012
    Chain is on right and yes I sharpen my chain at a 32 degree. I no what your thinking but this isn't my first saw.
  • Andrew White Feb 17, 2012
    Have you taken the depth gauges down? the cutters all slope backwards so as you remove material from the cutters the depth gauges in effect get higher, if you put a straight enge across the top of the cutters you should have a 25 thousands of an inch gap between the straight endge and the depth gauge, if not it will never cut anything no matter how sharp the cutters are,
    I'll look but I still think I need a new chain
  • 149 Answers
SOURCE: chain comes off the bar while running
check the nose sprocket and the bar groove for excess wear..
Is the chain the correct pitch for the bar and sprocket.
Posted on Jan 15, 2009
steve_lima
  • 181 Answers
SOURCE: Poulan 2375 w/18 inch bar keeps throwing the chain
when you put the chain on new did you adjust the tension on the chain.most new chains need to be ran a few minutes to heat them up a little.then you need to readjust chian so it doesn't sag out of the bottem of the bar,also when you adjust the chain you need to push the tip of the bar down so the bar is in the up possition.if you don't the bar will work it's way up and loosen the chain.
Posted on Feb 24, 2009
  • 6 Answers
SOURCE: saw cuts then stops chain still goes around bar then seems to catch agian then cuts
sounds like the clutch is starting to go out. i have one just like it and the same thing happened to me
Posted on May 22, 2009
  • 23 Answers
SOURCE: chain needs to be sharpend
Look at the chain, theresa 3 there and that number coinsides with file size
Posted on Jun 21, 2009
dontbother10
  • 2220 Answers
SOURCE: Chain keeps falling off bar afterwhen saw is
Reinstall the chain. Do NOT connect power. Mark one link (chalk, crayon, etc.) wear gloves and try to rotate the chain one complete revolution. Is this possible? No - remove the chain and remove burrs from the sides of the drive links with a flat file.
3893c9d.jpg An IPL for your saw can be found here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
Enter "111409" in the "Search for your unit by Model #:" window. Click search. Click "View Model" Click "View Illustrated Parts Diagram"
Yes - inspect the sprocket gear (KEY NO. - 11) pn 111363-01 new pn 122520-01 NLA, is it deeply grooved or perhaps worn through?
I'm going to get smacked as I have so many times before. The only thing RemingtonPower is producing today is unhappy customers. Replacement parts are exhausted. we aren't affiliated and had nothing to do with their decision to stop production.
Burrs on the chain or a defective sprocket are the most likely causes of your problem. If the gear is bad, there are no replacement parts available and I cannot help you further except to recommend you purchase a name brand replacement. Select a company you think will have replacement parts when you need them sometime in the future.
Chain adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system.
Your rating of our help is the only payment we get for this service. I provided as much help as humanly possible. Punishing me for your disappointment with RemingtonPower isn't fair to me. I hope I answered your question. Thanks. A few kind words would be appreciated.
Lou
Posted on Nov 02, 2009
How to correct the uneven cut that happened after reversing blades?
I'm assuming that you are talking about flipping the saw bar over which caused the cut to wander to the side. Remove the chain and inspect the bar edges for any metal caused to protrude beyond the flat face of the bar. Use a file to cut this overhanging metal off (at 45 degrees) so that the edge metal doesn't catch on the sides of the cut. Be sure to clean the bar and chain groove after this procedure. Hope this helps!
Nov 21, 2010 | Garden
Need to know how to change chain on a 14inch McCulloch Eager ****** gas chain saw
Turn the chain adjusting screw CCW a turn or two, release the chain brake, and remove the large nut on the right side cover. The bar and chain will come off after removing the cover. (note: a 16" bar and chain will fit the saw which makes it a little more useful if cutting trees) Be sure to clean the small oil passages in the drive end of the bar that run from the large holes out to the chain groove on each edge. It is common to flip the bar over to equalize chain groove wear. Also, if the outer corners of the bar edges have wear that causes the metal to flare outward, use a file to cut off those sharp edges (at about 45 degrees) so that it doesn't project beyond the bar's flat surfaces. This will help prevent a cut from wandering off to one side. Re-assemble in reverse order after cleaning the engine and cover. You may have to turn the chain adjust screw some more to compensate for the old chain which will stretch with use. Make sure the adjustment 'tang' falls into one of the large holes in the bar before tightening the cover nut down. Hope this helps!
Nov 10, 2010 | McCulloch Garden
Why my chain saw always cuts at an angle
a lot of people have this problem with a chain saw and cant get a strate cut, most of the time its down to them trying to force the saw through the wood and in doing this the saw cuts around corners as there pull is not square to the cut,, let the saw do the work, not you, if your pulling on the saw to make it cut well then it has a very dull or blunt blade,,,is there any side to side "rock" on the chain in this new bar? how have you sharpend it? dose the chain have the same pitch on both side's? are all the teeth cutting at the same depth? if its cutting around corners it could still be the chain pitch worn out, if so the chain is past its best as well, but most of the time its all down to how hard and how squarely your pulling on the blade when cutting,,,the first thing in logging to lurn is to cut squarely no easy task that! just dont force the saw to cut!! it will cut just as fast or faster without forseing it,, if all this still dont get you cutting right change the chain for a new one,,,the only hard work with a chain saw is holding it up to the tree and humping it around not cutting with it, thats the blade's job to do so the faster you try to make it cut the more out of true the cut go's as all your doing is bending the bar out of alinement,,all in all, its two hands for the job and a very gentle pressure on the saw, start the cut with the blade spinning and dont stop the blade in the wood, cut right through
Mar 28, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Doesnt cut straight? I have bought a couple of
The chain groove in the bar could be badly worn. Try flipping the bar over to see if things improve. Make sure the chain is properly tensioned. If better, but still giving problems, then buy a new bar. Chains will do this if they are not sharpened equally on both sides. Good luck!
Mar 26, 2010 | Garden
20" poulan chain saw cuts at angle
Hi
You must have hit a nail or stone with the one side of the chain. When the chain gets duller on one side than the other is what makes a saw cut at a angle. Get the chain sharpened and it should cut straight again.
Sam
Jan 08, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Brand new saw ... (x-mas present) ... chain came off after 9th cut ... I followed their instructions, but chain will still not turn ... and it's NOT BECAUSE IT'S TOO TIGHT? Has the clutch gone out already?...
You will need to remove the chain. Usually, the chain is damaged beyond repair after it jumps the bar. However, sometimes you can repair it with a flat file.
Inspect the chain for damaged links. Usually, the chain guide teeth that ride through the bar slot get damaged. It doesn't take much distortion of the guide teeth to bind in the bar slot. Sometimes, you can file the sides of these damaged guide teeth down enough to operate smoothly.
Be sure you check the tension of your chain after every 3-4 cuts so this doesn't become an issue. New chains will get play in them faster than used chains.
Be sure to also inspect your chain bar/bar sprocket for any damage.
Jan 03, 2010 | Poulan Pro Chain Saw 46cc 20"
The blade cuts part way through a log and then goes side ways. I took it off to see if it had a bend or something with the bar but the bar is straight and does not seem bent.
replace the bar - evidently one side of the bar is worn more that the other part of the rail. the chain twists and runs crooked onthe bar.
Oct 20, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Echo CS370. Just got back from shop. It cuts in an arc not straight down The Echo Logo on the bar is upside down. It was sharpened at the shop but spits out dust not chips.>
it's possible that the chain was installed backward. the cutting in an arc is caused by 2 things. A dull chain and the guide bar being worn into a radius where the chain rides. the guide bar surface where the chain rides needs to be flat and square to the sides. since the logo is upside down this shows that the bar has been flipped to use the other edge of it. the teeth on the chain on the bottom of the bar need to be facing the operator in order to cut
Aug 23, 2009 | Garden
Chain needs to be sharpend
Jun 21, 2009 | Remington Polesaw Wizard
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
