Question about Duravit Home
Hi there just fitted brand new bathroom pull cord.... works but have to pull it three times. Any ideas why ? Thanks Lydia
After fitting the cord it worked correctly twice then switched over to its three pull preference.... ?
  • 3,640 Answers
If the wires are correctly installed, and tight. then you may have a bad pull chain switch. good-day ! but first turn off electric, and see if the wires are not loose and the wire nuts are tight behind light.
Posted on Mar 19, 2012
Coleman powermate vangaurd 9hp. how long is the pull start rope?
no set length on any recoil repair
old one will be stretched or broken
melt cord end for ease of fitting and no fraying through holes
and finishing knots
feed one end into recoil internal through outer and inner casing
then knot
set recoil spring into correct position and tension
cord is at least three times around recoil
leave excess cord out for pull handle and later adjustment
then cut .. melt end .. feed thought pull handle
then adjust as you test recoil off the motor
then fit to motor.. pull a few times
and final adjustment of cord length at the pull handle
Oct 13, 2016 | Coleman Electrical Supplies
Looking to change a travel trailer bathroom sink. Any ideas ?
Hi Caroline:
I don't quite understand what you're asking.
If I did not like the sink, I would measure the space available, then go shopping to see if I could find one that I liked that would fit.
I'd get the dimensions, go back anc confirm that it would fit, go buy the replacement, and proceed to remove and install.
Another project done........ Let's go park by the lake......
Fish............ Beer............ Life is good!
Dec 04, 2015 | Cars & Trucks
What brand plumbing in shower
most taps for bathrooms have replaceable spigots and handles of various design that suit the shaft. I would be talking with a plumber as to what you have and as to why any spigot assy will not fit. Even if you have ceramic inserts they still fit the tap proper.
Jun 17, 2013 | Home
Problems replacing a 2D 4 pin holder fluorescent bathroom light.
I'm sure they made it that way for a reason. Unless you know the specifications will match, don't try to jerry-rig it to fit.
May 07, 2017 | Electrical Supplies
The pull cord on my generator has went slack but the rope still recoils. Has it snapped? Thanks
Hi, this is quite common you just need to purchase a new spring; the spring is what keeps the cord tight and coilled correctly. The new spring is inexpensive and comes with an applicator so its quite easy to fit
Aug 11, 2010 | Garden
How do i replace a pull cord with light switch
Ok so, L (line) N (Neutral) and E (Earth ground), and no idea what this rose is. I suppose you mean Junction Box when you say JB. You can use the original junction box for the wall switch connector, but the Black and white wires coming from the switch must be disconnected from power to be used, if power is already present in your light's original junction box (which is usually the case when using a pull switch light). Then you connect the white and black wires to your wall switch and use them to break the circuit at the light itself by wiring it between the light and the power lead.
Mar 24, 2010 | Plumbing
How to fit POLO PULLOUT SPRAY KITCHEN SINK MIXER TAP 0119 **NDD**
hi i need to fix a pull out sink mixer...but i have no idea how to fix.pls help.thanks
Oct 05, 2009 | Food Mixers
Hi , it about DXG 4-0 Megapixel camera
Could you post where you got your new usb cord from. I lost mine and can't find one any where that will fit this camera.
Thanks...
Steph
Jun 26, 2008 | DXG Technology DXG-409 Digital Camera
Acer apire 3000 a/c adaptor
Why did you have to buy a new adaptor? Did it suddenly stop working or was the problem intermittent?
It's my guess the adaptors are fine - very unlikely all three are bad - It's the connector in the laptop that's the problem - it's loose or was pushed too far in at some point so it can't make a tight connection. A good tech should be able to solder it on the inside. Hopefully, you can return at least one of the adaptors.
Good luck.
May 27, 2008 | Acer SPK 2 PCS 120W RMS 40HZ- 20KHZ BLACK...
Home Logo
166 people viewed this question
Top Duravit Home Experts
Craig Butler
Craig Butler
Paul Carew
Lawrence Oravetz
Are you a Duravit Home Expert? Answer questions, earn points and help others
