Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a ge modle gshf5kgxccww serial #hs417237 99 deg on refrig side -8 on the freezer side, no fan blowing in the refrig side, replaced main board and temp sensors, no change
Compressor is running, freezer is at -8 and the refrigerator side is at 99 and actually starts worming up after it's plugging it in. freezer side is set to 0 deg. and the refrigerator is set to 34 deg. I paid some guy to fix it he said it needed a new main board. So I bought one and put it in, and it made no difference. The instructions said to cut the #2 wire on the 9 pin connector. But it said to do that only if I had bottom freezer. I do not. I have a side by side. So I did not do that. I also bought a new temp sensor. I switched it with each sensor on the refrigerator side. It did not change anything.
  • jeff duprey Feb 22, 2012
    On Feb 20 I removed the defrost heater, still doing the same thing. The fan in the freezer side is running. The fan is not pushing the cold air into the refrigerator side.
    I took it all apart to see if there was a flapper door that was not opening, stuck or had some thing stuck in it. there was no door, It's wide open into the refrigerator side. I have not replaced the temp sensor on the evaporator in the freezer side
5 Suggested Answers
  • 109 Answers
SOURCE: GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Posted on Mar 31, 2008
  • 34 Answers
SOURCE: freezer and refrigerator compartment to cold
Set both settings at 5 and see if it starts working right
Posted on Jan 20, 2010
heatman101
  • 43501 Answers
SOURCE: My GE Profile Artica PSI23SCN
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on Apr 03, 2011
kvhappliance
  • 218 Answers
SOURCE: brought the GE WR55X10942 Refrigerator
Yes you will need to cut the wire the directions states all bottom freezer models and models with certain serial numbers... But you will not need to do other modifications specifically for bottom freezer only models.
Posted on Jul 15, 2011
Ge freezer temp changes from -3 to 44degs and the ice melts and runs on the floor. I replaced the main board about 2 yrs ago, help?
Self defrost mechanism appears to be ok sinc eyou can get down to -3 degrees. The culprit in this refrigerator is the temperature regulator or electronic thermostat in this box. It should not allow the temp to swing that drastically from one extreme to another.
Mar 17, 2015 | Refrigerators
Freezer and refrigerator compartment to cold
Jan 20, 2010 | GE GSS25LGM Side by Side Refrigerator
I have a GE side by side fridge. First the water would stop working intermittently. Then the ice and water stopped all together. Now on top of that its making a clicking noise and the freezer works for...
Your model needs attention soon to prevent damage to the control board. Something simple as a fan going bad will cause a chain reaction on your model. Let me know if you would like my assistance or your you would like to call in a technician. I can help you repair from here or my site. Thanks, Sea Breeze
Nov 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram ZISB36DYB Freezer Not Cold Enough; Burning Center
Pull the refrig out , and remove the panel at the bottom , on the back . Behind this panel , will be the compressor and condenser " roll " coil , and the condenser fan motor . From your description of the problem , the fan motor in not operating , or the coils are extremely clogged with dust . If the fan motor is not operating , the most likely cause , is the main control board . You can try replacing the motor first , but , the board is most likely the cause . This is the electronic board , behind the 8 " X 10 " panel , behind the refrig also . If you remove the panel , and look at the board closely , You may see a burned part ( resistor ) . However , replacing the burnt part , will not solve the problem . The complete board will need to be replaced .
Oct 14, 2009 | GE Refrigerators
Neither side will cool
If there is no frost on the rear wall , inside the freezer , then the main control board is bad . This board , is located behind the refrig , behind an 8 " X 10 " panel . The part number is WR55X10656 . This board , probably has a burnt compressor module , keeping the compressor from running . The board is easily replaceable .
Oct 05, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Gsl25jfpa bs fridge is warm on top and frozen on bottom and freezer is warm
It sounds like the fan in the freezer is not working , to circulate air , and the coldness is just dropping . This will cause the icemaker to stop working first , then the top portion of the refrig next . As this coldness drops , the lower portion of the fridge ( crispers ) , will freeze . The main control board , causes the fan , not to run . Part Number WR55X10656 . The main control board , is located , behind the refrig , behind an 8 " X 10 " , small panel . There is usually a burnt resistor on the board , which is connected to the fan . Unfortunantly , the whole board will need to be replaced . It is easily replaceable . Doesn't take any special knowledge . All the plugs 6 or 7 , each fit the pin plug designed for it .
Oct 03, 2009 | GE GSL25JFPBS Side by Side Refrigerator
What turns on the evaporator fan? I have a 5 year old GE profile bottom freezer fridge. I have discovered that the defrost timer is faulty. The defrost heater works and the evaporator coils frost up ok...
The main control board is probably the problem . Part number WR55X10656 . This board controls the operation of the fan motors and everything else on the refrig . This is also the " defrost timer " . However , the coils frosting up , is probably because the fan motor is not pulling air across them . Not because of a faulty " defrost timer " . This board is located on the back of the refrig , behind an 8"X10" panel . Usually a resistor burns out relating to the fan motor operation . Cannot replace the resistor , only the board .
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model GSS25TGNB CC died
If you do not see frost on the inside rear wall of the freezer , Poll the refrig out from the wall , and remove the back panel covering the compressor . If the compressor is not running , Remove the 8" X 10 " panel , just above the large panel first removed . Unplug the refrig . Remove the control board , and on the other side of the board ( soldered side ) , look just behind the small black boxes ( located on the other side ) and look for a joint which has become unsoldered . Resolder this spot and reinstall the board . Plug the refrig back in , and see if compressor starts . OR , you can replace the control board pt # WR55X10656 .
Sep 19, 2009 | GE Profile Arctica Stainless Steel Top...
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Noisy air flow problem, I think
the GE refrig has a variable speed fan motor controlled by the mother board located on teh rear of you refrig. the noise your hearing is the fan speed ramping up and down. if this noise is constant its possible the contoller on the mother board is bad and the board needs to be replaced. hope this helps...
Dec 07, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
134 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
