Screen resolution - Picture too big for screen
I purchased a 50 in panasonic plasma HD. When I watch regular TV the heads of people are cut off,when I watch sporting events I can't see the header at the top or bottom that gives the stats (i.e. qtr, inning, score, etc).
What can I do?
    Scholar:
  • 136 Answers
Give the model number of your tv.
Posted on Oct 25, 2008
  • 2 more comments
  • ready2helpu Oct 25, 2008
    There are typically to ways some folks handle this (to me, both are unacceptable, but not to others). One is generally called "stretch mode." That horizontally elongates 4"3 broadcasts, making everyone fatter and squished looking. Another one is generally called "zoom mode." this produces no distortion but at the expense of cropping off a good part of the picture (generally the top and bottom).
    Generally speaking, both the TV and the STB have such capabilities. There are some situations where you can't seem to do it on one device, but then there's the other device.
    There IS one situation where I DO use such controls. Even before HD, I'm sure you noticed that some shows were letterboxed (black bars top and bottom). I call that "faux widescreen." Gave you the "feeling" of widescreen while you didn't have a widescreen display. This is till going on... example, Rescue Me on FX. On a HD, because it's a SD channel, it comes in 4;3 so black bars on the sides. It's faux widescreen, so black bars top and bottom. I DO use the zoom mode here because much less gets cut off than a full 4:3 image.
    Thanks for the information and taking the time to reply. But again, the problem is in the Cablebox. If I disconnect the cable from the cablebox and plug it directly into the TV, I can use the remote control that cam with the TV and can change the size from Normal, to Streech, to Fill, and to Full. No problem - exactly what I want to do. But as soon as I connect the cable to the cablebox - I loose all control of the screen size. I get a full screen picture when I view an HD channel and the screen with the black stripes down the sides when I watch any other channel.
    The first thing you need to do is enter the Panasonic service menu. This requires your remote (often, programmable remotes are a pain for this; the original remote is recommended). Then, follow these steps:
    1. In the setup menu, set the antenna to "cable."
    2. In the timer menu, set the sleep time to 30.
    3. Exit all menus and tune to channel 124.
    4. Adjust the volume (on the TV, not your receiver) to 0.
    5. Press the Volume Down button on the television set panel until a red CHK appears on the screen.
    Once you're in this menu, you should know how a few buttons on your remote function, until you exit this menu:
    • The TV/Video button changes video inputs.
    • The Power button (on the remote) toggles menus.
    • The up, down, left, and right arrows are used for navigation.
    Once at this point, you can actually fix this power glitch once and for all.
    Fixing the Picture
    Here's what you need to do:
    1. Move the cursor to VER and press the Enter button on your remote.
    2. Select 16:9 (you are able to choose either 4:3 or 16:9), and press Enter.
    3. Unplug the TV set.
    4. Wait 60 seconds.
    5. Plug the television back in.
      TIP
      When you plug the TV back in, it should still be in service mode.
    6. Save your changes and exit the service menu.
    Things should work normally now. The key thing to look for is that curved image, and check out the top and bottom of the picture. If you can see those news tickers, you're all set.
    http://oreillynet.com/pub/h/4199
    check out this link for more detailed help.
    To those with problem with the picture being cut off, you can actually enter service mode to adjust it manually! :D Just follow these instructions: Power on your TV Go to menu and set antenna to CABLE Then, go to sleep timer in the menu and set it to 30 Exit menu and go to channel 124 Then, adjust volume to 0 on the remote Then, at the front of the TV, press the volume down and the word "CHK" in red appears Finally, press the power button on the remote You will then see a big service menu at the middle of the screen To adjust, use the volume buttons to adjust the values. To change each category, use the channel buttons. To exit the service menu, press the power button on the remote, and it will return to "CHK" in red at the upper left hand corner. Then, press the power button at the front of the TV to turn off the TV. If you want to see a summary or self-check, press the power button and action button at the same time for two seconds instead. Don't forget to copy down all of the original values on a separate piece of paper before you adjust the values. I'm still browsing it, but I don't have the time to adjust the screen right now.
  • 13,433 Answers
The resolution from the source is set too high, also check the settings in your television it may be set too high.
  • Ekse Oct 25, 2008
    can you post me the model of your panasonic, and details of the video source so I can get you some instructions on how todo that.
My panasonic plasma TV screen will light up, but no picture shows.
Have you tried replacing the cable? They can cause all sorts of trouble.
Oct 19, 2015 | Panasonic VIERA TC-P50U50 50-Inch 1080p...
How come the top and sometimes the bottom of my screen are cut off
Not all bradcast are in 16:9 resolution (wide screen). Most are still in 4:3 (old TV).
Sometime the advertisements are in 16:9 letterbox to project correctly on 4:3 TV and TV logo or titles are on the bottom or top of the picture. If TV is set to project wide screen, these logos or writings will be cut off.
If you have an option to switch TV resolution from remount, you will see whole picture.
Check your TV manual for settings.
Dec 20, 2010 | Panasonic TH-42PX20U/P 42 in. HDTV Plasma...
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
I have HD hooked up to my TV. As of yesterday,
Did you try to reset the picture settings in the menu? Do you have the same problem with other inputs or just the HDMI input?
Oct 16, 2009 | Panasonic Viera TH-50PX80U Plasma TV
Just bought a 50 panasonic viera, when we hook up ps3 on hdmi cable, we have sound but no picture.
Plasma TV normally do not have the resolution required for PS3 unless the plasma TV is fullHD( 1920x1080p) pixels.
HD Ready Plasma = 1024 x 768p
PS3 Outputs = (fullHD)1920x1080 or (HDReady) 1280 x 720p.
LCD TV accepts the resolution matches the resolution the PS3 is outputting.
Feb 28, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Lenovo T60 interfacing with Vizio HDTV using RGB cable
The X1400 supports Full-HD resolution. Full-HD/True-hd (1920x1080)
The best output would be via DVI but you are limited with the VGA port.
I would purchase a Grand Hi-Wire PC to HDTV converter from www.globalcomputer.com. Item # G126-1036 @ $139.99
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 04, 2008 | Computers & Internet
Screen resolution to big for plama screen 50
You need to first let me know what you are using for a source and then check the TV setting for the format and make sure it is on normal
Oct 26, 2008 | Televison & Video
High Definition Channels leave bar on top and bottom
More then likely it has to do with the aspect ratio of what you're trying to watch. Most DVD's are in widescreen format (2.40 to 1) like you would see in a theater but an HD tv is a 16 by 9 format or 1.85 to 1. Look at the DVD case and see. Also some HD shows are in widescreen so you'll get the same thing. You're only option to fill the screen is get movies in 1.85 to 1 or use your zoom functions however these do tend to distort the picture.
Feb 17, 2008 | LG 50PX4DR 50 in. Plasma TV
Color settings
go on the menu then after it appears press on the picture then just sttart moving the settings till u get the right stting on the tv
Nov 03, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Televison & Video Logo
480 people viewed this question
Top Televison & Video Experts
