Question about LG Washing Machines
Towels are getting ripped in washing machine brand new lg
  • 210 Answers
SOURCE: lg tromm front load washer machine
Try using www.affresh.com, in the wash using hot water. If your unit has a tub clean cycle use it. Leave the door open after using the unit to allow it to breath and wipe down the gasket. Use HE detergent and you don't have to use too much. That goes for the fabric softener as well.
Sgt 48
Posted on Jun 18, 2008
MNTECH
  • 1543 Answers
SOURCE: My front loading LG washing
Once the dingy look gets into them, it seems to be impossible to get out. It is caused by using too much soap and / or fabric softener. Remember, your front load LG is using only about 12 gallons of water to wash those towels. Your old machine used as much as 45. This means that all wash loads need to use less soaps and fabric softeners. Use 1 tablespoon of regular HE detergent for standard loads. (only a teaspoon if it is 3X HE) Only a teaspoon of fabric softener when you use it. Which brings me to towels. If washing bathtowels: You are clean and rinsed before you use the towel. The towel is not getting dirty, only soaking up the clean water off your body. Hang them on a towel rack and use them several times before washing, and when you do wash bath towels, most of the time you do not need any detergent, as they are really not dirty. Of course you should know that you never use fabric softener on loads of towels. Now, back to the dingyness. The dingy stuff is residual soap / fabric softener in the fabric, which once machine dried seems to be impossible to remove. If they are white towels, make sure to use liquid bleach and you might try to use a little Mrs. Stewart's concentrated liquid blueing in the fabric softener dispenser to see if if might help. Most likely you will have to try a few new towels, washing with no soap or fabric softener when laundered.
Please don't rate this, as it is really just informational, not what most people would call a solution, and any rating other than FixYa drops my score.
Note: If you wash some previously washed towel, using no soap, you should not see any soap suds in the washer. If you do, you are seeing soap left over from the previous washing of the towels or soap from build up on the outer washer tub. Use Whirlaway or AhFresh on tub clean cycle or at least the longest hottest cycle you have, and start using the correct amount of laundry additives. (also will help prevent odor issues)
Posted on Nov 23, 2008
odiebugs
  • 949 Answers
SOURCE: My Sears Kenmore, 2 years old washing machine is ripping clothes
If this has a paddle,check it for a sharp edge,also make sure it is not loose, the top cap should be able to be pulled off to see the locking
bolt,and you can check to see if it has loosened.
Feel everywhere on the inside of the washer for a edge that might be catching your cloths. You can also try the gentle cycle and see if it does not rip them.
You did not post the model# ,so I have no clue what style it is.
Posted on Apr 07, 2009
  • 111 Answers
SOURCE: SMELLY TOWELS!
rinse your towel in vinegar and then use it with your washing machine
Posted on Sep 18, 2009
  • 343 Answers
SOURCE: I bought a second hand LG washing machine -
Check that the "transit bolts" are not holding the tub to the body. They are there to stop the bowl from bouncing around during transport.. Located at rear.... To check, see if you can feel easy movement between bowl and cabinet..If the bowl movement is restricted, unscrew the 'bolts'...Good luck....Nomess
Posted on May 19, 2010
Stop Kenmore 700 series top loader from ripping small holes in towels?
Look for damaged rotor, possibly small dents with sharp edges or cracked unit that catches the clothes.
Feb 17, 2015 | Kenmore Washing Machines
What causes towels to become frayed along the edge of the towel, and shirts to have little holes in them - half the size of a pea - when I taken them out of the washer?
mine some times does it try not to overload the drum with washing as it doesent have enough room to move so the washing rubs against itself causing holes rips and fraying
Aug 16, 2014 | Washing Machines
WM3987HW
There are two solutions to this problem. 1. The load of clothes is not balnced correctly in the drum/or you are putting too many clothes in the machine. 2. The bearings have worn and have given up. These bearings cost more than the machine too repair as it is a huge job, also, most "technicans" will rip you off. If it is option 2, I recommend buying a new machine(as you can't replace them yourself without all the expensive tools). Buy a machine with the longest warranty and a descent brand. Don't be fooled by buying machine made in ITALY(eg. ARISTON) as Italy make junk these days, they only ASSEMBLED in Italy. Most parts are from Slovenia etc. Made in China is fine with washing machines. best bang for your buck is either SAMSUNG or LG frontloaders.
CHEERS.
Apr 30, 2014 | LG WM3987HW Front Load Washer/Dryer Combo...
Dishes not dry
No they don't do they. Even if you don't use "Sanitize" or "Air Dry". The water doesn't get that hot either if you haven't noticed. With the new "replacement" machine, even after it's done I can't touch the dishes for several minutes. But the LG made that little jingle indicating it was done. There must be an easter egg somewhere that tells the machine to dry. Whatever you do, go and buy Dishwasher Booster, whether your store carries "Affresh" or the Oxy Clean brand, use it every cycle with your washer. You'll thank me. Your problem probably isn't listed under troubleshooting either is it? Just hang some paper towels or a dish towel nearby and expect to dry your dishes when the machine is finished washing them.
Apr 20, 2014 | LG LDS4821ST Stainless Steel 24 in....
Bosch WFF2001 - various problems
Replace the washer is my suggestion.
Jun 25, 2017 | Bosch Washing Machines
My LG Turbodrum DD will not drain
Get a new machine. LG washing machines are ****. I have the same model and it has broken down and made horrible noises for years. It finally just stopped working. RIP
Feb 11, 2010 | LG Washing Machines
SMELLY TOWELS!
Sep 18, 2009 | LG WM-2277HW Front Load Washer
Apr 07, 2009 | Kenmore Washing Machines
My front loading LG washing machine doesn't seem to wash as well as I had expected. Actually the only things that I have noticed this in is the wash cloths and towels. They are getting a gray dingy look to...
Nov 23, 2008 | Washing Machines
Sour smell on towel after washing them
That is comon with LG.
Clean out the filter in the front.
Than take an OLD towel.
Wash with chlorox first a hot load. After that do the same but than with vinegar and that should take care of the SOUR problem
I have an LG too.
Jun 19, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
295 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
