Question about Hilti Drills
I have a TE 74 and it has just stopped hammering, the motor still runs ok but no hammer action, any suggestions?
  • 2,176 Answers
Could be quite a few things. e.g. stuck ram worn o rings and seals. I would suggest calling Hilti direct at 1-800-879-8000 for a service center nearest you. These are not the most user friendly tools to repair. It can be done but trust me it is a pain.
Posted on Mar 01, 2012
  • edwin Aug 10, 2013
    what grade oil does the hilti 74/75 use
rowdy45176
  • 2176 Answers
SOURCE: te-5 rotary hammer i need parts
Call Hilti direct at 1-800-879-8000 and speak to them. They can fax or ssend you a breakdown of the tool list. They will also sell you parts. I don't know of an outside source for Hilti parts. If I have helped you would you please rate my response accordingly and Thank you.
Posted on Aug 25, 2009
97F350diesel
  • 1326 Answers
SOURCE: I have a Macallister Hammer drill Cod 144vchd and
The chuck may be frozen, try applying some oil inside it. If that doesn't work it will need to be opened and inspected for any damage or frozen gears. You always want to rotate the settings every so often to avoid something like this happening. The metal gears sometimes freeze/seize after being in one place too long.
Posted on Aug 28, 2009
  • 1383 Answers
SOURCE: I have a hilti TE
The hammering action is caused by air cushion between driver piston and striker piston.
A lack of lubrication will cause this or too much grease has entered cylinder or hammer is stored with nose of hammer up. To much, or little grease, or old dirty grease will cause poor hammering action because the striker piston cannot move all the way to front of cylinder (when you slam tool against the work, you are actually forcing the striker closer to the bit). Clean both pistons and apply fresh grease, also make sure orings on these pistons are in good order. If you think that the grease is ok, then try storing the hammer with nose down and bit removed so that the striker will creep down when still hot and be in the right position for next use /cold start. Good luck
Posted on Apr 14, 2011
  • 123 Answers
SOURCE: Hilti TE 17 Rotary Hammer repair switch fix
If you are talking about the wire going from the switch to the stator it difficult to get to. You have to remove the motor end cap, cooling fan and handle holding the switch. this will get you to the brush holders. These can be brittle so you need to be carefull. Turn the motor over and tap the end of the armature on concrete checking the brush holders every couple of taps to see if they are coming out of the motor housing. after they clear they will just come out. If you havn't done so already remove the wires going to the brush holders. Your stator will simply slide out after your brush holder comes out. This will give you access to the wires to repair.
Hope this helps.
Posted on Oct 29, 2009
Testimonial: "worked well for me"
ftw1952
  • 10319 Answers
SOURCE: Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Posted on Mar 11, 2010
Hilti TE 74 not hammering
It takes 70 cc of oil in the gear casing. Too much oil will snap the connecting rod. If it did not have oil in it there might be a leak somewhere
Nov 06, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Brand new te-7c and hammer action is not working Please help
are you using the right SDS bits? second there is a selector on the side for heavy hammer, light hammer and drill only, make sure that you have the selector in the proper position and then you would need to apply slight pressure to the bit for the hammering action to start, if youhave done all these I would take it back for warranty replacement or repair. Hilti is very good about warrantys.
Aug 31, 2011 | Hilti TE 7C 120V Rotary Hammer Drill...
Need on/off switch for Hilti TE 17 Hammer Drill
Parts for the TE17 have been discontinued for over 15 years. The switches and the oilite bearings for the motor were the first to run out.
Jan 07, 2011 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
Hilti drill want hammer.
Not positive but I think that it works on air. Is there a cylinder with a piston in it. The orings could be blown?
Im not positive. Just tryn to help
May 30, 2010 | Hilti TE 70 Hammer Drill Performance...
Drills but dont hammer te 74
Hilti no longer carries parts for the 74. However most of the TE75 parts will interchange with the 74
Jan 31, 2010 | Hilti Drills
Demolition tool or breaker
The shaft from the motor to the drive gear is likely not working the action of the hammer. There is a gear which spins the gears to achieve the hammer action, suspect the gear is either stripped, broken or both.
Jan 17, 2010 | Dewalt D25330K 2KG Sds Plus Demolition...
No hammer effect, motor work OK
First try the switch for hammerdrill/drill action. If it feels loose, then its internal. if it feels ok, then your hammers on the cage are stuck, frozen or worn.
Jul 17, 2009 | Hitachi DH38YE 1 1/2" Spline Rotary Hammer
My hilti te 6-s stopped working trigger looks to be ok. wondering how to test trigger and motor to be sure niether is the issue. thnx
I would first check the cord to the switch and then the 2 wires coming from the motor to the switch to see if they have continuity. UNPLUG tool first. to be on the safe side remove the bottom cover 2 T15 Torx screws and look at the brushes also and while apart if you have compressed air blow thru all the openings. The switch is hard to check so I would check everything around it first and if OK I would say a bad switch.
Apr 07, 2009 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Rotary hammer won't rotate, hammers very good
Unscrew the brushes and take a look at them. It sounds like you need new brushes.
Apr 06, 2009 | Drills
Drills Logo
424 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
