Question about Dell Inspiron Mini 10 Netbook Computer (Intel Atom Z520 160GB1GB) (dndofm61)
The boot selection failed because a required device is inaccessible on a Dell inspiron mini
How to repair
  • 11800 Answers
SOURCE: Dell Inspiron 5100 will not boot. Error ide
The hard disk is dead, it must be replaced and Windows reinstalled .
Posted on Oct 28, 2009
Testimonial: "Thanks, sad but true. It is an older laptop and was bound to need an upgrade. Thanks again."
  • 113 Answers
SOURCE: Dell Inspiron mini10
check if keyboard works during dell logo - try to press F2 or F12 - if no response need to replace keyboard
Posted on Feb 26, 2010
  • 3940 Answers
SOURCE: How do I boot this Dell Inspiron 1440 in Safe Mode?
F8 at boot
or
MSCONFIG, Boot.ini tab, check safeboot (You will need undo this to boot in normal mode)
Posted on Apr 22, 2010
  • 1149 Answers
SOURCE: My Dell Inspiron 6000 won't boot up. It keeps
Hi:
The DST error code 1000-1046 is definitely a failing hard drive. ..I am not sure why your laptop is not recognizing a CD in the drive, but you should go into your BIOS settings, and in boot sequence, make sure that the CD drive is the first boot device. If you can't boot from a CD, you are not going to get very far with installing a new hard drive...
Posted on May 02, 2010
Testimonial: "Great advise. Thank you!!"
PCTechOnline
  • 532 Answers
SOURCE: loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
Posted on Jun 10, 2010
Dell-n5050 laptop; windows failed to start; code-0xc000000e; boot failed because required device is inaccessible. I have Dell OS media stick. and is there a free fix for this problem?
That code is a Windows boot error. I'm not sure what you can do with the Dell OS media stick but the traditional solution with a regular hard disk is to take a Windows 7 OS disk, boot with it, and run startup repair. Here's a link to Startup Repair: Startup Repair Microsoft Windows
Apr 01, 2015 | Dell Inspiron N5030
CODE Oxc000000e. says required device is inaccessible. i have the Dell os and recovery and restore key. what do I do next
your bootmgr is not working right,it cant boot up,download this and put it on a cd and run it, EasyBCD
Google com
Possible hdd failure or a damaged file.
Windows Boot Manager
Windows failed to start. A recent hardware or software chance miht be the cause. To fix the problem:
1. Insert your windows installation disc and restart your computer.
2. Choose your language settings and click "Next."
3. Click "repair your computer."#
Status: 0xc000000f
Info: The boot selection failed because a required device is inaccessible.
Aug 04, 2014 | Acer Aspire Computers & Internet
I keep getting error 0xc000000F on Acer Aspire One D257 laptop. Ive researched and keep hearing the best option is to download the repair tool. But when i boot up my computer it goes to windows boot...
Usually if the message "a required device is inaccessible" then there is a problem with the hard disk, maybe if the HDD can be test with manufacturers test software, otherwise you have a faulty HDD and it needs to be replaced.
Jun 09, 2014 | Acer Aspire One D255-2670
Hi, my dell laptop having problem I have a
Press F8 when starting up to get into safe mode, then use system restore to revert back to a previous working state
Aug 10, 2013 | Dell Inspiron Computers & Internet
Dell Inspiron mini 10. The system will not boot up, after the Dell logo screen and blue bar goes away, the screen is blank and the curser is flashing in the upper left corner of the screen. F11 isn't...
That cursor indicated that the BIOS can't find an Windows installed on the hdd. Since even the recovery partition appears to be inaccessible the only thing left is to reinstall it using the recovery cd that should have come with it when you bought it If you don't have it you can order it from Dell.
Sep 01, 2011 | Dell Inspiron Mini 1012 Netbook...
I9 cant get my vista - hp pavilion desktop to
u have to run recover cd, which will boot from cd. A. 1. repair - click / select the repair option. 2. it will repair operating system files. it will automatic restart after repair, than remove the cd and boot the system.
B. 1. If u don't have any data in C drive u can format the drive 2. install the operating system freshly 3. u should have drivers cd's . rgds, Manju
Apr 15, 2010 | E-Machines eMachines W2686 PC Desktop
Fomating dell inspiron mini 10
You can make a bootable USB stick with everything you want and boot from it.
Stelios.
Feb 21, 2010 | Dell Inspiron Mini 10 Notebook
I have a mini dell and the sign in box is dissappear
is that the sign in box for you to login in windows? if yes then;
1. restart laptop
2. boot in safe mode. keep tapping on f8 then select safe mode. if fails
3. keep tapping f8 then select last known configuration, if fails
4. keep tapping on f8 then select startup repair. You can also access startup repair using the windows disc came with the laptop.
Sep 16, 2009 | Dell Inspiron mini 9 - Black , IntelĀ® Atom...
You're getting that error message because the boot files on your hard drive (the required inaccessible device) are corrupted.
When first booting, press F8 repeatedly. Will the computer let you go into safe mode? If not, without the installation cd, you're kinda between a rock and a hard place. However, you can download a (free) vista recovery disk (repair only) from the people at easyBCD:
http://neosmart.net/wiki/display/EBCD/Recovering+the+Vista+Bootloader+from+the+DVD
Just follow the directions to do a start up repair.
If that works, by all means, make yourself a recovery cd before doing anything else.
Jan 26, 2009 | Microsoft Windows Vista Ultimate Edition
Dell Inspiron Mini 10 Netbook Computer (Intel Atom Z520 160GB1GB) (dndofm61) Logo
100 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
