Laptop Overheats My laptop overheats and shuts down very often.
  • 32,281 Answers
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Posted on Feb 17, 2012
  • 272 Answers
SOURCE: LAPTOP OVERHEATS AND COMPLETELY SHUTS OFF
Have you cleaned it lately? If not that's what they sell those cans of compressed air for. With your computer off bloe the air through all of the vents you can locate to get all of tha accumulated dust that is blocking the airflow out of there!
Posted on May 25, 2009
  • 60 Answers
SOURCE: zd8256ea heating problems
If your comfortable with disassembling the machine then i suggest you Clean the CPU, HSF and apply some clean Silicone. Also there are fan controllers available for download which will force the fans to full speed. Failing all of that you can buy Antec or similar Notebook coller fan which sits underneath it with a large quiet fan to keep it cool.
Posted on Sep 04, 2007
micromend
  • 748 Answers
SOURCE: M6307 Gateway Laptops overheats and shuts down
Have you called Gateway? This is definitely a mother board or CPU problem, both probably caused by a slow acting fan. Gateway should replace these.
Posted on Jan 05, 2009
  • 8 Answers
SOURCE: model mt3422 laptop overheats,and shuts down
use an external usb burner
Posted on Mar 10, 2009
DJ Wildman
  • 10 Answers
SOURCE: toshiba A65-S1062 - This laptop overheats and shuts down.
I bet that you had your laptop on all the time.
Your heat sink is saturated with dust and grit.
you may have to open up the unit and use a can of dust remover to clean the fins on the heat sink out. it is causing your CPU to shut down bucause it is becoming overheated.
Happy Fixing =)
Posted on Jul 11, 2009
HP Pavillion tx2-135dx laptop overheats
hi.Fan Always Runs Or Laptop Overheats And Shuts Itself Off
Warning! Before Disassembling Laptop always unplug power and remove the battery.
Laptops that shut down without warning are often experiencing overheating issues. Overheating may be a symptom of age, of clogged ventilation or impending failure, but it can also result from simply using the laptop in a bad location. Before you try to take the laptop apart to look for problems, it pays to patiently troubleshoot the symptoms and see if an easy fix is possible. I wrote The Laptop Repair Workbook to teach basic laptop technology and troubleshooting to regular people and techs in training. The overheating flowchart below is one of twelve flowcharts in the book.wfwmoavismn7iaaaaasuvork5cyii=
May 09, 2014 | HP Pavilion Computers & Internet
Eee 1015PE is overheating and shutting down
Is the fan working? You will need to replace your fan if it's not functioning. And don't use it in that condition, you risk damaging it everytime it overheats
Nov 17, 2012 | ASUS Eee 1015PEM-PU17 Netbook
Aspire 5738-6444 overheats
you have to open your laptop and clean all dusts sticked to the heat sink. this will solve your problem temporarily.
Feb 08, 2012 | Computers & Internet
The laptop overheats and then shuts down
Hi joshua1156,
Your laptop fan is not working. That's why the laptop overheats and shuts down. Replacing the fan will solve your problem.
Thank you for using fixya,
Arun Zac
Nov 26, 2010 | Gateway 7320GZ Notebook
Toshiba satelite P105 laptop pc problem: overheats and shuts down automatically. while in use. What are the causes of overheating?
Normal 0 When a CPU chip overheats it shuts down (thermal overload) and won't boot up again until it has cooled down. If this problem is not fixed, then eventually the CPU chip will fail. This fault is either a faulty fan or the fan and heat sink assembly is clogged with dust. Please click on this link and follow my instructions to fix :-
http://www.fixya.com/support/r5959377-overheating_computer
Oct 16, 2010 | Toshiba Computers & Internet
I have a compaq presario f700 and it never overheated until one day i played a game on ninjakiwi.com called SAS zombie assault 2. Now when i listen to music on windows media player or watch videos on...
Insufficient information, but try this for starters:
Make sure the laptop sits on a hard surface and the fan vents are not covered/clogged.
1) Run windows only on a fully charged battery and see if it overheats
2) If not, run media player only, and look for the same
If it overheats in either step, you have a hardware/software problem.
Hardware problem could be that the fan has failed completely and needs to be replaced.
Software problem could be incorrect fan settings, although I do not think you can turn the fan OFF on a laptop.
IF the laptop overheats in Step 1, I would definitely suspect a hardware problem. In that case, run the laptop but do NOT log into windows. Go into the BIOS (check fan settings in there, if there are any).. leave it running in BIOS and see if it overheats then.
Aug 18, 2010 | Computers & Internet
Laptop Compaq Presario F 700 overheats easily and shuts down
When the CPU overheats it shuts down (ie thermal overload) and won't startup until it has cooled down. This problem is caused by faulty fans (with bearing problems and may not spinning at normal speed) or the fan and heatsink assembly is clogged with dust.
Check the vents and fan and vacuum and remove the dust.
If the laptop is not placed on a flat surface there may not be enought air entering the vent on the bottom of the laptop.
To improve ventillation, you can stick rubber pads on the bottom of the laptop to increase the height of the laptop off the table. Better still purchase a laptop fan assisted base and place the laptop on this base, this provides further fan assisted ventillation.
Aug 26, 2009 | Compaq Presario 700 470024-192 Notebook
I just got a webcam and my laptop overheats what
You need to buy a laptop cooling fan. Not expensive. This is a must so you don't burn out the components on the laptop or oops! laptop no more....
Jul 16, 2009 | Dell Inspiron 1501 Notebook
Toshiba A65-S1062 - This laptop overheats and shuts down.
Happy Fixing =)
Jul 11, 2009 | Toshiba Satellite A65-S1062 Notebook
Computers & Internet Logo
376 people viewed this question
David Payne
David Payne
