Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Flashing filter on hunter 44155 thermostat - Hunter Fan Company 5/1/1 Programmable Thermostat
3 Suggested Answers
Crossedwires
  • 44 Answers
SOURCE: how to wire hunter 44155
Go to the hunter web site. They will have the proper wiring diagrams on the site. If you cannot do that pick up a basic wiring book at your local electric parts supplier. the place you got the thermostat would be a good start. I do know that menards has some books in the electric area that would be a great help to you. You also will need to be sure that the thermostat is able to handle both air and heat. many only do heat. If this does not help let me know and I will try and get more information to you
Posted on Feb 09, 2008
SOURCE: hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
Posted on Jul 13, 2008
The word filter keeps flashing on the thermostat. Why?
Filter change indicator - will flash after 400 hours of system use as a reminder to check or change your filter. Press and hold the Filter button for 3 seconds after changing the filter to reset the filter timer. (Pressing the Filter button for less than 3 seconds will cause the Filter change indicator icon to appear. The filter timer will not be affected unless the button is held for more than 3 seconds.) Note: Clearing the Filter counter will also clear the Energy counter.
Feb 18, 2015 | Hunter 44360 7-Day Programmable Digital...
Hunter set and save prorammable thermostat 44155 want shut off at desired temperture. I have the thermostat set at 80 during the daytime when I am not home and 78 for evening and night. The thermostat will...
Possible that the sensor is not reacting and so does not set to the data required in the program. Try and see what is the error factor for the switch on and off which will give an indication of the sensor error. If so this must be replaced. otherwise you can use the error to set it likewise., higher or lower.
Sep 29, 2011 | Dryers
Regardless what I do I can not reset the change Filter message and this is a problem on both of my 44660 thermostats. I followed the proceedure in the manual.
I have a solution!!!! Ok, hit the filter key. You will see the filter counter screen. Hit and hold the RET/CLEAR key until the Filter flashes and it clears the counter. I just found it by trial and error. I wrote it inside the cover so I could remember.
Oct 03, 2010 | Hunter Fan Company 5/1/1 Programmable...
Flashing time on a Hunter Programmable Thermostate #44665
Teresa
have a cental air guy in for a check up on your units. they may need servicing
Jul 22, 2010 | Hunter Fan Company 5/1/1 Programmable...
My hunter thermostate keeps flashing a 4 and wont turn on !
hunter thermostats are not the highest quality. on the back of the thermostat there should be a not well identified reset button. You can locate and push this to attempt to fix the problem. Or purchase a new (i would suggest Robertshaw or braeburn) thermostat and install.
Dec 14, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44155c wiring from manual thermostat
Jun 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
Flashing re co
Re Co stands for Recovery Mode. That means if you have programed your thermostat to be at say 72° at 5:00 then it should kick on in Recovery Mode several minutes before 5 in order to reach that temperature. This is normal and doesn't indicate that something is wrong, just that your thermostat is trying to reach or recover the programed temperature.
Feb 08, 2008 | Heating & Cooling
How to wire hunter 44155
Feb 07, 2008 | Hunter Fan Company 5/1/1 Programmable...
Programmable Hunter Thermostat
hi
this site as the owners manual you can download in pdf . if this helps you out .
Programmable thermostats at discount prices at hunter-thermostats.com.
riz.
Nov 14, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
231 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
