Technics su-g75 receiver not getting regular stereo output when in stereo mode surround sound works fine but when listen to stereo only plays out center channel and subwoofer why? Please help.
furion187
  • 54 Answers
SOURCE: 4 ohm and 8 ohm speakers
You can plug in higher ohm speakers , the higher the ohm the higher the resistance is, it is a danger when you plug lower ohm speakers into a higer ohm Amp , at a high volume that will cause them to blow , the center speaker would be fine to use a higer ohm speaker , your best choice is to buy a Active Subwoofer, which means the sub has it's own power supply , and u can blast the thing as much as u like , thn u can turn the bass down on all the other speaker's so u can play it louder , and have the sub turned up has high as u like , this is the best way to get great sound with high volume , buy a Active sub woofer , any active subwoofer is ok , a active sub woofer has its own volume and inputs on the speaker ,
Posted on Dec 09, 2007
SirHanz
  • 145 Answers
SOURCE: subwoofer connection
if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
Posted on Jan 29, 2008
  • 4 Answers
SOURCE: Center, and rear surround speakers
Sounds like the rear volume is just turned down. Cant be the amp if the front and subs are working
Posted on Dec 09, 2008
ravichetty
  • 158 Answers
SOURCE: home stereo
POSSIBLY THE AUDIO IC IS BLOWN
Posted on Feb 10, 2009
  • 121 Answers
SOURCE: dayton sub-100 connection
You have it upon one of several truly odd "standards" in the AV industry but the answer is simple if not quite logical. You will use an RCA type cable from the Sub out or LFE on the receiver to just one of the two inputs on the subwoofer. I usually use the one on the right but it really doesn't matter. The other connectors would be for a system with out a sub out where the speaker wire would be run first to the subwoofer and then out to the speakers. This will not be used at all in your case.
Enjy!
Posted on Feb 27, 2009
Technics SU-G75 owners manual download
http://www.manualslib.com/manual/926367/Technics-Su-G75.html?page=2#manual Technics SU G75 Service Manual Page 2
Sep 23, 2015 | Technics SU-G75 Amplifier
Want to download Technics SU-G75 service manual
Technics will not give it to you. Gotta pay the piper!
Did you try to google it - might get lucky - but don't hold your breath.
Sep 21, 2015 | Technics SU-G75 Amplifier
How do i hook my speakers to my amp
Your amp has separate outputs for rear channels. Simply connect your rear speakers to the outlets on the back of your amp set up for them.
Jun 11, 2015 | Technics SU-G75 Amplifier
My technics integrated receiver su-g75 is stuck in
The headphone jack is stuck, something got in there. Probably have to take it apart, but it might be a piece of a plug. Use flashlight...
Aug 28, 2014 | Audio Players & Recorders
Ok I have a technics integrated receiver su-g75 it
The amplifier power transistors could be bad, the speakers can be muted or a fuse for the speakers could have opened.
Technics SU-G75 has no sound
Hello
when the resistors are burned,means that the transistors are damaged, or the power module is damaged.
and in your case its the power module.
Hope this helps.
Feb 07, 2014 | Technics SU-G75 Amplifier
My technics amp SU-G75 keeps shutting off and reads OVERLOAD when played over the volume of -40 to -35. I kept playing around and it works fine when the bass dial is on half, but more bass shuts it off. I...
some amps are made more for low ohm loads (bass) and some are made for high impedence loads (mids/highs) and it seems you are asking too much from your amp.
Mar 05, 2013 | Audio Players & Recorders
Technics SU-g75 Amplifier. No longer any volume. Fuse is OK, display is fine, just no volume??
ALL speaker jacks must be loaded and closed for any sound to come out of this system. Missing one speaker, or one bad connection and you will get no sound or some will work and some will not. speaker wires need to go deep into speaker jack holes.
Aug 04, 2008 | Audio Players & Recorders
52 people viewed this question
 Grubhead
Grubhead
