Check that you have not left a CD, DVD or USB stick or device plugged in when you are trying to boot as the laptop may be trying to boot from that instead of the correct internal hard drive. HAL.DLL is for the Hardware Abstract Layer and if this is really missing or corrupt you will need to look for a recovery disk.boot.ini is normally used on such as Windows XP and you should be able to find examples of this file by searching on Google or the Microsoft site. See http://support.microsoft.com/kb/289022 which gives examples of how to edit boot.ini for Windows XP.
Could be an incorrect bios hard drive setting. Dell has a good customer service area. Did you use same type of drive SATA TO SATA? IDE to IDE? If you changed over there might be a setting to account for the difference.
The first thing to do is go into the bios. To do this, power up the laptop and hit F2 at start up. Sometimes it requires hitting the F2 button numerous times. You should see message in the top right corner that says "Entering Set Up". Once in the bios screen, look through menu to see if your hard drive is recognized by the bios. If it is not recognized by the bios, it may be a defective hard drive or problem with the motherboard. You might also try removing the hard drive and checking for any problems with the connector then reinstalling the hard drive and trying to boot up again. If this does not work, I would recommend replacing the hard drive.
Unmountable boot volume indicating that the system cannot successfully read the boot sector of the hard drive.
Run the diagnostics on the hard drive, if it fails, replace the hard drive.
If diags pass, boot to the recovery console, run chkdsk /r If it still gives the error after that, you can try reinstalling windows.
If that fails to resolve, then again, replace the hard disk drive
It sounds like your lap top took a fall. try booting into your bios and check your boot order and see if it see your hard drive there. has some one pulled out your hard drive and changed any jumpers?
