Question about Motorola Mobility RAZR V3i Cellular Phone
How can I open the back so I can insert my Sim card? Please help. Thank you
Have tried sliding down the back of the mobile phone, but whatever I do it's not opening, please help.
  • 51 Answers
Hi
sir your mobile is not open by sliding down there is botton on the top if you press that and try to pull the cover to your side then it will open
thanks
your friend from fixya!
Posted on Oct 26, 2008
Can you please advise me on removing the back to fit my new sim card Regards
To remove the battery and/or cover from the phone, follow the steps and diagrams below:
To remove the cover, lift up (1) press and slide the section of the phone upward.
Installing the SIM card, make sure the gold contacts of the SIM card are facing down before attempting the insertion. Slide the SIM card into the SIM card socket.
Note: The data stored on the SIM card can be damaged if the card is sctrached or bent during installation, so be very careful when installing the SIM card.
Slide the battery into the compartment so that the tabs on the end align with the slots at the bottom of the device and the metal contacts line up with the those on the device. Lightly press down on the battery until it slips into place
Lastly, Place the battery cover onto the back of the phone (the tabs at the top of the battery cover should interlock in the body chassis). Lower the battery cover down until it is flush with the phone.
Thanks.
Jun 15, 2011 | Samsung Galaxy S GTI9000 Smartphone
Please - how do I open my Nokia 3410 to put a new SIM card in?
Welcome to FixYa.
Hello Biff, here's how to open and put in a new SIM card with your Nokia 3410.
Press the release button (1), slide the cover (2), and lift it off the phone (3). jas247_117.gif Push the two catches in opposite directions (4), and lift the battery out of the phone (5).
Slide the SIM card carefully into the card slot (6). Make sure that the golden connectors on the card are the bevelled corner is on facing downwards and that the left.
Re-insert the battery and close the back cover.
Thank you for using FixYa. Have a great day.
Jas247
Jun 12, 2011 | Nokia 3410 Cellular Phone
Were do i put the sim card i have a nokia 6111
Hello fridge,
i have some tips on how to install sim card on your cellphone:
Install SIM card
1. Make sure that the cover of the connector
panel is closed.
2. Slide the phone open.
3. Open the SIM card compartment (1) on
the back of the slide
4. Slide the metal SIM card holder towards
the compartment lid to release it (2).
5. Open the SIM card holder.
6. Insert the SIM card in the holder as shown (cut corner at
the upper right).
7. Close the SIM card holder, and press it down slightly.
8. To lock the SIM card holder, slide it away from the
compartment lid (1).
9. Close the SIM card compartment (2).
hope this helps :D
Apr 24, 2011 | Nokia 6111 Cellular Phone
I can't open my back cover...how can i change my sim
Hi there!
Let me give you the steps on how to insert the sim card on your phone.
First,kindly switch off the power and disconnect the charger and any other device before removing the covers. Avoid touching electronic components while changing the
covers. Always store and use the device with the covers attached.The SIM card and its contacts can be easily damaged by scratches or bending, so becareful when handling, inserting, or removing the card.
For you to be able to remove the back cover is that you have the press the back part of the phone gently and slide down the back plate of your phone.And after that kindly remove the cover and the battery.Please open the SIM card holder and insert the SIM card into the holder with the bevelled
corner facing down and the contact surface area facing toward the contacts of
the device. Close the SIM card holder.
Line up the battery contacts, and insert the battery. Replace the back cover.
That's it!
Thanks!
Apr 20, 2011 | Nokia X3 Cell Phone
Insert sim problem for nokia 3600 slide
Hello
Try power cycling for the phone. Please follow the steps below:
1. Remove the battery from the phone while it's turned ON.
2. Remove the SIM card.
3. Leave the battery and the SIM card out for five (5) minutes.
4. Put the battery and the SIM back and turn the phone ON.
If same problem occurs, try using another SIM to isolate the problem. If same thing happen after trying another SIM, then the phone needs repair. You may need to contact the manufacturer.
THANK YOU FOR VISITING FIXYA
Mar 03, 2011 | Nokia 3600 slide Cellular Phone
My sidekick slide cant read my new sim..........i need help...when ever i try am stuck at the sim center.
Hi, First request the phone's IMEI code by contacting customer service for T-Mobile. If you've been a customer long enough, T-Mobile may send the IMEI code, or the code identifying the specific phone, in a few days.Turn off the Sidekick Slide. Remove T-Mobile's SIM card, which is located near the battery. Insert the new provider's SIM card.Turn the Sidekick Slide back on. The phone will detect the new code and ask for the IMEI code. Enter the code. Now the Sidekick will operate using the new network.
Thank you
Jan 03, 2011 | T-Mobile Sidekick
I changed sim card, now they both display ''Insert SIM''
try taking out both cards and popping the battery on the phone.
Wait a few minutes and then turn the phone on with no card in it.
Turn it back off when it says no card found and insert the newer card and power it back up.
It seemed to keep a memory of the blank card.
Jul 23, 2009 | Samsung Cell Phones
Emergency calls only and not showing service provider
sounds like either your sim card isnt inserted correctly, or the slots arent turned on. sim card slot 2 is the slot closest to the phone, gold chip faces up, sim card slot one is slightly elevetaed off the phone, gold chip faces down. make sure it is inserted all the way down. perss fimly. then go to SETTINGS>DUAL SIM SETTINGS>DUAL SIM OPEN>CLICK OK. This opens up both sim card slots. after you find out which slot you are going to use, you can repeat these steps and only have opened the one you are using.
Jun 02, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Sim card
HI,
please follow this link for instruction on how to insert sim into nokia 6111
http://nds1.nokia.com/phones/files/guides/Nokia_6111_UG_en.pdf
Jul 10, 2008 | Nokia 6111 Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
149 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
