Question about Dryers
On a fairly new Kenmore dryer,model#110C66012010, dryer works okay but indicator lites won,t work.Interface board was replaced. Rene
  • 156 Answers
SOURCE: kenmore dryer model #11071804000
thay can go bad soon but ck the thermo fuse on the dryer its a white fuse on inside dryer that will fix it 98% time
Posted on Feb 28, 2008
localwonder
  • 6784 Answers
SOURCE: dryer timer not working on a kenmore dryer model 80 serious
HI, if this device isn't working, you will need to replace it. it cannot be repaired. it is designed to fail and when it fails, you will have to replace the entire timer control module.
This device control all aspects of the cycle you initiate.
Posted on May 23, 2009
Maytag317
  • 1136 Answers
SOURCE: My Kenmore electric dryer runs but no heat ....
Hi, You will need to remove the front lower panel and this will get you to the element and thermostats.
With the dryer running. check voltage to the element and you should get 240V. If there is voltage, you will need to change the element.
If there is no voltage to the element, UNPLUG the dryer and check the thermostats and fuse for continuity. These parts are located on the element housing and the blower housing under the drum.
If any of the thermostats or the fuse are open, they will need replaced.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
Posted on May 29, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Kenmore Dryer Model #68202 just quit working. Set
Hi and welcome to FixYa. I am Kelly
Things that will cause a dryer to just up and stop are:
1. Door switch
2. Motor Switch
3. Belt switch
The first thing to check is the door...
a. Verify the door remains closed and that if you gently tug on the door that it does NOT make the door switch click. Things like the switch actuation post get worn and clothes being dried press against the door and can cause the dryer to stop.
The second thing to check is the drum.
a. Reach inside the dryer and push the drum in either direction. If it moves easily with little resistance (Belt not turning the motor as drum is moved) then the belt has broken and the belt saftey switch has been activated causing the dryer to appear dead in all aspects.
The last thing that can cause it to just stop is a failure of the motor or motor switch. (Least suspects at this time)
Also go to the main Circuit breaker panel and physically turn off the dryer 30A Circuit breakers by pushing them against the off position and then back to the on position. This resets the breaker completely
You did not mention the age of this Dryer yet at this time I suspect a broken belt has tripped the belt safety switch.
Thanks for using FixYa!
Kelly
Posted on Mar 03, 2010
heatman101
  • 43501 Answers
SOURCE: My Kenmore dryer won't stay
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jun 02, 2011
Testimonial: "you have been alot of help now I need to go home and double check the items you have listed to see if I can get my dryer to work"
Kenmore elite he3 dryer says PF
The PF and E2 (F02) error codes are related. The PF indicates that the dryer is experiencing a power failure. The F-02 error code indicates a Keypad/User Interface failure. The error codes for this dryer are shown in the third image below.
You could have a loose wire harness connection between the machine control board and the user interface control board that could cause there error messages and symptoms. The first image below shows how to access these components. I recommend that you unplug the dryer and then access these components. Check the wire harness connections on between the user interface control board and the machine control board. If the connections are okay then you will likely need to replace the user interface control board to correct this problem. The part number for the user interface control board is 8564396. You can order this part from the Sears PartsDirect website. It costs just over $100.
Sep 20, 2010 | Kenmore Dryers
Kenmore frontload washer, model#11047087600-- F71 error code displayed--what does it mean? thanks Rene
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 06, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I had a F70 error code on my Kenmore HE Elite dryer. In the manual it does not show a F70 code. I unplugged and let sit for a while now it will not even power up.
Jun 07, 2010 | Kenmore 67082 Electric Dryer
Kenmore Oasis Elite gas dryer,beeping, flashes OF
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
The part number for the user interface for this model is 8564374.
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
The procedure for replacing this control board is shown in the images below.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the washer first.
http://media.fotki.com/1_p,wkgbsdrbswtkdqwxgtqsskgwtqkq,vi/ksgtwdgrtxkrrffsdss/1/1303472/5961857/image29464img-or.jpg
http://media.fotki.com/1_p,sqrbbsbrrbwrbdtxgtqsskgwtqkq,vi/kbqtdwdswxkbswddwbg/1/1303472/5961857/image23056img-or.gif
Apr 01, 2010 | Kenmore 67082 Electric Dryer
My Dryer Kenmore Elite HE5 show the Code F70...
Dec 31, 2009 | Kenmore Elite HE4 Electric Dryer
What is the code F70? Kenmore Elite HE5 dryer
Nov 08, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer seems too hot and displays error code f70
Mar 23, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite quiet pack washer quit. Please help!
Feb 18, 2009 | Kenmore Elite HE4 Electric Dryer
Clothes not dry and get F70 code
Jan 03, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore HE5t washer
Sep 06, 2008 | Kenmore 67082 Electric Dryer
Dryers Logo
180 people viewed this question
Top Dryers Experts
