Question about Garden
Troy built weedwacker wont start
I have a troy built weedwacker that is refusing to start, have changed the spark plug, any more suggestions
  • 2,239 Answers
Try draining the fuel and re filling with fresh, if no better, does it have a spark at the plug? does the plug get wet with fuel? if not try replacing the fuel filter in the fuel tank.
Posted on Feb 18, 2012
  • 115 Answers
SOURCE: wont start
could be a fouled plug,bad coil,or contacts on flywheel rusty
Posted on Aug 23, 2009
  • 211 Answers
SOURCE: Ryobi 780 Trimmer No Spark - won't start
Hi
Check the spark at the plug,compression and carburation.Clean the air and the fuel filters.Check the muffler.
best regards savumihai71
Posted on Feb 12, 2009
  • 41 Answers
SOURCE: weedwacker starts easy but will not run for more than 5 seconds .
May need to check for holes in fuels. Or fuel pump diapham is bad. If so replace carb., don,t waste money on carb. kit.
Posted on May 13, 2009
connertamago
  • 37 Answers
SOURCE: Troy-Built TB70SS, 1 year old, will not start even after carb cleaning
check to see that the kill button is not stuck in the contacting position, and if it is, try to get it unstuck. WD40 should help. if it's not, then disconnect the kill wires. now try starting it. if it still doesnt start, then the spark generator is bad. if this is the case, you'll need a new trimmer, or have a small engine mechanic replace the generator. i think its called the coil, not sure at the moment it's 4:00 am for me. anyways, whichever is cheaper is best choice.
Posted on Jun 01, 2009
  • 7 Answers
SOURCE: troy-bilt gas edger trencher won't start. Spark
Remove spark plug and pour 5mls or one teaspoon of premixed gas in the engine. Depress trottle to full with choke on "run", pull starter about 10 to 12 times If it starts and run for a while and then shuts off your carb needs servicing. If not remove muffler and look for a spark arrestor screen. This could be plugged up with soot. If it is, replace and this would have been your problem. While the muffler is off slowly pull starter rope and examine the piston if gas and oil oozes backwards as the piston moves to the top then the piston and rings need replacing.
Posted on Nov 10, 2009
Was running stalled now wont start
Tina you could try a new spark plug. This may have given up the ghost.
Oct 16, 2013 | Troy-Bilt Troy-Built Gas String Trimmer...
Troy built 6.75 Briggs is very slow to start. The plug has been changed. Air Filter changed. Plug is usually wet with fuel when it wont start?
first is the fuel older than 30days from the pump?then check for spark the coil might be weak
Jun 10, 2012 | Garden
Troy built tiler won't start!!
What is the method your machine uses to decide when to fire the spark plug? Does it have a magneto, and/or ignition points under the flywheel, or a crankshaft postion sensor?
Apr 18, 2017 | Computers & Internet
I put trimmer away after using, and the next time I took it out it would not start, I changed the spark plug and the gas and still it wont start., the kill switch on the handle check out ok with a meter?
I want u to make sure a critter hasn't built a nest in the exaust hole.
Use something to get in there and scratch around with, and blow out with some air. If its not exausting it won't start. Also make sure the fuel lines are not cracked or loose and letting air bubbles in, she won't start then either. Hope I helped.
ballping
Jul 26, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Can't start my Troy Built Tuffy tiller. I haven't used it for a year, but it started fine last season. I replaced the spark plug, changed the oil and air filter and filled it with fresh gas. When I pull...
First pull your spark plug out reconnect to the plug wire and ground tot he engine body
Pull the starter cord and see if you have a good clean spark that goes to the electrode and not to the side of the spark plug.
If no spark check your off/on switch
Mar 31, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have changed the air filter and bought a new spark plug but my troy built with Honda 160 cc engine will not start.
there is a possibility the c oil is bad, pull the plug and with wire attached pull cord to see if any spark
Aug 07, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Have a riding Troy Built that just quit. Will not start. Tested battery, it's good. Has gas. Any suggestions?
Sounds like your electronic ignition has gone bad. Usually when they start going bad you can let the engine cool and it will restart. In your case, apparantly it gave no warning. Check it by unscrewing the spark plug, leave the lead wire hooked to it, placing the spark end of the plug against the head. Try to turn the engine over and see if there is any spark jumping from the end of the plug to the metal. If not, it's the electronic ignition. But be sure the plug you are using is good.
Jun 17, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
May 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy built leaf blower
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
Nov 18, 2008 | Troy Bilt 31cc Quickshift Blowervac, Model...
Garden Logo
191 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
