Question about GE Refrigerators
Ge refrigerator GE profile model # PSS 26 S GPA SS stopped freezing this morning temperature keeps rising power on not cooling
hotuna
  • 288 Answers
SOURCE: GE Regrigerator "Profile" PSS26SHPA SS
It sounds like the drainage for the defrost water is plugged or obstructed somehow. The ice build up is left over water that is freezing due to the fact that it has not been channeled out properly and when the cycle comes back on it freezes.
look for the collection pan underneath the fridge, access the tube ending to there, blow some air through it. Compressed works best if you have access to some. Also I would advise doing this after the unit has been off for a short while, sometimes the plug will be frozen, so give it time to melt just in case. When you blow on the tube there should be no back pressure, this will tell you if the plug has been removed.
Posted on Dec 06, 2007
SOURCE: GE Profile Refrigerator PFS22SISBSS Bottom Freezer Temperature Indicators
I finally called GE about the non-working LED's and the temperature fluctuation. It's a known problem as many consumers have posted online. I called 800-386-1215 several times. What I found is I'd get different menu options nearly each time I called. The way I got to a 'helpful' human follows: Call above number; you will/may here a voice that states only 'for recalled appliances press 9' (may also have options for repair or parts) PRESS 0; next menu PRESS 5; you'll hear 'for less than 1 yr old press 1' and 'for more than 1 yr press 2'. In my case I pressed 2, then got a menu with 'for refrigerators PRESS 2'. Spoke to a woman who never denied that GE has a motherboard problem. She offered to provide a free motherboard but no labor. I asked (to be sure) if I would have to pay labor, she said yes or I could have $400 off a new crappy GE fridge. She said I would have to have a repairman come to diagnose the problem, then order the part and then come back to repair. I then said, 'You're telling me that I have to pay for TWO service calls to repair a known GE defect???? How much should I expect to pay for these TWO service calls???' She then asked me to hold, then came back on the line and told me that GE would pay the labor for the repair.
I also asked if GE was willing to do anything about the 25 cent door latch that cracked after 11 months (and is attached to the door gasket a $228.00 part) or the rusting wire freezer baskets and was told no. Hey, worth a try! The fact that they said no ensures that I will continue on my crusade to warn anyone who'll listen not to buy GE! Keep calling, after I got the right menu the wait was short the whole call was less than 15 minutes.
Posted on Sep 17, 2008
  • 61 Answers
SOURCE: Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Posted on Jun 08, 2009
MNTECH
  • 1543 Answers
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Posted on Aug 04, 2009
  • 288 Answers
SOURCE: GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Posted on Nov 27, 2009
Hi. Our GE GSH25JSDD SS side by side drive just stopped freezing, cooling. The fan is on inside freezer and lights, and motor down on bottom, back is running. Drain is clear. Won't cool down.
I need someone to feel the top of the compressor. Is it cool, hot or too hot to keep your hand there? Usually on GE models like yours the=> WR55X11072 Main Control Board is the problem along with the start relay, overload and run capacitor. GE Refrigerator Model GSH25JSDD SS Parts
I'm here should you have question, Thanks, Sea Breeze
Oct 10, 2015 | GE Refrigerators
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
Temperature rising in freezer and fridge motor running constantly
The temperature in the freezer will rise if there is no air circulation. Air circulation stops when the evaporator freezes solid. When this happens the thermostat cn not respond and the fridge keeps running.
Defrost the freezer and see if things return to normal. If they do then you have an auto defrost problem.
A technician can help you with this problem
Apr 01, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Our GE Profile PSS25NGMABB has a temperature flux both Freezer and Refrigerator. I've noticed occassional icing in the freezer and noticed some items are warming up and then refreezing. I had a tech come...
Very Unlikely, more likely you have a defrost problem. Probably the control board or a defrost thermostat. This is a complicated refrigerator, I would call another company, make sure they know the GE PSS models well. I have to carry a service book just to be able to test the electrical on these models control boards. Good Luck, Appliance Specialists
Dec 31, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Both Freezer and refrigerator are not as cold as they should be
We may need to look at the control circuit board the back of refrigerator if the refrigerator has stopped cooling. Let me know if the compressor is running or not. Let me know, I have a repair manual if you like.
Thanks, Sea Breeze
Apr 21, 2009 | GE Profile CustomStyle¿ 22.6 Cu. Ft....
Refrigerator will not cool
Unplug power, pull refrigerator away from wall and gently remove and examine both sides of control board, Look for burn marks or smell of burns and then let me know what you find. Thanks, Sea Breeze
Mar 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Feb 24, 2008 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
