Question about Whirlpool Dishwashers
Du3003xl whirlpool dishwasher
Spray arm
  • 14 Answers
SOURCE: whirlpool GU3200 dishwasher
The illusive technical repair sheet that isn't there...
Turn the thing a little further and pull UP. It'll come out. You've got to put some muscle into it!
The manual for the GU1000/1200/1500 is here (it's almost the same and as close as I can get you to a 3200)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
Jeremy
Posted on Dec 29, 2007
watugot
  • 290 Answers
SOURCE: dishwasher - no spray arm action
If it is filling with water properly then it sounds like the chopper screen is clogged so that water isn't getting into the pump. You can remove the top of the pump housing and get to the screen and chopper blade to inspect it. Go to sears.com, click on parts and enter your model number and you can view a diagram of the pump parts to help in disassembling it.
If the pump is not clogged then you have a problem with the impeller or motor. If this is the case you can replace the entire sump assembly just about as cheap as replacing individual parts of the pump.
Post back with any questions.
Thanks, Mike
Posted on Feb 16, 2008
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
SOURCE: Dishwasher upper arm does not spray
possible ball valve problem
Posted on Jan 03, 2009
  • 254 Answers
SOURCE: SPRAY ARM ASSEMBLEY NOT TURNING ON MY BOSCH
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
Posted on Mar 09, 2009
I have a whirlpool dishwasher WDF530PLYB and I need to clean my filtration screens and I can't get it out. Please help. Thanks
If you are speaking about the filter behind the spray arm in the tub:
grasp the tower (the top post above the spray arm)
and unscrew it. CCW under and in the center of the tower hole thus revealed is a philips screw and fiber washer holding the spray arm on remove these then remove the arm. next, using a flat screwdriver un-snap the filter cover
Mar 17, 2018 | Whirlpool Dishwashers
I have a Whirlpool DU3003XL dishwasher, the filling water supply and the drain pump run at the same time. The dishwasher has not been used for quite a long time.
Hi, You have a faulty pressure switch. You will need to remove the outer casing and look for a round device that is typically red(ish) and grey in colour with a couple of small hoses attached to it.
Replace that and that should solve your issue.
Jul 04, 2017 | Whirlpool Dishwashers
Looking for answer to error code F5 on Whirlpool Dishwasher ADG 8200
Fault Code F5 or Five Flashes
Cause: Spray arms are blocked/clogged or otherwise malfunctioning.
Action: Spray arms are easily removed so take them out of the dishwasher and wash in the sink to clear out any gunk (using descaler should help shift any stubborn debris). Whilst doing this run the dishwasher on a short program without the spray arms to clear any further blockages.
Jul 14, 2016 | Whirlpool ADG8200 Dishwasher
How do I remove spin arm assembly from my kitchenaid dishwasher
About 56,200 results (0.83 seconds) Search Results
    How To Repair Dishwashers/KitchenAid Repair/Chopper ...
    https://en.wikibooks.org/...Dishwashers/KitchenAid.../Choppe...
    WikibooksDisassembly guide to access the chopper assembly in: KitchenAid K seriesdishwasher (similar to Whirlpool and Kenmore models) ... If the door safety interlock fails, the dishwasher could return to an active mode where these blades spin and ...place and carefully work around it to remove the upper spray arm water conduit.
    How to: remove and clean your dishwasher spray arms ...
    ? 3:13
    https://www.youtube.com/watch?v=MCWvxGmK3eM
    Feb 1, 2013 - Uploaded by Indesit Service UK
    Watch our easy to follow guide on how to remove and clean your Indesit dishw... ... KitchenAid & Whirlpool Dishwasher - Not Cleaning ,pump wash arm impeller chopper ... Why am I getting poor results from my dishwasher?
    Dishwasher Not Cleaning-How to Remove Spray Arms ...
    ? 3:47
    https://www.youtube.com/watch?v=BIru-ieAK54
Feb 03, 2016 | KitchenAid Dishwashers
I have a Whirlpool GU2455.... dishwasher. Top spray arm is not spinning. Lower arm appears to be moving but slowly. Dishes on the top rack do not get cleaned. They are wetted, but the arm doesn't appear to...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Jan 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher sprays water up into the dishes but the little spray arms don't move when the water sprays up. The arms move by hand when I touch them. What could this mean for my dishwasher?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Aug 31, 2010 | Whirlpool Dishwashers
Dishes not being cleaned
Here is a tip that will help you with that problem...
Dishwasher2_bing.gif Spray Arms not Spinning
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Asker's Testimonial " Thank you. This was very helpful " - johnson20717
Jul 18, 2010 | Whirlpool Dishwashers
My whirlpool Quiet Partner 1 leaks from the bottom of the door.
Some leaking around-under-from the door on dishwashers can be traced back to a split in the spray arm. If the lower spray arm develops a split in it, the spray arm can turn too fast, and shoot water directly at things that it is not suppose to spray water at....sprays water at the door vents or edges and can create water leaks. See if thats the problem
Nov 13, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwasher does not clean items on top shelf.
Check the upper spray arm holes for debris that may be plugging up the spray arm. If clean remove the lower spray arm and filter screen and clean out any debris in the sump.
Feb 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Dishwashers Logo
71 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
