Question about Garden
How do I drain gas in a craftsman riding mower carburetor
How do I drain carberator on 18 horse motor
  • JamesDias Feb 16, 2012
    e is a electric wire conected to carberator
    Can I unscrew the electric terminal from carberator to let gas out
  • Garden Master
  • 2,478 Answers
On bottom of carb is fuel solenoid, unscrew and the gas. May to unhook wire to it.
Posted on Feb 16, 2012
panilling9
  • 284 Answers
SOURCE: gas coming out of exhaust is it the carburetor and why
carb. float stuck open
Need to remove carb. replace float needle valve and possibly the needle valve seat,
change your oil also
saturated with fuel
Posted on May 25, 2009
ozark333
  • 396 Answers
SOURCE: I have a Craftsman mower LT1000 riding mower 17
Also, unplug the wires connected to the bottom of the float-bowl. Just wiggle the plug loose off the bottom of the bowl.
These are 12 volt powered when the ignition is on. Put your key in the ignition and turn it to ON. * DO NOT ATTEMPT TO START THE MOWER.*
With the key in the ON position, use a volt meter and test for 12 Volts
to the terminals of the plug. The Grey is Positive and the Black is Ground.
You should see 12 volts to this connection which powers the Fuel Shut-off solenoid. This solenoid shuts off fuel when you turn off your mower to prevent backfires (IMO-doesnt work!) If you dont see 12 volts, check the plug on the opposite side of your mower where the Grey and Black wires go to. We have had several of these connections fail due to corrosion (needs di-electric grease-Craftsman...are you listening?) Disconnect the plug and see which pins feed the Grey wire. Now test for 12 volts at the plug on the side that leads back up to the ignition switch. If you see 12 volts you know you have the same corrosion problem. Clean the pins, if you have it, a shot of di-electric grease so it wont happen again and reconnect. Test at the float-bowl connector now. Hopefully you will see 12 volts and are all set. If no voltage is at the ignition switch side of the connector you need to test the ignition switch. I believe most mowers will use a Red wire down to the connection we checked and follow that wire to the ignition switch. Tap the wire close to the switch and test for voltage. If you have voltage you know there is a break in the wire leading to the connector. If no voltage is present at the output of the ignition switch it may be time for a new one. You could test all the wires of the ignition switch for another wire that has 12 volts when the ignition is on and simply place a jumper between that wire and the Red feed wire for the solenoid. Of course this is a last resort but should work in a pinch. Good luck.
Posted on Sep 29, 2009
  • 78 Answers
SOURCE: I need a diagram for a Kohler carburetor on my
I dont see any Diaphram listed. I would go to your local Yard equipment Dealer that handles Kohler. but my reference books show no diaphram or even a model ca
Sorry
Posted on Oct 22, 2009
backwoodsctr
  • 169 Answers
SOURCE: Adjusting a craftsman dlt 3000 riding mower
assuming that you are working on a briggs engine? regardless of make what the problem is that the needle and seat inside the carb is not sealing off the fuel flow from the fuel pump/fuel tank or both......gravity feed fuel systems are the worst about flooding, the only fix will be a carburetor repair with needle and seat replacement
Posted on Nov 25, 2009
  • 95 Answers
SOURCE: I need a diagram on how to replace a 42
Follow this link to Sears parts site put in your model number and you might be able to find it there.
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Mar 17, 2010
How do i fix the carburetor on a craftsman riding mower with a 15 horse briggs motor.
Your carb needs cleaning sounds like the very small jet about the size of a small needle inside the bowl that feeds the intake " top " of the carb is pluged or dirty..you must take it apart and clean or get a rebuild kit..good luck.
Jun 14, 2014 | Craftsman Garden
You may need to change the fuel filter, change and gap the spark plug, and adjust the valves.
Craftsman 42 " mower w/Kohler 18 horse engine clicks, but will not turn over.
my westwood tractor 1600hp will not charge the battery
Apr 17, 2013 | Craftsman Garden
Craftsman Lawn Mower
If a riding mower, unscrew fuel solenoid and unplug wire going it on bottom of carb, If it doesn't a solenoid, remove small nut on bottom of carb.
Feb 16, 2012 | Garden
MOWER ONLY RUN WHEN U PUT GAS IN CAB WANT START
Ok, so your not getting gas to carberator, or thru the carberator. Disconnect gas line from carberator, if gas is present thru fuel line, you have a carberator problem. Your rather meger with your mower information so this is all i can tell you. Wish i could be of more help.
May 29, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
