Question about Garden
Craftsman Lawn Mower
How to drain carberator of gas
  • Garden Master
  • 2,478 Answers
If a riding mower, unscrew fuel solenoid and unplug wire going it on bottom of carb, If it doesn't a solenoid, remove small nut on bottom of carb.
Posted on Feb 16, 2012
SOURCE: craftsman lawn mower
I had both my front wheels wobbly - so I cut shims from a tin can - wrapped the axle of the wheels with the shims and then inserted them back into the plastic bushes. It was a snug fit - but helped quite a lot.
Posted on May 27, 2008
  • 68 Answers
SOURCE: I need to find a repair manual for a craftsman riding lawn mower
SearsPartsDirect.com should have your answers
Posted on Apr 26, 2009
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
  • 376 Answers
SOURCE: Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
Posted on May 25, 2009
bargainbin2
  • 123 Answers
SOURCE: 13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Posted on Aug 29, 2009
Craftsman Briggs & Stratton lawn mower 450series, only used3 times and it will not start? Has oil, gas
Hi Elva
If the mower has been sitting for a while the plastic carburetors have a tendency to plug up. If I remember correctly the choke is attached to the governor. If you can empty the old gas and fill the tank up with 93 octane and let it sit for a couple of day's it may start. I had the same problem. Thx
Jul 28, 2016 | Craftsman Garden
Lawn mower will not start after running out of gas.
are you getting spark?was the gas you put in newer than 30 days old?
Jul 22, 2012 | Poulan Garden
Oil plug Murray mower 22525x92a
there is a drain on the bottom of the mower but its easier to run it out of gas and then turn it on its side and drain it from the dip stick hole
May 20, 2012 | Craftsman 550 Torque 22 in Deck 2n1 Side...
How do I drain gas in a craftsman riding mower carburetor
On bottom of carb is fuel solenoid, unscrew and the gas. May to unhook wire to it.
Feb 16, 2012 | Garden
MOWER ONLY RUN WHEN U PUT GAS IN CAB WANT START
Ok, so your not getting gas to carberator, or thru the carberator. Disconnect gas line from carberator, if gas is present thru fuel line, you have a carberator problem. Your rather meger with your mower information so this is all i can tell you. Wish i could be of more help.
May 29, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I can not keep my mower running. It ran great before winter, now it acts like it is going to run.. but dies. I have new gas in it, new oil, and changed the spark plug. What else could it be? craftsman...
Hi, I would suggest taking the main jet out of the carberator and cleaning it with carb cleaner. If you did'nt drain the gas out of it before winter, the gas has gotten old and has plugged up your main jet in the carberator. It could also be that the needle has got **** on it and is stuck, I'd clean that also. Your problem is all in the carberator, and old stale gas sitting in it all winter is the reason.
May 08, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
How do I change the oil on my craftsman lawn mower
put a small tub on the ground , remove the dip stick , and tilt the mower on its side with the air cleaner / carb , up and let it drain out . or there is a drain plug under the motor near the blade
Apr 12, 2010 | Craftsman 25cc Gas Line Trimmer
I left gas/oil mixture in my Craftsman weed wacker for too long and now it won't start. Is there a simple way to fix it? I assume the carburator is crudded up. Thanks!
I add fuel stabilizer if fuel is still in mowers, etc. for the winter since it isn't easy to totally drain it.
Just a day ago, our rototiller was limbered up for the garden and I shot 'starter fluid' (ether) into the air intake before even trying it and it fired on the second pull. You can buy the stuff at any auto parts store and even dollar stores.
Mar 20, 2010 | Craftsman 25cc Gas Line Trimmer
Putting the carberator back together.
one end to the govenor other end to the throttle on carb
Jun 30, 2009 | Craftsman Garden
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
