Question about Sony Ericsson P900
Stylus to sceen problem
I have reset the calibration so that when you tap the screen with the stylus it responds correctly. There is one small area however on the screen where it records slightly above where you touched with the stylus. This area is around the lower centre of the screen so it is not possible to pick up the on-screen keyboard as it always assumes I am touching just above this. The phone has never been dropped or abused. Any ideas anyone ?
  • Oliver Doherty Aug 17, 2006
    Whoops - Heading should read: Stylus to Screen problem
Its gone m8 i got the p910 and i got the same problem with it u can get a new one off ebay for bout 30 with postage and its dead easy to fit, if u cant fix it ur self let me no ill take sum pics and send them to u
Posted on Feb 24, 2007
Htc prophet touch screen issue
for window phones
1. Press the "Home" key and press "Start." Use the directional pad to highlight "Settings," then press the center or "Enter" button.
2. Use the directional pad to select the System tab. Select "Screen," then press the center or "Enter" button. Select "Align Screen."
3. Using your smartphone's stylus, tap the crosshairs as they appear on your screen. Do this for as many as appear, until the calibration tool finishes. Your screen is now properly calibrated.
for Android phone
4. Press the "Home" button or capacitive area, then press "Menu." Tap "Settings."
5. Tap "Language and keyboard." Tap "Keyboard settings." Tap "Tutorial" and go through the steps that appear on your screen.
6. Once this is finished, turn your phone off and on again. Your keyboard has been adjusted, which activates a re-calibration of the capacitive touchscreen. (Capacitive screens are technically far more accurate that resistive, and so a full calibration tool is not included with Android phones.)
Aug 20, 2012 | imate JAMin Smartphone
The pen has stopped working when touching the screen
If your Leapster 2 will turn on, but the touch screen is not responding to the stylus, try re-calibrating the stylus with the screen using the steps below: 1. Turn your Leapster 2 off, and remove the game cartridge.
2. Hold down the 'hint' button while the game is off. The 'hint' button is the middle small button in the row of three above the directional pad on the left, with a '?' on it.
3. With your finger still firmly on the 'hint' button, turn the Leapster 2 back on. Keep your finger on the 'hint' button.
4. The screen should be displaying the calibration screen. You can release the 'hint' button now.
5. Press the 'A' button on the right to enter the calibration screen.
6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your Leapster 2 throws at you.
7. The screen will return to the calibration screen. You can now turn the machine off. Leave the cartridge out of the console, and turn it back on.
8. Your stylus and touch screen should now be working, enabling you to sign in as usual.
9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Mar 28, 2011 | Leapster 2 Handheld Game
The touch screen does not respond to the stylus what can i do?
Welcome to Fixya. If you need to sync the device to the stylus just follow the steps below.
9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on.
Thanks for using Fixya,
Mar 02, 2011 | LeapFrog Leapster 2 Learning System
IQue 3600 won't respond properly to stylus. Responds if you touch one item down the lists. Example, to OK something, you have to touch right below the OK. It just recently started this, Maps display...
I solved the problem by re-calibrating the screen. Go to the home icon on the screenn tap preferences, date and time, then tap digitizer. Then follow the prompts and tap exactly on the target Xs.
Thanks!
Oct 01, 2009 | Garmin iQue 3600 GPS Receiver
My Sylvania SMPK8854 touch screen 4GB mp3 player will not respond to touch. I tried resetting it but did not help. How do I fix it?
YEA PLEASE CAN YOU HELP MEE BECAUSE MY Sylvania SMPK8854B WILL NOT LETT ME TOUCH THE SETTING AND I REALLY NEED HELP!! WITH MY Sylvania SMPK8854B!!
THANK YOU THEY MUCH!♥
Jul 09, 2009 | Sylvania SMPK8854 Digital Media Player
When i do hard reset hx2490b screen calibration does not appear
Try using your finger to calibrate the screen at first. (If you have difficult to navigate to the alignment screen use the stylus & keyboard to feel out your way) when calibrated to an accepable degree use the stylus to calibrate the sreen, if the target doesn't respond to stylus at any specific piont use your finger. Continue this process till u get it aligned as best as possible. I suspect this problem is caused by specific points on the screen going bad.
Feb 24, 2009 | HP iPAQ HX2490 Pocket PC
Zire won't come on
You need to follow the procedure to calibrate the digitizer.
If the screen does not respond to the stylus, then the digitizer is defective and needs to be replaced.
Best regards,
Feb 11, 2009 | Palm Zire 71 Handheld
Screen Calibration
Check for protective film/screen debris build-up around edges.
Check for loose cabling plugs into the back of the Screen
Unscrew the four little fascia screws & lift panel out.
I had same problem after unable to enter password.
Did Hard reset, encountered the stylus calibration cycling error.
One of my screen cables had come adrift slightly at one corner.
Jul 29, 2008 | Sony CLIE PEG-N760C Handheld
Palm m505 problem after hard reset
ouch... Try opening it up and run a business card between the digitizer and the screen. Fixes m500s and m100s.
Apr 02, 2008 | Palm m505 Handheld
Calibration of my MobilePro off
We've put together some useful tips on calibrating your MobilePro * When calibrating your touch screen be sure to use the same amount of pressure that you apply during normal use. In general, the lighter the better. This allows the screen to recognize taps consistently. * When calibrating your touch screen hold the stylus over the calibration point until it moves to the next point. Holding it for this period will lead to greater accuracy than just tapping the spot quickly. * When calibrating your touch screen support the screen from the back with your other hand. Try not to grasp the screen from the side with your thumb on the front. * When calibrating your touch screen do not let anything other that the stylus accidentally touch the screen. For example, don't rest part of your hand on the screen to help steady the stylus. * Once you've completed the stylus calibration, be sure to perform the double tap calibration as well. This will ensure greater accuracy.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Sony Ericsson P900 Logo
46 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
