Question about Refrigerators
Need user manual for gram k1407 commercial fridge
Fridge freezing up, think settings wrong
2 Suggested Answers
deltonsmith9
  • 96 Answers
SOURCE: MANUAL FOR GRAM FRIDGE K410RGC6N
type in model number and download it on pdf files and print just search for free copy
Posted on Jun 03, 2012
The True brand commercial refrigerator at my job is entirely too cold. How do I adjust the temp? Beer is exploding!
You will need to adjust the thermostat.
The thermostat will be hidden at the bottom back of the fridge near the compressor.
You may need a screw a flat blade driver driver to adjust the themostat
Apr 01, 2011 | True TSSU-48-12 Refrigerator Commercial
My fridge is over cooling - now freezing food
i just want to say that i have the same fridge freezer and that is whats happening to mine. even the drinks are freezing aswell as tomatoes and any other thing that is put in there. after reading your problem im thinking maybe this is a manufacturing fault. i am about to buy an extended warrenty for mine then i can get the poeple to fix it as mine is also 3yrs old. hope that helps.
Feb 19, 2010 | Hoover HCA390FFK Bottom Freezer...
Crisper and veggie bins are freezing the produce
I have dealt with bosch and thermador quit a bit and they usually don't have to much of a recommendation for these settings because they are more of a commercial type appliance producer and all situations are different. Here is a tip for the sliders though. Remember that leafy produce needs more airflow to hold its texture and taste and anything with a skin requires less airflow. As far as the temp settings I believe the most nominal settings are going to be in between 5 & 7 to keep from freezing the produce. You will have to play around with it a little though to get it to keep the ref good and cold but keep from freezing the vegies. Hope this helps. Good luck.
Jun 05, 2009 | Bosch KGU6655
KF48 Beverage Air Freezer permently stuck on "defrost."
Unplug the fridge overnight and defrost it completely. Ensure the thermostat is properly set.
If it does not restart normal function after you plug back, then there may be a fault concerning the digital control, in that case call the number listed on the owner manual.
Jan 06, 2009 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Beverage-Air DD50 Commercial Keg Fridge Not Cooling
The starting components on the compressor could be going bad. You need to turn off the thermostat and then after about five minutes turn it on while listening to the compressor to hear if it kicks in, if it doesn't then you might have faulty starting component, more likely the overload.
Jun 26, 2008 | Beverage-Air DW49 Stainless Steel Beverage...
Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Jan 28, 2008 | Arctic Air R22CW Refrigerator
Samsung ht-db650
I dont think its connected. anyway, make sure DVD is clean and unscratched. If it wont help and these are commercial DVDs, then there is probably something wrong with them. If they are home made DVDs, then it may be that your player doesn't handle them well and you can try to burn it a other dvd format... look in you r manual to find out which format are compatible.. Good luck.
Jan 15, 2006 | Samsung HTDB650 System
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
